Not licensed for extended scripting
Re: Not licensed for extended scripting
Postby Darwusch » Mon Jun 24, 2013 2:29 pm
Please read the posts about this earlier in this thread.
Darwusch
Darwusch
Postby renen » Mon Jun 24, 2013 8:00 pm
Hi Darwush,
Could you please provide me with the details as well ?
thx in advance.
renen
Postby viper1705 » Tue Jun 25, 2013 1:56 pm
Darwusch wrote:Hi,
Darwusch
thanx Darwusch, works perfectly now.
viper1705
Postby JoopK » Tue Jun 25, 2013 6:01 pm
4 me 2? :D
JoopK
Postby RdP » Sun Jun 30, 2013 12:23 pm
For the plugwise plug-in, I like to investigate if extended scripting can be of any use.
So please sent me the details as well....
Many thanks in advance,
RdP
Postby JoopK » Sun Jul 28, 2013 8:23 pm
@Darwusch, can you pm me the details?
JoopK
Postby 123unlock » Tue Aug 13, 2013 2:47 pm
for testing source version v2.23.130601 and the .2 edition you can change 0x0187D value 06 to 17
in the webserver files you also need to change the appliancestable.pte and appliancetypestable.pte
search for Plugwise.FeatureFlags.ContainsValue .. and change that value from V to W then it should work ok
price for extended scripting is only 20 euro.. so better buy activation :wink:
Xtrusion Digital Home Automation Project
123unlock
Postby JoopK » Tue Aug 13, 2013 2:53 pm
I ordered it via a request on the plugwise website more than a month ago, but never received an reply...
In the html files I removed coding for not extended scripting (The always disply zero part). It works very fine!
JoopK
Postby jellepie » Thu Sep 19, 2013 6:19 pm
I installed version 2.23 20130901.2 from the website without checking here first if extended scripting would be possible...
Could you provide me with the HEX location and values that need to be changed if possible? Thanks!
jellepie
Postby Darwusch » Sat Sep 21, 2013 4:41 pm
jellepie wrote:I installed version 2.23 20130901.2 from the website without checking here first if extended scripting would be possible...
It is at address 27C9
Change 06 to 17
Darwusch
Postby jellepie » Wed Sep 25, 2013 8:58 pm
Thanks a lot Darwusch, it works like charm!
jellepie
Postby Waterman67 » Sat Oct 26, 2013 1:35 pm
Hello Plugwise source updated to version 2.23(20130301.5) :?
Darwusch the hex location has changed can you help me out. Thanks
Waterman67
Postby Darwusch » Sat Oct 26, 2013 8:33 pm
That looks like an older version number.
Darwusch
Postby Waterman67 » Sat Oct 26, 2013 11:17 pm
Oeps sorry think you are right.
Should i look at adress 0x0187D.?
Waterman67
Postby RdP » Sat Oct 26, 2013 11:27 pm
Darwusch wrote:That looks like an older version number.
It is !!
Download the latest from the Plugwise website...
RdP
PreviousNext
Return to Plugwise Forum
Users browsing this forum: Majestic-12 [Bot] and 1 guest
