Individual Room Control ELV the MAX!
Moderator: jrkalf
Re: Individual Room Control ELV the MAX!
Postby Rene » Fri Nov 11, 2011 9:04 am
How do you control your kettle than? What is the reason you replaced the NT20E?
Postby Digit » Fri Nov 11, 2011 10:49 am
With the Evohome Evotouch. For now this is the only way. Another way to control it will be added; what exactly, hasn't been decided yet. It involves either a soldering iron or yet another thermostat... :wink:
The reason for replacing the NT20E is that modulation keeps the floor at a more constant temperature, which increases comfort a lot; enough to keep it at that (modulation).
Postby Digit » Thu Nov 17, 2011 9:45 pm
Postby blb » Thu Nov 17, 2011 11:06 pm
I have installed 1.3.2, nothing broken as far as I can see now ;-)
Bernard
blb
Postby Art » Wed Nov 30, 2011 5:44 pm
blb wrote:I haven't found a smartphone application yet.
An iPhone app appeared in the appstore yesterday. Only German language so far :-\
Art
Postby matthijskooijman » Fri Dec 02, 2011 9:48 pm
Did anyone try to find out how firmware upgrades in the Cube work? Perhaps even capture a firmware image during the upgrade process? I'd like to see if the firmware can be dissected, see what's inside.
matthijskooijman
Postby matthijskooijman » Fri Dec 02, 2011 10:08 pm
One addition to my last post: I pulled the MacOS application apart and there doesn't seem to be a firmware image in there (unless they hid it inside a java class file). My suspicion is that the application just always gets the latest firmware version from some webpage, downloads the image and sends it to the cube. That's why I talked about "capturing" the firmware image :-)
matthijskooijman
Postby lesender » Wed Dec 07, 2011 8:03 pm
Take a look in MaxSettings.jar - there is a file called "firmware.enc".
It is ASCII/Hex coded - means "0112..." is "0x01 0x12 ..."
The file is sent, while firmware upgrade (I sniffed ist with lan-sniffer). But Im afraid it is encrypted
lesender
Postby matthijskooijman » Wed Dec 07, 2011 11:16 pm
Hmm, I don't remember seeing the MaxSettings.jar file in the DMG file. Where did you find that MaxSettings.jar file (perhaps it was downloaded by the tool after upgrade)?. In any case, I'll take a closer look next week.
matthijskooijman
Postby lesender » Thu Dec 08, 2011 9:13 pm
C:\Program Files\MAX\lib\MaxSettings.jar
lesender
Postby Snelvuur » Thu Dec 29, 2011 11:47 pm
So i got the homeseer scripts up and running, besides a few things that i thing should be the other way around it still displays an error with "System date & Time" but i can control them.
But i do have a question about the devices itself, i've set them to 20 degrees to go on at a certain time but it just keeps the radiator turned on.. should it not detect 20 degrees and stop heating? If i turn it to 17 degrees then it stops with heating so it does know how far out the pin needs to be. Am i missing something?
Snelvuur
Postby Digit » Fri Dec 30, 2011 12:19 am
Maybe it isn't 20 degrees there where the Radiator Thermostat is? Temperature at floor level is lower than 1.50m above the floor, for example. So it is possible that the thermostat measures a different temp.
For that, you can adjust an "offset" for each Radiator Thermostat individually.
Postby Snelvuur » Fri Dec 30, 2011 9:57 am
Need to tweak it then a little, its too warm.. the thermostat are at mid level so it should be fine. I actually closed a room and it was really like walking into a brick wall of heat (so its not like it cannot sense it) :P
Snelvuur
Postby Snelvuur » Sun Jan 01, 2012 7:38 pm
So digit, what is your offset? Since i really thinks its too big here :P if i put them at 18.5 degrees they stop heating.. with a offset of 1. Normally its around 20 to 21 in my eyes.
Snelvuur
Postby Digit » Sun Jan 01, 2012 8:06 pm
Mine are all 0.
PreviousNext
Return to Homematic, FS20, FHT, ESA and ELV
cron
