water switch
Forum about Click On Click Off (KAKU), Home Easy and related hardware.
no1san
water switch
Post by no1san »
I want to use Click On Click Off swicth water on/ off.
Anyone found a electric water switch ?
Thanks n advance,
Sander
Re: water switch
no1san wrote:Hi,
Thanks n advance,
Sander
Yes
raymonvdm
Re: water switch
Post by raymonvdm »
The do exist and you can even pull one from an old washing machine or dishwasher.
I don`t know the exact name for it but this is what is found so far
http://www.dugoshop.nl/Hydra-GuardAfsluiter_detail.htm
http://www.akatherm.nl/nl/cat/industrie ... ch/s+t+g+c
Re: water switch
I think he may want something like this http://www.conrad.nl/ce/nl/product/571288/
Or using a KaKu to switch power to a pump?
He's not quite clear about this
no1san
Re: water switch
Post by no1san »
@raymonvdm
yes thats ist. but found in cheaper . Thanks!
@AshaiRey somthing like that.
I found this:
http://www.conrad.nl/ce/nl/product/5830 ... view1&rb=2
Check the reviews including pictures
Thanks all!
Bastiaan
Re: water switch
Post by Bastiaan »
Not sure how and where you want to use the valve for but keep in mind that a simple valve might have some impact on your tubing if it switches abrupt.
The valves I use open and close slowely so no big bangs through the house.
We discussed valves before in this topic (Dutch) Homeseer en sproeien tuin http://www.domoticaforum.eu/viewtopic.p ... it=gardena
Bastiaan
no1san
Re: water switch
Post by no1san »
thanks!
i like dutch :mrgreen:
Return to “Click On Click Off & Home Easy”
