Buienradar monitor HS3 plugin
Buienradar monitor HS3 plugin van Labium (Dutch allowed forum)
Moderator: labium
Bastiaan
Re: Buienradar monitor HS3 plugin
Post by Bastiaan »
Just installed the plugin so started fresh with v0.6, set the address (only 1) and got the connect light green.
Checked the logs and saw an error about the Jilles.Geocode.js
It seems there is a mismatch between the install package and the plugin.
in the package the file is in html/js/ the plugin looks in /html/js/buienradargps/
copied the file over and re-started the plugin:
Error in the plugin manager: **FATAL**: Failed getting InterfaceStatus from BuienRadarGps - the interface was not found in the list of active interfaces.
in the log: Calling SetIOMulti in plugin BuienRadarGps:Conversion from string "" to type 'Double' is not valid.
Removed all devices, restarted the plugin and had no errors.
Log looks ok:
Jan-10 10:29:56 Plug-In Finished initializing plug-in BuienRadarGps
Jan-10 10:29:55 BuienRadarGps HSPI Started
Jan-10 10:29:55 Info Plug-in BuienRadarGps has connected successfully
Jan-10 10:29:55 Info Remote application or plugin has connected: 127.0.0.1:61321
Jan-10 10:29:55 Info Remote application or plugin has connected: 127.0.0.1:61320
Noticed that everytime I edit the current address I get a new device made.
Only get the text "small" in the devices. No graphs etc.
UPDATE: Just saw that after the restart the address was not checked as active. Changed it and I am back with the error in the log:
File does not exist: C:\Program Files (x86)\HomeSeer HS3\html\js\buienradargps\Jilles.Geocode.js
But file is there:
Screen Shot 2014-01-10 at 11.02.00.png (10.17 KiB) Viewed 20121 times
Another odd thing: when I enter LAT and LON it shows OK, when I try to edit the values the popups are switched arround. Clicking on the LAT, give the popup for LON and vice versa.
labium
Post by labium »
thank you for the info, i shall look into it
bartbakels
Post by bartbakels »
Are there any updates regarding this plugin? Still looking for the functionality to predict rain via a device in HS3.
reagrds
bart
(ON ESXI )on NUC
labium
Post by labium »
yes there is progress i am testing a child device with all rain properties . since december there was very little rain here in spijkenisse so there was not much testing.
akkie71
Post by akkie71 »
I tested your buienradar monitor with great interest.
I you're looking for someone to test your latest version, I'd be happy to try it.
Broes
Post by Broes »
Great plugin!
Got it working here too, although I am not sure because I didn't see any rain coming up yet :wink:
I am wondering if it possible to monitor via HSTouch, I have no idea how to get the image in.
It would be wonderfull to switch something when rain is coming up!
Peter
bartbakels
Labium,
Any plans to release a next version of your plugin? otherwise im planning to migrate the buienradar HS2 script to HS3.
Thanks for this great plugin.
Bart
(ON ESXI )on NUC
RdP
Post by RdP »
Tried the plug-in (1.06) and it seems to connect, but the device status of the monitoring location just stated "Small" (see below)
Any idea what is going wrong ?
Thanks,
Akatar
Post by Akatar »
when i try to enter the config page:
error - De conversie van tekenreeks naar type Boolean is ongeldig.
any ideas?
RdP
Post by RdP »
What's the status of this plug-in ? I still have the same issues as posted earlier :-(
Thanks,
labium
Post by labium »
i am not working on it anymore. i am trying now to make devices for node js. hs3 is a very heavy load on my computer . the buienradar android app kan also give the same local rain info nowadays.
RdP
Post by RdP »
Ok...
That's too bad, I liked the functionality, alltough I couldn't get it to work all the time...
Return to “Homeseer Buienradar monitor HS3 plugin”
