New Source 2.22 version available for beta users.
T-Rex
Re: New Source 2.22 version available for beta users.
Post by T-Rex »
After installing Source 2.22 beta (20120404.2) 15 minutes ago I constantly get two windows popping up, "Schedules" and "HTTP". Looks like debugging information? See attachment.
Reinder
Post by Reinder »
I noticed this also yesterday morning.
I will check what/why this is.
Btw: happy easter :)
I know what it is; it's very obvious that this is the HTTP response from the server to which the data is being uploaded.
T-Rex
Post by T-Rex »
The "Schedules" and "HTTP" windows don't appear anymore in Source 2.22 beta (20120409.1). :)
T-Rex
Post by T-Rex »
In the latest version of Source you can also export the sense data. This is very good, I like this addition!
One question about this. I export the data of the plugs and senses and use Excel to analyse it. The more plugs and senses I get, the more work it is to manually export all this data. Is there any way to export data automatically, let's say every hour or every day?
T-Rex
Post by T-Rex »
Did something change regarding the Source-update? Until three updates ago there were no problems. However, the last two bèta updates were interrupted by Norton (the SONAR part) and the source-update-executable was deleted because Norton thought it's behavior was suspicious. Did other people also see this?
WHB
Post by WHB »
Oh well, avast! virus scanner thinks the beta files are potential threats since they are "uncommon". :lol:
But with the latest 2.22 beta (20120504) I have a problem that the Source no longer detects the Stick.
Already tried reinstalling drivers and rerunning the configuration program. But it just no longer detects the Stick.
I run it 24/7 on a VIA Eden thin client with only 2GB of flash storage. Since space is an issue in my setup I only meet the bare minimum software requirements with a stripped down WinXP SP3 and .NET Framework 2.0 SP1.
Reverted back to 2.22 beta 20120323.4 that has no issues with my setup.
Anyone else having this problem?
Reinder
Post by Reinder »
The final beta (latest release candidate) is released now.
Plugwise Source 2.22 beta 20120604 (RC5)
Please report any bugs to
helpdesk@plugwise.com
Include the version number of your Source application in your report.
You can find it in the bottom right of the blue title bar.
Changes:
- PTE: Up to 80% faster handling of arrays and array elements
- PTE: See PDF for new features
Fixed
#3140 Week graph shows all 52 weeks for current year
Known issues:
- Plugwise Smile-P1 is not yet supported
- French translations not complete and outdated
Plugwise Source 2.22 beta 20120521 (RC4)
Changes:
- Updated PTE documentation.
- PTE: on a script of runtime error in a function, a more informative trace back is written.
Fixed
#3139 PTE: Arrays operators like + and - have same effect as their compound versions += resp. -=
#3125 ConfigWizard: Manually added module ids, disappear and reappear again
#3137 Reports: Scrolling and zooming the graph with mouse wheel, does not refresh graph
Plugwise Source 2.22 beta 20120504
Changes:
- New WHQL certified driver for Stick
Fixed
#3120 Changes made just before backup are not stored in backup
#3109 Manually entering SLP settings does not work
Plugwise Source 2.22 beta 20120427
Changes:
- Japanese translation update
Fixed
#3107 ConfigWizard: Crash when entering module ID
#3103 ConfigWizard: "Invalid email address" message on correct email address
Plugwise Source 2.22 beta 20120424
Changes:
- Export: production columns are always exported
- PTE: Rounding method changed to 'Nearest' (0.5-->1) instead of .NET's default 'Bankers' (0.5-->0)
Fixed
#3102 Reports: Graph not correct when using bidirectional meter with production
#3101 Export: No production for bidirectional meters
#3100 Crash at startup: 'Invalid characters'
Plugwise Source 2.22 beta 20120419
Changes:
- Export: Sense and Scan data can be exported to CSV
- Export: CSV uses Windows' default field separator. Can be overruled in Settings->Program
- Settings: Current Windows' currency is always added in currency selection list
Fixed
#3087 Reports: Comparison graphs not correct
#3078 Rooms: Creating new and then canceling still creates room
#3077 Reports: Sense and Scan graphs cannot be copied to clipboard
#3064 Tariffs: Newly added tariff, cannot be used until Source is restarted
#2969 ConfigWizard: Hang or crash on network with 40 or more modules
- Some (potential) crashes
Plugwise Source 2.22 beta 20120412
Changes:
- Modbus: Presets are read-only.
Fixed
#3068 Reports: Graph of multiple submeters, ignores 'Skip in totals' flag
#3063 Settings->Program: Feature list is continuously refreshing
- Some crashes, especially when language is set to Japanese
Plugwise Source 2.22 beta 20120409
Changes:
- Updated German translation
Fixed
#3054 Deleting a switching group does not release trigger until refresh
#3050 Comparison graphs is empty when selecting a room
#3049 PTE: Production is added to usage
#3032 Newly created group not shown
#3029 Listviews show random icon changes during the first minutes after Source has started
#3023 New appliances do not show up in Reports, unless refresh button is clicked.
#3013 Changes in appliance type not visible unless refresh button is clicked
#3010 ModuleWizard: Newly added module gets skipped in configuration page.
#2987 P1: Total produced power value not correct.
#2935 Windows XP: High peak in memory usage at start up.
Plugwise Source 2.22 beta 20120404
New:
- Pro: SLP configuration, automatic and manual. Adding port in settings.ini is no longer required.
- Pro: Modbus. Read out separate phases even when multi-phase meters are defined.
Changes:
- Pro: New Modbus meter wizard. meters and gateways are stored in db, not in xml.
- Updated Dutch manual.
Fixed
- several crashes
#3042 Reports: Graph shows only power production or only consumption
#3029 Appliances: Icons change several times the first minutes Source is running.
#3028 ConfigWiz: 'Stick found' message, but Circle+ ID box remains disabled.
#3016 Reports: Comparison graph not correct
Known issues:
Plugwise Source 2.22 beta 20120322
New:
- Reports: Right click on graph to copy image to Windows clipboard
Changes:
- Updated German en Greek translations
- Several textual changes
Fixed
- several crashes
#3000 Add Module: manually entered module ID disappears from list
#2993 Modbus: Adding new meter requires restart of Source
Plugwise Source 2.22 beta 20120317
New:
- Reports: Change period with scroll wheel: Left+Wheel = expand/shrink period, Right+Wheel = move period
- Groups and rooms can be duplicated
Fixed
#2975 MeterWizard: Add meter causes crash
#2973 Group settings: Triggers are not listed
#2967 Sense settings: Advanced settings is gone
#2965 ModuleWizard: Module list is empty
#2952 Update button results in server error message
#2855 Sense: Modules only switch on Sense broadcast if Source is running
Plugwise Source 2.22 beta 20120312
New:
- Support for climate and movement graphs in web server
Fixed
#2963 Reports: Production from main meter shifted to start of day on timeline
#2958 Reports: Production not visible
#2949 Reports: Gas usage shown as production
#2945 Crash when opening Sense properties
Plugwise Source 2.22 beta 20120301
New:
- Comparison graph in Reports screen
- Combine 2 or more meters to 1 merged (virtual) meter
- Pro: SLP auto discovery (if supported by SLP)
- Pro: SLP configuration settings, no need for INI file
- Pro: Meter wizard for ModBus devices
Changes:
- Central meters and submeters have separate branches in Reports screen
- Use of terms 'meter' and 'sensor' instead of general term 'module'
- Separate icons for Stealth(+), Circle(+) UK and Circles US(+)
Fixed
#2939 Pro: Merged modules are lost in import
#2931 Translator program does not start
#2930 Reports: From date higher than Until date causes crash
#2928 Backup misses .PLU extension
#2923 Wrong titles in comparison graph
#2917 ConfigWizard: Crash on last page when PC is offline
#2916 MeterWizard: Adding new meter type causes crash
#2915 MeterWizard: Test uses error box for success message
#2914 Stealth is named Circle in module list
#2907 Pro: Merge item in context menu is disabled
#2905 Check marking 'No personal data' pops up error message
#2900 No graph when period starts and ends in same month
#2854 Using decimals in Sense boundaries cause crash
#2833 Context menu not working in schedule list
#2821 Multiple 'Usage' titles in graph
#2777 Pro: Import ignores SED locations
Verkenner
Post by Verkenner »
Hold on.
Today Plugwise Source updated to 2.22beta Release 20120604.1
But after installing the new Plugwise release many errors in the homeseer-logging appear.
5-6-2012 18:44:10 Plugwise ERROR: Cannot query http://localhost:8080/statistics.xml: Naam kan niet beginnen met het teken %, hexadecimale waarde 0x25. Regel 5, positie 112.
The new Plugwise-release gives problems with the webserver. Plugwise made changes in the webserver, so (in Homeseer) the Plugwise-plugin does not work anymore.
Best regards, Verkenner
Same probleem here. Homeseer connection is lost.
Hope Rene or plugwise will fix this soon.
Webserver is working fine here.
A quick fix of what looks like a bug in de Plugwise template engine is to delete the line starting with <datetime> and ending with </datetime> from the statistics.xml file in the Plugwise www directory. According to the documentation the functions System.Date and System.Time should still exist but they throw an error.
Edit: The complete System object seems to no longer exist, while the documentation still describes it.
Thank you.
It's working again
I also have the problem the source can no longer find the stick as reported earlier in this topic. Did somebody solve this problem?
Verkenner
Post by Verkenner »
Thanks a lot Rene.
It's working again, YES !!!
Verkenner
Post by Verkenner »
Problem: Sometimes source no longer detects the Stick. Error in WIN7.
Solution: Plugwise-helpdesk recognized the problem and installed a new (USB) driver.
Problem gone. (Sorry I could not find the driver anymore).
Return to “Plugwise Forum”
