New Energy Saving Z-Wave Thermostat from Danfoss
Re: New Energy Saving Z-Wave Thermostat from Danfoss
The new Danfoss radiator thermostats are available.
Wall thermostaat from Danfoss is stil not available..I hope in may.
The Horstmann version is available.
Interesting News,
I am waiting a long time for these radiator thermostats, and the availability now gives me a complete summer to experiment with these devices.
Some questions from my side:
1) is the M30x1.5 version compatible with Heimeier. According to my information the heimeier has a 30mm nut, can I assume that the Danfoss fits?
2) and most important: Are these radiator thermostats supported by Homeseer?
Geert-Jan
Geert-Jan
I'm wondering if the EM6500 can control these thermostat's,...
M30 is not the Danfoss standard.
Danfoss use the RA system (Klik)
f0r 99% sure they will fit.
At the moment I'm using the previews version of the Danfoss thermostat. This is working wel in Homeseer.
With the new one you will get a extra device for setting the temperature in Homeseer.
Availability is delayed to end april...
I'm a bit surprised about the size.
It's almost the same size as the normal Danfoss version.
In the next days I will test this device and post a review online.
some pictures.
some pictures.
- danfoss-2.jpg (76.54 KiB) Viewed 8881 times
- Danfoss-1.jpg (105.92 KiB) Viewed 8881 times
older people would prefer the old ones because of better grip when manual operated.
** edwin **
Edwin, I thought that the idea was to do things remote and not touch it anymore
Enver, good News and for sure I will get some when I am back in Holland. Not sure I have the RA version everywhere.
Bad News:
Devices are not working well in Homeseer.
http://board.homeseer.com/showthread.ph ... ht=danfoss
Good News:
When it will work you will have good control.
Since the modules are detected by the Homeseer Thermostat plugin.
Good News:
This is great to see, I anticipated a much bulkier module.TANE wrote: It's almost the same size as the normal Danfoss version.
Not so great News about the Homeseer integration though. Let's hope that's fixed soon!
Erwin
HS3 Pro 3.0.0.298, W10 on Atom x5-Z8300
SqueezeBox, UltraM1G3, UltraMon3, Z-Wave
HS2 Pro 2.5.0.80, W2k3 on AMD X2
X10 CM11A/CM12U, SqueezeB, UltraMon, tenHsPower, UltraM1G, SqueezeBox
Shame it doesn't work out of the box as this would be a great addition to my setup.
Hopefully you/they will get it to work.
Where did you het one?
Nico - Domotica in de Betuwe
I'm sure it will work soon...since this a Homeseer probleem and not Danfossnico_gh2 wrote:Shame it doesn't work out of the box as this would be a great addition to my setup.
I hope we will not need any thermostaat in the next months.
"Where did you het one?" Shop?
