three Chan protocol
Moderator: b_weijenberg
koen01
three Chan protocol
Post by koen01 »
Is this protocol supported by the 433mhz e usb transceiver?
http://wiki.pilight.org/doku.php/threechan
If not, is it possible to support it in the future?
I'm willing to send raw dumps etc.
b_weijenberg
Re: three Chan protocol
Post by b_weijenberg »
sent you a PM
koen01
Post by koen01 »
Can't reply to the pm.
But the sensor is the one that came with this station.
http://www.alecto.nl/weerstation-1700
In pilight it works with the threechan protocol for temp, humidity and battery level.
The pilight alecto protocol only works for temp.
b_weijenberg
As indicated in the PM contact support rfxcom.com
b_weijenberg
The Alecto WS1700 and compatible protocol is added in the RFXtrx433E firmware version 232.
Enable the Rubicson protocol to receive this sensor.
Drawback for this sensor type is that it does not have a checksum byte and you will receive sometimes wrong values as a result of a bad RF packet!
Use this type of sensor only for temp/hum display and not for control of heating or ventilation.
