Eneco Toon Homeseer Script/Plugin
Forum over Homeseer Plugin ontwikkelingen, hierin staan aparte forums voor bijvoorbeeld Plugwise, RFXcom, Fritzbox, Alphatronics etc.
Moderator: Digit
bartbakels
Post by bartbakels »
Dear all,
Just to let you know, I am currently working on a homeseer 3 script to interface the eneco toon thermostat. Untill now im able to login, start, get current states and logout. As soon as I will get all functions working I will post the script on here. Maybe someone can build a plugin from it.
Keep in mind its nothing fancy and im not a scripting specialist ;)
and special thanks to RVDM from https://github.com/rvdm/toon
Regards
Bart
(ON ESXI )on NUC
bartbakels
Eneco Toon Homeseer Script/Plugin v0.1
dear all,
hereby version v0.1 of the script. For now it can only be used to write a setpoint and change modes. It also displays some current values of the toon in the homeseer log. In the next version these values will be pushed to 1 or more homeseer devices. In addition all other values such as current E/gas usage/costs etc will be made accesible by this script.
The reason I post this pre beta now;
I''ve tested the current script with HS3 and HS2 (v0.1). When I going to push values to homeseer devices it would not be compatible with HS2 anymore.
Im not a scripting guru, so I know I did something a bit clumsy, so please correct me ;)
Installation instructions:
save the code as toon.vb and create an homeseer event with parameters described in the header, except when using HS2 use these parameters ("Main","USERNAME,PASSWORD,SETPOINT,MODE")
The username and password are the same as for your eneco access
So here it is, and please comment and feel free to give me some feedback :D
v0.1 usable for HS2 and HS3
Sub Main(params as object)
'Control Eneco Toon Thermostat From Homeseer v0.1
'Made by Bart Bakels/ Promedes.nl
'Usage Script parameters; USERNAME,PASSWORD,SETPOINT,MODE
' No setpoint change fill in nothing; USERNAME,PASSWORD,,MODE
' no mode change fill in nothing USERNAME,PASSWORD,SETPOINT,
' only status update  fill in USERNAME,PASSWORD,,
' modestates; 0=comfort; 1=thuis 2=slapen 3=weg
'Enable Debug Messages Level
'0=None
'1=Info
'2=All
Dim Debug = 1
'Get parameters
Dim parameters(4) as String
parameters = params.Split(",")
Dim Username As String = parameters(0)
Dim Password As String = parameters(1)
Dim setpoint As String = parameters(2)
Dim selectedmode As String = parameters(3)
'random needs to be a valid UUID1
Dim Random = "12344178-1544-5648-1234-567882545632"
dim indexstart
dim indexend
Dim loginresponse
Dim startresponse
Dim logoutresponse
Dim stateresponse
Dim spsetresponse
Dim modesetresponse
Dim clientid
Dim clientidchecksum
Dim agreementid
Dim agreementidchecksum
'Login
loginresponse = hs.URLAction("https://toonopafstand.eneco.nl/toonMobileBackendWeb/client/login?username=" & Username & "&password=" & Password,"GET", "", "")
If Debug = 2 Then
hs.WriteLog("Toon response login Pri", loginresponse)
End If
'find IDS
indexstart = InStr(loginresponse, """clientId"":")
indexstart = indexstart + 13
clientid = Mid(loginresponse,indexstart , 36 )
If Debug = 2 Then
hs.WriteLog("toon ClientID", clientid)
End If
indexstart = InStr(loginresponse, """clientIdChecksum"":")
indexstart = indexstart + 21
clientidchecksum = Mid(loginresponse,indexstart , 40 )
If Debug = 2 Then
hs.WriteLog("toon ClientIDChecksum", clientidchecksum)
End If
indexstart = InStr(loginresponse, """agreementId"":")
indexstart = indexstart + 16
agreementid = Mid(loginresponse,indexstart , 5 )
If Debug = 2 Then
hs.WriteLog("toon AgreementID", agreementid)
End If
indexstart = InStr(loginresponse, """agreementIdChecksum"":")
indexstart = indexstart + 24
agreementidchecksum = Mid(loginresponse,indexstart , 40 )
If Debug = 2 Then
hs.WriteLog("toon AgreementIDChecksum", agreementidchecksum)
End If
'Start
startresponse = hs.URLAction("https://toonopafstand.eneco.nl/toonMobileBackendWeb/client/auth/start?clientId=" & clientid & "&clientIdChecksum=" & clientidchecksum & "&agreementId=" & agreementid & "&agreementIdChecksum=" & agreementidchecksum & "&random=" & random,"GET", "", "")
If Debug = 2 Then
hs.WriteLog("Toon response Start", startresponse)
End If
'Retrieve Toon State
stateresponse = hs.URLAction("https://toonopafstand.eneco.nl/toonMobileBackendWeb/client/auth/retrieveToonState?clientId=" & clientid & "&clientIdChecksum=" & clientidchecksum & "&random=" & random,"GET", "", "")
If Debug = 2 Then
hs.WriteLog("Toon response status", stateresponse)
End If
'Write Manual Setpoint to Toon
Dim setpointraw
If NOT setpoint = "" Then
setpointraw = setpoint*100
spsetresponse = hs.URLAction("https://toonopafstand.eneco.nl/toonMobileBackendWeb/client/auth/setPoint?clientId=" & clientid & "&clientIdChecksum=" & clientidchecksum & "&value=" & setpointraw & "&random=" & random,"GET", "", "")
If Debug = 1 Then
hs.WriteLog("Toon SP written","SP set to: " & setpoint & "  response: " & spsetresponse)
End If
End If
'Write Mode to Toon
If NOT selectedMode = "" Then
modesetresponse = hs.URLAction("https://toonopafstand.eneco.nl/toonMobileBackendWeb/client/auth/schemeState?clientId=" & clientid & "&clientIdChecksum=" & clientidchecksum & "&state=2&temperatureState=" & selectedMode & "&random=" & random,"GET", "", "")
If Debug = 1 Then
hs.WriteLog("Toon Mode written","Mode set to: " & selectedMode & "  response: " & modesetresponse)
End If
End If
'Logout
logoutresponse = hs.URLAction("https://toonopafstand.eneco.nl/toonMobileBackendWeb/client/auth/logout?clientId=" & clientid & "&clientIdChecksum=" & clientidchecksum & "&random=" & random,"GET", "", "")
If Debug = 2 Then
hs.WriteLog("Toon response logout", logoutresponse)
End If
'decode state
Dim currenttemp
Dim currentsetpoint
Dim burnerstatus
Dim currentmode As String
indexstart = InStr(stateresponse, """currentTemp"":")
indexstart = indexstart + 14
currenttemp = Mid(stateresponse,indexstart , 5 )
currenttemp = currenttemp/100
If Debug > 0 Then
hs.WriteLog("Toon CurrentTemp", currenttemp)
End If
indexstart = InStr(stateresponse, """currentSetpoint"":")
indexstart = indexstart + 18
currentsetpoint = Mid(stateresponse,indexstart , 5 )
currentsetpoint = currentSetpoint/100
If Debug > 0 Then
hs.WriteLog("Toon CurrentSP", currentsetpoint)
End If
indexstart = InStr(stateresponse, """burnerInfo"":")
indexstart = indexstart + 15
burnerstatus = Mid(stateresponse,indexstart , 1 )
If Debug > 0 Then
hs.WriteLog("Toon burnerStatus", burnerstatus)
End If
indexstart = InStr(stateresponse, """activeState"":")
currentmode = Mid(stateresponse,indexstart , 2 )
if currentmode = " -"
currentmode = "Manueel"
End if
if currentmode = " 0"
currentmode = "comfort"
End if
if currentmode = " 1"
currentmode = "thuis"
End if
if currentmode = " 2"
currentmode = "slapen"
End if
if currentmode = " 3"
currentmode = "weg"
End if
If Debug > 0 Then
hs.WriteLog("Toon currentmode", currentmode)
End If
If Debug > 0 Then
hs.WriteLog("Toon", "Success")
End If
End Sub
(ON ESXI )on NUC
bartbakels
Re: Eneco Toon Homeseer Script/Plugin
In the next version the login credentials will be stored in a ini. As well as the automatic generated device references. Im planning to create devices for each value in HS3 such as;
-PV
-SP
-Mode
- Burnerstate
-Curent Gas usage
-current E usage
-Current Gas costs
-Current E costs
-Total gas usage
-Total E Usage
- etc
In addition it would be helpfull to have a VB JSON interpreter. But could not found a usable solution, any suggestions?
regards
Bart
(ON ESXI )on NUC
bartbakels
Dear all,
IM getting there. The script now creats and updates the toon devices automatic, and the credentials are now stored in a INI. In addition I posted a screenshot. keep u posted
Screenshot
Screenshot
Regards
Bart
(ON ESXI )on NUC
bartbakels
Eneco Toon Homeseer Script/Plugin v0.4 available
Dear all,
hereby version 0.4,
dropbox.com/s/vay4t6tdmsul77s/ToonHS3sc ... ipt0_4.zip
- Just Unzip the content of the zip to your Homeseer 3 root
- Change the login credentials in the toonscript.ini file in the config directory.
- Create an event which will call the script every X minutes for status updates. parameters; ,
To change mode use an additional event with the parameters; ,MODE
To change setpoint use an additional event with the parameters; SETPOINT,
when the event is run for the first time the following devices are created;
screenshot devices
screenshot devices
:D
I plan to create buttons to change modes, but this is not yet supported in HS3 for my understanding.
Please feel free to comment, give feature request or what so ever.
regards
Bart
(ON ESXI )on NUC
Edwin
Post by Edwin »
looking great,
verry good job
greetings edwin
esschenk
Post by esschenk »
Good Job
Ed
bartbakels
Dear All,
I am working on some improvements;
- an status device including last update, status, etc
- errorhandeling
- better data parsing
- calculate dayusage and costs?
- buttons to control the thermostat (as son as supported by HS3)
Are there any other feature request?
regards
Bart
(ON ESXI )on NUC
RdP
Post by RdP »
Hi Bart,
Nice job !!!!
I can put the Thermostat part in my IPThermostat plug-in, if you share your scripts with me. I want to keep the IPThermostat plug-in solely for Thermostats and keep things simple.
On the other hand it's a bit stupid to have only the thermostat part of the Toon in my Plug-in.
I can offer you to create a Toon plug-in based on what you already have done and than you'll have the needed buttons as well :-)
The problem is that I don't have a Toon and it will cost me a fair amour of time to create a plug-in, although it gets easier with every new plug-in.
Let me know your thoughts?
/Rien
bartbakels
Rien,
Thanks for your response. I think your correct that the toon has some more usefull functions which can/ need to be used.
So a dedicated plugin would be the best way to go in my opinion. The script is not password protected so be my guest. In addition if u go for the option to built a plugin, i would love to help. So i can learn something ;) im still waiting on a visonic plugin ( maybe reverse engineering) and mayby a conversion of my hue script to a plugin for hs3.
If u have any questions please contact me here or pb me.
Regards
Bart
(ON ESXI )on NUC
bartbakels
Eneco Toon Homeseer Script/Plugin release 1.0
dear all,
hereby version 1.0 of the HS3 toon script.
dropbox.com/s/azmwt7f38qfag0k/ToonHS3sc ... ipt1_0.zip
changes;
-errorhandeling
-buttons for mode change
-buttons for sp change
-info/status device
-day gas and electra usage
Be advised, the Control (script) buttons do not work in HSTOUCH, probably a bug, which has been communicated with the HS team
please comment, if there are issues and or feature requests.
regards
Bart
(ON ESXI )on NUC
bartbakels
Eneco Toon Homeseer Script/Plugin v1.1
dear all,
version 1.1 dropbox.com/s/yvzzsfueoytf3ji/toon%20v1 ... 20v1_1.zip
hereby version 1.1, changed the daily E usage. I projected the low usage only as total usage which offcource is not correct. Now there are 3 devices wich represent;
E Day (laagtarief) usage
E Day (hoogtarief) usage
E Day Total usage
IMPORTANT, I also changed the script parameter call to a "|" divider instead of ",", so please check your script calls. Please remove all old devices and run the script again, the devices will be created again.
If there are any additional questions please comment.
regards
Bart
(ON ESXI )on NUC
smaling
Post by smaling »
How 2 install this?
bartbakels
Just follow the instructions in the header and in this topic.
Btw as soon as the new hs3 update is released i will release the new version with working hstouch buttons.
Regards
Bart
(ON ESXI )on NUC
bartbakels
dear all,
I have a new version available which fixes some small bugs and the buttons are working in HStouch now. However this only works with the beta release of homeseer. Any interest in this version?
regards
Bart
(ON ESXI )on NUC
Return to “Homeseer Plugins Forum”
