Opentherm Gateway 4.0 alpha/beta testers wanted
Locked
sappien
Re: Opentherm Gateway 4.0 alpha/beta testers wanted
Post by sappien »
It's indeed Linux X86, but same error
sappien
Post by sappien »
It only starts when running a Xwindows
That's a completely different error. Why are you running this as root? That should not be necessary. (You may have to add the user to a special group to allow access to the serial port.)
Try 4.0b2.2. That doesn't crash in case of dbus problems (of course you won't have dbus control of the application in that case).
trie wrote:Do you also have a Linux x86_64 or the raspberry version of this? Then I can get the logging on console as well.
You can run the 32-bit linux version on a 64-bit linux platform with 32-bit libraries installed. I have uploaded otmonitor 4.0b2.2 for raspberry pi.
sappien
Post by sappien »
hvxl wrote:That's a completely different error.
You're right, I was also trying to use the dbus... but that gave the same error as otmontior..
sappien
Post by sappien »
hvxl wrote:Try 4.0b2.2. That doesn't crash in case of dbus problems (of course you won't have dbus control of the application in that case).
It's working.. Now I've got to figure out why dbus isn't working ;)
In a next version I can make otmonitor (optionally) use the system dbus instead of the session dbus. But that requires some advanced security configuration on the system that may be a bit too much for the average user.
sappien
Post by sappien »
dbus-send --print-reply --dest=com.tclcode.otmonitor / com.tclcode.otmonitor.Command :PR=A[/b]
Failed to open connection to "session" message bus: Unable to autolaunch a dbus-daemon without a $DISPLAY for X11
When I'm using eval it starts without the Display error
eval 'dbus-launch --auto-syntax' "dbus-send --print-reply --dest=com.tclcode.otmonitor / com.tclcode.otmonitor.Command :PR=A"
Error org.freedesktop.DBus.Error.ServiceUnknown: The name com.tclcode.otmonitor was not provided by any .service files
Any idea? I've tried creating .service files, but I'm unknown with dbus, so just messing around :roll:
trie
Post by trie »
Great, working now on the RPi which also has the OTGW connected. Unfortunately, the daemon/webinterface does not show logging as you've requested in my other topic about time/date losing. Any other way or do I need the graphical version?
Other question: is there some documentation about the T/B/A/R output and meaning (which code is what and how to interpret the values) of the OTGW? And any documentation of the status bits PS=1 provides?
OK, that appears to work. I wasn't aware of dbus-launch, but it seems you can use it to start otmonitor with a session dbus:
dbus-launch --exit-with-session ./otmonitor --webserver 8085 --daemon &
After that you can control otmonitor via dbus, even from another shell running under the same user.
Note: I think dbus-launch was the key, not eval.
trie wrote:Great, working now on the RPi which also has the OTGW connected. Unfortunately, the daemon/webinterface does not show logging as you've requested in my other topic about time/date losing. Any other way or do I need the graphical version?
You can specify several command line options to otmonitor. Use the -o option to specify a logfile, e.g.:
./otmonitor -o $(date +otlog-%Y%m%d.txt) --daemon /dev/ttyUSB0
The opentherm messages are decoded by otmonitor. For more details look at the opentherm specification.
The information reported by PS=1 is documented on the web site
sappien
Post by sappien »
hvxl wrote:OK, that appears to work. I wasn't aware of dbus-launch, but it seems you can use it to start otmonitor with a session dbus:
Otmonitor is running with the dbus-lauch, but connecting to it with dbus is still not working :
without eval I still get :
with eval :
--edit--
Is the name com.tclcode.otmonitor setup by otmonitor, or must I configure this manually?
It's hard for me to come up with different suggestions since the previous one worked for me (on a raspberry pi).
You could try:
$ dbus-launch > /tmp/dbusenv
$ ./otmonitor.ahf --daemon --webserver 8085
And then in another session:
$ . /tmp/dbusenv
$ dbus-send --print-reply --dest=com.tclcode.otmonitor / com.tclcode.otmonitor.Command :PR=A
The com.tclcode.otmonitor name doesn't require any manual configuration.
sappien
Post by sappien »
unfortunately... :cry:
I will try it on a fresh normal Debian installation.. (now using Voyage debian Linux)
Locked
