updating doorcam image in HStouch
Jeroen Bartels
Post by Jeroen Bartels »
I'm trying to get the latest image from my doorcam on my iphone using HST.
I do have the image but it does not refresh when a new 'latest.jpg' is created. So it keeps on showing the original picture when i deployed.
In HST I choose image (correct?) and set video=true and refresh=60 sec. Does not work.
For me it does not have to refresh automatically every xx sec, just when I open the screen would be OK too.
Can anybody help me or show a screenshot of the working settings?
Question 2: If i would set refresh every 60 seconds (without the 'latest.jpg' image being renewed, does it still use data-traffic?) I only have a limited data available every month (my employer does noy understand that I need unlimited for domotica reasons :roll: )
See below my current settings:
Thanx,
**Jeroen**
Rutger
Re: updating doorcam image in HStouch
Post by Rutger »
Hi jeroen,
Question 1 can be simply answered, because I had the same problem last week. You have to place the image location at the 'ImageURLNormal' section.
I use also the complete pad like i.e. 'http://192.168.1.58/ipcam.jpg', but your link should also work I think.
On question 2 I can't give you an answer.
DJF3
Post by DJF3 »
Jeroen,
Q1: You image doesn't refresh. Could this be because you're not using imageURL? Should you point to a 'web' location instead of a file-system location?
(can you put your latest.jpg in your Homeseer HTML directory and then use http://<ipaddress>/latest.jpg)
Q2: I would think a refresh is a refresh (like a browser reload). If the image doesn't change the image will be reloaded as it can't tell if the source changed.
DJ
Jeroen Bartels
Hey guys,
Thanx so far.
One more question: When I store the webcam picture in the HTML folder it works fine.
But I would like to store them in /html/webcam/logitech c210/latest.jpg
What should I change the location into as http://192.168.1.3:82/webcam/logitech c210/latest.jpg is not working?
**Jeroen**
Esteban
Post by Esteban »
Remove the space in your URL and rename your directory 'logitech c210' to 'logitechc210'. That should solve it. Then all you should need is:
http://192.168.1.3:82/webcam/logitechc210/latest.jpg
Jeroen Bartels
Thanx guys,
It's working!!
I can finally get this off my wish list (after 2 years)
**Jeroen**
