CV control / Opentherm gateway with iPhone app
Re: CV control / Opentherm gateway with iPhone app
Very interesting product! If you will provide an Android app or some kind of HTTP command for the settings of the gateway controller, count me in!
** Maurice **
I'm interested.
I would very much like to see your design, as I've been sketching something similar a while ago, but never got to building anything.
If you're going to produce and sell a module, I'm probably interested in buying one too, depends on the direction you took.
I'm also very much interested!
With or without OpenTherm. (rather ironic name actually
Count me please. I've also an iSense OT v3 system.
Is it also possible to integrate it with Homeseer?
There are some people who can fix that you know
- Starting Member
Yep definitely interested. Keep me in the pipeline.
Are you going to show us something? Or just words ...
Wijnand
Wijnand
I would also be very interested in this if it would work with my Daalderop (I suppose it does, because i use a standard "Honeywell Chronotherm Modulation") .
Can i Place this product between the Central Heater and the Thermostat?
Best regards,
Wilco
Best regards,
Wilco
What is the status for this complete project at the moment?The hardware will be a professional designed and produced PCB, the iPhone app will be available in the iTunes store within a few months begin of March 2012 would be realistic.
L.s,
Just a brief update, see picture.
E.e.a. works satisfactorily for some time. To a small series to make me some options to scan, but do have applications yet not really enough.
Few notes: Food and firmware update via USB port. The RJ10 connector is used for an external temperature sensor, the heating temperature so that any measurement. a weather-dependent control can be applied.
Furthermore, a UTP connection, a connection for the CV (OpenTherm and on / off) and a thermostat connection (OpenTherm and on / off).
google translated to english
- Hand build pcb
- pcb_pic.jpg (232.07 KiB) Viewed 12023 times
Yep, count me in.
<strike-through>Also interested if this would work with an Intergas Kombi Kompact HR heater</strike-through>
Not right now.. To many projects
DJ
DJ
Me thinks that on/off will work just fine with any on/off capable boiler.
Yes I'm very interested as well!
Kind Regards,
Greg.
Greg.
