Version 0.7.0.0
Moderator: RdP
Version 0.7.0.0
Releasing this version took a bit longer than I expected, caused by some last-minute issues with a model 7390 which I wanted to solve first.
Download: http://www.hekkers.net/files/FBF_0702.rar
Changelog will follow in the weekend, but most issues are solved (I think :) )
@Enver: delete the WLan device for the toggle to work (not 100% sure, could not test this).
Reason: Changed link to latest version 0.7.0.2
abl
Re: Version 0.7.0.0
Post by abl »
Just installed this version without any problems! Unfortunately I can't check the changes (forgot my mobile at my work)...
Thanks Digit for the effort you put into this project!
stefxx
Re: Version 0.7.0.0
Post by stefxx »
Thanks again for this great plugin!
Re: Version 0.7.0.0
Robert,
How can I create the WLAN device?
Update: After delete just restart Homeseer
Re: Version 0.7.0.0
sddroog wrote:Thanks again for this great plugin!
And to you for helping me (and by that, also the rest)!
abl
Re: Version 0.7.0.0
Post by abl »
I can confirm that when there is no caller information available 'unknown' is shown as last caller name (which is going through my speakers). Before that the speakers told us that somebody familiar was calling which was not always the case (not too good for the WAF :mrgreen: ). Now it is working perfectly...
Re: Version 0.7.0.0
Robert,
Wlan toggle option is not not visibile.
Schermafbeelding 2011-01-07 om 23.12.53.png (15.95 KiB) Viewed 24285 times
Schermafbeelding 2011-01-07 om 23.11.59.png (14.78 KiB) Viewed 24285 times
RdP
Re: Version 0.7.0.0
Post by RdP »
Thanks Robert,
All seems to be working....
Just curious what the release notes are.
And what I can do with the Country and area prefix codes
/Rien
Re: Version 0.7.0.0
TANE wrote:Robert,
So it is visible. But I don't see it.
I think I have something to work on for the next release.
Re: Version 0.7.0.0
RdP wrote:Thanks Robert,
Nice!
You? Nothing. See if they are correct, nothing more :) The Plugin will try to use them (for now, only the area code) when the Fritz reports a phone number that is 6 or 7 positions long, which means the phone number doesn't contain the area code.
When the area code can be successfully retrieved from the Fritz!Box settings, the Plugin will use this area code to perform a name search with a phone number including that area code if not provided. So, if the other side is being reported as 1234567 by the Fritz, this will probably mean that the phone number is lacking an area code. In that case, if your area code is 321, the Plugin will do a name search for 3211234567. But only for an online search!
If you think you cannot live without this feature, we will have to exchange some information to get this working on your Fritz model as well.
Another option would be upgrading to a 7390, the decision is yours :)
Re: Version 0.7.0.0
abl wrote:Now it is working perfectly...
Thanks for the reply.
Re: Version 0.7.0.0
http://www.hekkers.net/files/fbf_0701.rar should fix the HSTouch toggle option.
Re: Version 0.7.0.0
No list of changes yet... I've been working a lot this weekend, these last few hours I'm going to do some stuff I really like :D
Re: Version 0.7.0.0
Robert,
Bedankt voor de update
Device toggle werkt perfect in versie 0.7.0.1
Re: Version 0.7.0.0
Stuur de taart maar naar René :)
Locked
