I can't get my IPcam get to work on my pronto.
I use a instar ip camera and I can log in with
http://192.168.2.150/snapshot.cgi?user= ... d=roland25
I use the IPCams v9600 script.
can someone help me to get it work
IP Cam on Pronto
IP Cam on Pronto
Ralph
Re: IP Cam on Pronto
of cause I've been reading these topics bofore I was posting mine ,but I'm nog good in scripting. so I was hoping that someone can help me with an easy solution.
best regards ralph
best regards ralph
Ralph
Try this one:
var socket = new TCPSocket();
var receivedData = "";
socket.onConnect = function() {
System.print ("TCP-IP Connected");
socket.write("GET /snapshot.cgi?user=admin&pwd=roland25" + " HTTP/1.1\r\n\r\n");
socket.onData = function() {
receivedData += socket.read();
System.print ("Tcpip Data Received:"+ receivedData);
socket.onIOError = function (x) {
GUI.widget("panel").label = "IOError " + x;
System.print ("Tcp Error:"+ x);
socket.onClose = function () {
// remove the HTTP info from received data
var imageStartIndex = receivedData.indexOf("\r\n\r\n");
var bitmapData = receivedData.substring(imageStartIndex+4);
// display the image
var MyImage = new Image(bitmapData);
GUI.widget("panel").setImage(MyImage);
socket.connect("192.168.2.150", 80, 6000);
sorry cant help you right now
at the moment I have not installed the Pronto software.
Read the stuff first, because if you don't' understand the basic stuff it will be very hard to understand the complete package.
Programming the pronto is no boy stuff
- Starting Member
Ralhop, did you made any progress? bacause i am having problems likewise !ralhop wrote:I'm new in Prontoedit so where do I put this script?
grz Ralph
