I've just pulled the latest trunk for domotiga, as you've put in experimental FS20 support via the CUL/CUN/CUNO.
I was able to defined my CUNO device, but under "Add Device" I can't select the CUNO device to connect to. How do I define a device?
Eager and willing to test.. my FS20 / FHT gear are ready for some bug-tracking
Jelle.
ELV FHT80b heating system.
Let me know what you prefer in debugging the workings of this newly added features.
I tried to add a lamp, but it came back with an interface error. Probably stating it can't find the CUL device?
2011/08/29 09:05:34 [Devices] Interface for device with name 'Zolderlamp' is '32'
2011/08/29 09:05:34 [Devices] Address for device with name 'Zolderlamp' is '51B730'
2011/08/29 09:05:34 [Devices] Unknown Interface 32 for device 'Zolderlamp'!
I've added an attachment with my added device in the overview.
I do get a positive connection with the CUL and it's showing wonderful messages of my FHT system. A few are missing though, but it could be malformed packets as well. the CUNO at some points does need a reboot .
when I switch the light manually, it does see it properly in the logfiles:
2011/08/29 09:09:03 [CUL] FS20 message received with address: 51B730 (221234241411) command: Dim 9
2011/08/29 09:09:03 [Devices] Interface with name 'CUL Interface' has id '32'
2011/08/29 09:09:03 [Devices] Device with address '51B730' is 'Zolderlamp'
2011/08/29 09:09:03 [Devices] Device with address '51B730' and 'Zolderlamp' is a new device
2011/08/29 09:09:03 [Devices] ValueUpdate() called for device with id '39' and name 'Zolderlamp'
2011/08/29 09:09:03 [Devices] Device change triggered for device with id '39' and value1 'Dim 9'
2011/08/29 09:09:05 [CUL] < F51B73000E3
2011/08/29 09:09:05 [CUL] FS20 message received with address: 51B730 (221234241411) command: Off
2011/08/29 09:09:05 [Devices] Interface with name 'CUL Interface' has id '32'
2011/08/29 09:09:05 [Devices] Device with address '51B730' is 'Zolderlamp'
2011/08/29 09:09:05 [Devices] ValueUpdate() called for device with id '39' and name 'Zolderlamp'
2011/08/29 09:09:05 [Devices] Device change triggered for device with id '39' and value1 'Off'
2011/08/29 09:09:06 [CUL] < F51B73011E2
2011/08/29 09:09:06 [CUL] FS20 message received with address: 51B730 (221234241411) command: Dim 9
2011/08/29 09:09:06 [Devices] Interface with name 'CUL Interface' has id '32'
2011/08/29 09:09:06 [Devices] Device with address '51B730' is 'Zolderlamp'
2011/08/29 09:09:06 [Devices] ValueUpdate() called for device with id '39' and name 'Zolderlamp'
2011/08/29 09:09:06 [Devices] Device change triggered for device with id '39' and value1 'Dim 9'
Trying to recreate the lamp device, or trying to switch it after having it manually switched doesn't make it work. I still get the same interface 32 error.
A small status update, to compliment Ron on his fantastic work in this project:
- FS20 signals are all being received and send to the various devices. This works quite well!
- FHT messages are being received at the moment, but not properly logged. Most messages are being decrypted very nicely.
I'd say this is a huge step. I'm hoping to see nice logging for FHT in the future. And perhaps even a way to send commands to set up the entire heating controls.
Jelle
