Buienradar monitor HS3 plugin
Buienradar monitor HS3 plugin van Labium (Dutch allowed forum)
Moderator: labium
esschenk
Re: Buienradar monitor HS3 plugin
Post by esschenk »
Found the right version, I have installed this version.
Within the setup I can enable the plugin, but don’t see the setup page under plugins.
There are no errors in the log.
Disconnected
Buiten BuienRadarGps BuienRadarGpsDevice BuienRadarGps_IO_0 IO panel Today 9:39:17 PM
Any idea
Ed
bartbakels
Post by bartbakels »
Labium,
hereby a feature request is it possible to create devices which value will be set high once rain is expected( 5 or 10min) just like the neerslagmonitor scripts in hs2.
Regards
Bart
(ON ESXI )on NUC
labium
Post by labium »
the setup page is to be reached via the manage plugins page then press the blue name of Buienradargps
labium
Post by labium »
new version with i hope good working connect and disconnect status of io device. if you downloaded 1.0.0.5 you only have to replace the hspi file
buienradar1.0.0.6.zip
(85.82 KiB) Downloaded 710 times
vanisher
Post by vanisher »
Looking good!
bartbakels
labium,
Thanks, the connection state works now.
one other question. Is the device vaue of the location used? Should it have a value of 100 when rain is expected? Because I always see a value of 0.
Happy holidays!
Bart
(ON ESXI )on NUC
labium
Post by labium »
the device value is used for which graph is presented, big or small, not for the rain parameters, i am thinking how to have both in the device value or in the device.
bartbakels
Labium,
Maybe an idea to store the graph settings to a config file? Or create additional devices with user defined offset times with a high value when rain is expected in 1, 5 or 10 min for example?
Regards
Bart
(ON ESXI )on NUC
esschenk
Post by esschenk »
The new version works great, only I can’t see graphics with Google chrome
With explorer its works fine.
But most off the time I use chrome so any idea
Thanks Ed
bartbakels
Same here with iphone or ipad. Maybe an idea to create the graphs with javascript.
However still a great plugin!!
(ON ESXI )on NUC
labium
Post by labium »
the first version makes graphs with javascript
bartbakels
Labium
I use these graphs alot. Are compatible with most browsers. More info at board.homeseer.com/showthread.php?t=164 ... to=newpost
Regards
(ON ESXI )on NUC
labium
Post by labium »
dont worry in the next version chrome will work, i forgot a ")" in the code, ie has no problem with that chrome was more precise. if i wasnt changing the devicevalues it was published already.
vanisher
Post by vanisher »
Is it possible to disable logging?
The updates are uhmmm, quite large :D
labium
Post by labium »
i will implement the logging choices in the next version
Return to “Homeseer Buienradar monitor HS3 plugin”
