File monitor script
File monitor script
File monitoring script v1.4
Mogelijke opties
- Toon totaal aantal files.
- Files tonen in detail.
- Verschillende wegen ID in de gaten houden.
- Verschillende wegen per device.
- Meerdere wegen per device.
- Mogelijkheid to speech vb. In een event speak "File melding. $$DS:<DeviceCode>"
- Events zetten op de devices met files meldingen.
- Device value en status worden geupdate.
- HTML bestandjes per opgegeven weg genereren.
UPDATE:
De laatste versie is 1.4
Bug fix :
- Hersteld typefout
Bij de optie meerdere devices werd de waarde van het device niet aangepast
'AZ_FileInfo.vb
'by A.A. van Zoelen
' Version
' 1.0   - 12 jan 2012 (first release)
' 1.1   - 18 jan 2012 Bug fix
'         Count in string selection was occassionally negative.
' 1.2   - 25 apr 2012 Bug fix
'	  String handling improved
'         New URL added
' 1.3   - Added option for HSTouch text object view
'         Removed parsing bug
'1.4  - 4 Sept 2012 Bug fix
'         Corrected a typo that prevented device value updates
'USAGE with HomeSeer
'Make an event and select script.
'For the parameter field use ("Main","W40;Y;N;A16 N11 A12 A13")
'where: ("Main","<DeviceCode>,<MultiDevices>,<DetailLevel>,<Route id(s)> ")
'Main with a capital M
' <DeviceCode> vb.W40 - is the device code to use as first device
' <MultiDevices> vb. Y - Y(es) or N(o)
'     When N then file information is placed in just 1 device.
'     When Y then for each road ID given there will be made
'     a device holding the relevant information.
'     Note: In this example 4 devices will be created
'           starting from W40 and then W41, W42, W43
' <DetailLevel> vb. Y - Y(es) or N(o)
'     When N only the file count on the road ID is shown
'     When Y also the detailed info will be shown.
' <Road ID(s)> vb. A28 A12 N11
'     A list with road id's that you want information from.
'     Each road ID is seperated with a space from the other
'     Leaving this empty will give you every file
'REMARKS
'I may be nessecary to throw away old devices when you
'update your road id list.
'This script is optimized for http://www.verkeerplaza.nl/filelijst
'And most likely won't work for an other source.
sub Main(byVal params As Object)
' These variable must be set first
  'Write debug info to the HS log file.
  'The logging is very intensive!
  'true or false
  Dim Debug as boolean
  Debug = false
  'If you have trouble displaying data in a text field
  'on a HSTouch device then set this to true. For each
  'road there will be a html file created in the given
  'folder so you can include that as source for the
  'text object in the HSTouch designer.
  'Remark: Fill in the URL to this file in the
  '        property called Text.
  Dim IsHsTouch as boolean
  Dim InfoFolder as String
  IsHsTouch = true
  InfoFolder = "c:/Program Files/HomeSeer HSPRO/html/AZTools/"
  'The full URL to the page where the data is
  'USE FORWARD SLASHES AS IN //
  Dim strURL as String
  strURL = "http://www.verkeerplaza.nl/filelijst"
' The next few variables might be alter if needed
  'The tag for the Road list block
  Dim strRoadListTag as String
  strRoadListTag = "list-road"
  Dim strRoadListEndTag as String
  strRoadListEndTag = "</div>"
  ' Use these values to create new device(s)
  Dim strDeviceRoom As String = "Monitoring"
  Dim strDeviceType As String = "Verkeer Monitoring"
  Dim strDeviceFloor As String = "Systeem"
'Below this there is no real need for altering anything
  Dim strSite          as String
  Dim strPath          as String
  Dim strWebPage       as String
  Dim intTemp          as Integer
  Dim strTemp          as String
  Dim strOutput        as String
  Dim intNumberOfRoads as Integer
  Dim i                as Integer
  Dim count            as Integer
  Dim CalcLenght       as Integer
  Dim strRoads          ' String array
  Dim strDevice As String = hs.StringItem(Params, 1, ";")
  Dim strHouseCode As String = GetChar(strDevice,1)
  Dim strDeviceCode As String = strDevice.subString(1)
  Dim blMultiDevices As Boolean = hs.StringItem(Params, 2, ";") = "Y"
  Dim blDetailedInfo As Boolean = hs.StringItem(Params, 3, ";") = "Y"
  Dim strRoadList as String = hs.StringItem(Params, 4, ";")
  If Debug = true Then
	hs.writelog("AZ_FileInfo","strDevice :" & strDevice & ":" )
	hs.writelog("AZ_FileInfo","blMultiDevices :" & blMultiDevices.ToString & ":" )
	hs.writelog("AZ_FileInfo","blDetailedInfo :" & blDetailedInfo.ToString & ":" )
	hs.writelog("AZ_FileInfo","strRoadList :" & strRoadList & ":" )
  End If
  ' If there are roads then split
  ' them into an array
  strRoads = Split(strRoadList," ")
  intNumberOfRoads = UBound(strRoads)
  If Debug = true Then hs.writelog("AZ_FileInfo","Number of roads :" & intNumberOfRoads + 1)
  'First do some checks
  'Is the device and house code oke
  If not ((Val(strDeviceCode)>=1) And (Val(strDeviceCode)<=128)) Then
        hs.WriteLog("AZ_FileInfo", "Ongeldige DeviceCode!")
        Exit Sub
  End If
  If not (strHouseCode <> "") Then
        hs.WriteLog("AZ_FileInfo", "Ongeldige HouseCode!")
        Exit Sub
  End If
  'Are the devices(s) available
  If blMultiDevices Then
        For i = 0 To intNumberOfRoads
           If Debug = true Then hs.writelog("AZ_FileInfo","Road(" & i & ") = " & strRoads(i))
           If hs.DeviceExistsRef(strHouseCode & Val(strDeviceCode)+i) = -1 Then
              Dim dv As Object
              dv = hs.GetDeviceByRef(hs.NewDeviceRef("File(s)" & " op " & strRoads(i)))
              dv.hc = strHouseCode
              dv.dc = Val(strDeviceCode)+i
              dv.misc = "&h10"
              dv.location = strDeviceRoom
              dv.location2 = strDeviceFloor
           End If
        Next
   Else
        If hs.DeviceExistsRef(strHouseCode & strDeviceCode) = -1 Then
           Dim dv As Object
           dv = hs.GetDeviceByRef(hs.NewDeviceRef("File(s)"))
           dv.dc = strDeviceCode
           dv.misc = "&h10"
        End If
   End If
  'Get Address and path of the URL
  strTemp = Replace(UCase(strURL), "HTTP://", "")
  intTemp = Instr(strTemp, "/")
  strSite = "http://" & Left(strTemp, intTemp - 1)
  strPath = Right(strTemp, Len(strTemp) - intTemp + 1)
  If Debug = true then
	hs.writelog("AZ_FileInfo","Site found :" & strSite )
	hs.writelog("AZ_FileInfo","Path found :" & strPath )
  End If
  'Try to get the website data
  Try
    strWebPage = hs.GetURL(strSite, strPath, false, 80)
    If Len(strWebPage) < 100 Then
	hs.SetDeviceString(strDevice, "Website " & strURL & " down", True)
	hs.SetDeviceStatus(strDevice, 17)
	hs.writelog ("AZ_FileInfo","No data found at " & strURL):exit sub
    End If
  Catch ex As Exception
    hs.writelog("AZ_FileInfo","Connection to site failed due:" & ex.Message )
    Exit Sub
  End Try
  If Debug = true Then hs.writelog("AZ_FileInfo","Byte(s) found :" & len(strWebPage) )
  'Now we have the complete webpage
  'loaded into a string we can
  'search for the road list block
  'and drop all data infront
  'and after the block.
  'Occassionally there is a negative string lenght which
  'obviously isn't possible to caught this calculate the
  'lenght first and make sure that it's => 0
  CalcLenght = Len(strWebPage) - InStr(strWebPage, strRoadListTag) + 1
  If CalcLenght < 0 Then CalcLenght = 0
  strWebPage = "<ul class=" & Right(strWebPage, CalcLenght )
  CalcLenght = InStr(strWebPage, strRoadListEndTag ) - 1
  strWebPage = Left(strWebPage, CalcLenght)
  'We have the data block.
  'If the user wants this be split
  'to seperate roads then do it
  'here otherwise place all file
  'information into one device.
    'Multiple devices
    i = 0
    Do
      If intNumberOfRoads > 0 Then
        strTemp = FindRoadNumberBlock(strWebPage, strRoads(i), Debug)
      Else
        strTemp = strWebPage
      End If
      count = CountOccurrences(strTemp, "locatie" , false, Debug)
      If strRoads(i) <> "" Then
        strOutput = strRoads(i)
      Else
        strOutput = "Geheel NL"
      End If
      strOutput = strOutput & " - Totaal " & count & " files" & vbCrLf
      If blDetailedInfo then strOutput = strOutput & strTemp
      If IsHsTouch = true Then WriteRoadToFile(strOutput, InfoFolder, debug)
      hs.SetDeviceString(strHouseCode & Val(strDeviceCode + i), strOutput, true)
      hs.SetDeviceValue(strHouseCode & Val(strDeviceCode + i), count)
      If Debug = true Then hs.writelog("AZ_FileInfo","Number of traffic jams(s) on " & strRoads(i) & ":" & count )
      i = i + 1
    Loop until i > intNumberOfRoads
  Else
    'One device to hold all
    i = CountOccurrences(strWebPage, "locatie" , false, Debug)
    hs.SetDeviceValue(strHouseCode & Val(strDeviceCode), i)
    strOutput = "Geheel NL - Totaal " & i & " files"
    If blDetailedInfo then strOutput = strOutput & strWebPage
    hs.SetDeviceString(strHouseCode & Val(strDeviceCode), strOutput, true)
    If Debug = true Then hs.writelog("AZ_FileInfo","Number of traffic jams(s) :" & i )
  End If
End sub
'==          Functions and SUBS           ==
Function FindRoadNumberBlock(strWebPage, Road, Debug)
  Dim strWegData as String
'  If Debug = true Then hs.writelog("AZ_FileInfo","FindRoadNumberBlock:Start function=" & strWebPage )
  'Find start op road information
  count = Instr(strWebPage, Road & "</li>")
  If Debug = true Then hs.writelog("AZ_FileInfo","FindRoadNumberBlock:Search for = " & Road )
  If Debug = true Then hs.writelog("AZ_FileInfo","FindRoadNumberBlock:Found at " & count )
  'The requested road is found
  if count > 0 then
    'Drop the first part incl. the </li>
    CalcLenght = Len(strWebPage) - (count + len(Road) + Len("</li>") )
    strWegData = "<ul><ul>" & Right(strWebPage, CalcLenght)
    If Debug = true Then hs.writelog("AZ_FileInfo","FindRoadNumberBlock:Right string=" & strWegData )
    'Now find the end of this block
    count = Instr(strWegData, "wegnummer")
    'Drop the last part
    count = count - Len("<li class=") - 2
    If count < 0 Then count = 0
    strWegData = Left(strWegData, count )
    If Debug = true Then hs.writelog("AZ_FileInfo","FindRoadNumberBlock:After left string=" & strWegData )
    'Close a few tags to prevent unwanted
    'generation of html code
    strWegData = strWegData & "</ul></ul>"
    If Debug = true Then hs.writelog("AZ_FileInfo","FindRoadNumberBlock:ReturnString=" & strWegData )
  End If
  return strWegData
End Function
'function takes three parameters.
'The first is the string to be searched through.
'The second is the string to search for.
'The third is a Boolean that determines if the search
' should be case sensitive.
'The function returns the count of occurrences
Function CountOccurrences(p_strStringToCheck, p_strSubString, p_boolCaseSensitive, Debug)
     Dim arrstrTemp
     Dim strBase, strToFind
     If Debug = true Then hs.writelog("AZ_FileInfo","Start Count Occurences" )
     If p_boolCaseSensitive Then
         strBase = p_strStringToCheck
         strToFind = p_strSubString
     Else
         strBase = LCase(p_strStringToCheck)
         strToFind = LCase(p_strSubString)
     End If
     arrstrTemp = Split(strBase, strToFind)
     CountOccurrences = UBound(arrstrTemp)
     If Debug = true Then hs.writelog("AZ_FileInfo","End Count Occurences : Count = " & CountOccurrences )
End Function
' Write the info as a HTML file to disk so
' you can show it in a textbox on a HSTouch device
Sub WriteRoadToFile(strOutput, InfoFolder, Debug)
   Dim RoadNo as String
   RoadNo = Left(strOutput, Instr(strOutput, " ") - 1)
   strOutput = "<HTML><BODY>" & strOutput & "</BODY></HTML>"
   My.Computer.FileSystem.WriteAllText(InfoFolder & RoadNo.ToString & ".htm", strOutput.ToString & ControlChars.CrLf, False)
   If debug = true then hs.writelog("AZ_FileInfo", "WriteRoadToFile start - " & strOutput)
End Sub
Wim2008
Re: File monitor script
Post by Wim2008 »
Hallo Bram,
Omdat ik zeer nieuwsgierig was, heb ik het script direct gedownload en in een event geplaatst. Als je het event 1x laten lopen worden er keurig 4 wegen vermeldt, natuurlijk nu zonder file. Maar dat zal nog wel veranderen.
Ik ga alle andere opties ook eens proberen. Hartelijk dank voor je advies en mooi opgezette script voor de file melding.
Hieronder nog 1 kopie van het resultaat als het script 1x gelopen heeft.
Mvgr Wim :) :wink:
Bedankt Win.
Ik heb heb het voor mezelf gemaakt maar als ik er anderen ook een plezier me kan doen waarom dan niet. :-)
DJF3
Post by DJF3 »
Dag AshaiRey,
Ben nieuwschierig. Kwam er vrij kort geleden achter dat m'n script niet meer werkte. Heb door nieuwe projecten erg weinig tijd om 'm te updaten.
Jouw script ziet er goed uit en ik zal het ook testen.
Als 't werkt dan zal ik ook een verwijzing zetten op mijn website.
Groeten!
DJ
Esteban
Post by Esteban »
Bedankt voor het delen, ik heb het hier ook even ge-installed, tot dusver geen problemen te melden.
esschenk
Post by esschenk »
Hallo,
Ik heb dit Script ook geinstalleerd en het werkt perfect
zo zijn we weer klaar om naar de Camping te rijden zonder file.
Thanks
ed
Herbus
Post by Herbus »
Bedankt voor dit super handige script. Ik loop tegen twee dingetjes aan:
Ik heb als commando ingesteld: AZ_FileInfo.vb("Main","V1;Y;Y;A1 A27") en krijg dan de foutmelding:
17-1-2012 19:31:18 - Error - Scripting runtime error: System.Reflection.TargetInvocationException: Het doel van een aanroep heeft een uitzondering veroorzaakt. ---> System.ArgumentException: Argument Length moet groter dan of gelijk zijn aan nul. bij Microsoft.VisualBasic.Strings.Left(String str, Int32 Length) bij scriptcode9.scriptcode9.FindRoadNumberBlock(Object strWebPage, Object Road, Object Debug) bij scriptcode9.scriptcode9.Main(Object params) --- Einde van intern uitzonderingsstackpad --- bij System.RuntimeMethodHandle._InvokeMethodFast(Object target, Object[] arguments, SignatureStruct& sig, MethodAttributes methodAttributes, RuntimeTypeHandle typeOwner) bij System.RuntimeMethodHandle.InvokeMethodFast(Object target, Object[] arguments, Signature sig, MethodAttributes methodAttributes, RuntimeTypeHandle typeOwner) bij System.Reflection.RuntimeMethodInfo.Invoke(Object obj, BindingFlags invokeAttr, Binder binder, Object[] parameters, CultureInfo culture, Boolean skipVisibilityChecks) bij System.Reflection.RuntimeMethodInfo.Invoke(Object obj, BindingFlags invokeAttr, Binder binder, Object[] parameters, CultureInfo culture) bij System.Reflection.MethodBase.Invoke(Object obj, Object[] parameters) bij Scheduler.VsaScriptHost.Invoke(String ModuleName, String MethodName, Object[] Arguments)
Zie ook het bijgevoegde log en printscreen van de website.
Neem ik AZ_FileInfo.vb("Main","V1;Y;Y;A1 A12") dan wordt alles wel goed gevuld. Hij struikelt dus over de laatste file.
Ik ging er vanuit (kan er naast zitten....) dat de value van de device gevuld wordt met het aantal files. Dat doet hij bij het tweede device wel, maar het eerste blijft op nul staan.
Nogmaals dank voor het delen van je werk!
log en source.rar
(117.5 KiB) Downloaded 894 times
Herbus (Jos)
Hoi Jos,
Bedankt voor de log en info.
Ik zal er vanavond naar kijken. Ik zie al wel wat het probleem is maar kan nog niet zien waar en waarom het zich voordoet.
Groeten,
DJF3
Post by DJF3 »
I also see the following error quite regularly (multiple times per day)
Scripting runtime error: System.Reflection.TargetInvocationException: Exception has been thrown by the target of an invocation. ---> System.ArgumentException: Argument 'Length' must be greater or equal to zero. at Microsoft.VisualBasic.Strings.Left(String str, Int32 Length) at scriptcode16.scriptcode16.FindRoadNumberBlock(Object strWebPage, Object Road, Object Debug) at scriptcode16.scriptcode16.Main(Object params) --- End of inner exception stack trace --- at System.RuntimeMethodHandle._InvokeMethodFast(Object target, Object[] arguments, SignatureStruct& sig, MethodAttributes methodAttributes, RuntimeTypeHandle typeOwner) at System.RuntimeMethodHandle.InvokeMethodFast(Object target, Object[] arguments, Signature sig, MethodAttributes methodAttributes, RuntimeTypeHandle typeOwner) at System.Reflection.RuntimeMethodInfo.Invoke(Object obj, BindingFlags invokeAttr, Binder binder, Object[] parameters, CultureInfo culture, Boolean skipVisibilityChecks) at System.Reflection.RuntimeMethodInfo.Invoke(Object obj, BindingFlags invokeAttr, Binder binder, Object[] parameters, CultureInfo culture) at System.Reflection.MethodBase.Invoke(Object obj, Object[] parameters) at Scheduler.VsaScriptHost.Invoke(String ModuleName, String MethodName, Object[] Arguments)
Parameters: AZ_FileInfo.vb("Main","V15;Y;Y;A4 A16 A2")
Version: 1.0
There is already for a few day an update available.
' Version
The first message of this thread has the latest version in it.
DJF3
Post by DJF3 »
Thank you!
Had de update gemist.
DJ
Wim2008
Post by Wim2008 »
Bedankt voor de nieuwere versie. Had over het nieuwe script heen gekeken.
Mvgr Wim :)
Mocht er nog problemen voor doen dan staat versie 1.2 in de eerste post. Zo niet dan is er geen noodzaak om te updaten.
Deze gebruikt ook een andere url (de oude staat ook nog in het script)
Wim2008
Post by Wim2008 »
Bedankt weer. Wat is het verschil tussen de vorige versie en de nieuwere?
Groetjes Wim :)
Weinig. Ik heb wat extra checks erin gezet bij string lengte bepaling. Ik stond namelijk eerst op het verkeerde been door heel wispelturige error meldingen in mijn log en dacht eerst dat het door dit script veroorzaakt werd. Bleek later het poollicht script te zijn :-)
