this page is based on the"neerslag monitor script " in thread domoticaforum.eu/viewtopic.php?f=47& ... 066#p60982
the info from gps buienradar is captured by homeseer.
put the aspx page in the html folder of homeseer put the dll file in the html/bin dir of homeseer
you can retreive the file with homeseer as server with
''http://10.10.10.2:7845/BuienRadarHs.asp ... 10.10.10.2''
''http://yourhsip:yourhsport/BuienRadarHs.aspx?lat=yourlatitude&lon=yourlongitude&hs=yourhomeseerip''
10.10.10.2 = homseercomputer ip
7885 your homeseer port
fill in your own latitude and longitude and hs ip and port
you can also run it from iis on the same or other computer
BuienRadarRain Monitor ASPX Page for HomeSeer
Moderator: Ruud
- BuienRadarGps.zip
- dll en aspx file
- (8.3 KiB) Downloaded 525 times
- Member
Re: BuienRadarRain Monitor ASPX Page for HomeSeer
Labium,
The attachment doesn't work anymore!
Kees
Kees
the other 6 downloaders have the same experience ?, i will look in to it tonight.
Labium,
You don't have to.
It's something forum maintenance related.
You don't have to.
- Member
The selected attachment does not exist anymore. That's the message I get.
Sorry I wasn't clear, the file doesn't exist for download. But Robert also react I see.
i will try to load it up tonight , dutch time. the forum gave a lot of errors yesterday indeed.
labium
labium
i have uploaded zip faile again in first post, it should work now.
- Member
Thanks it works! Now see what the results are when there's rain in forecast.
Kees
Kees
