Rfxcom homeseer plug-in and lighting4
Moderator: b_weijenberg
rvdvoort
Post by rvdvoort »
I am able to control my home LED lighting with a 24 (6x4digits) digit pulse in the RFXcom mgr via lighting 4.
I am not able to find how to do this via homeseer. Is the same lighting4 functionality enabled in the HS3 plug-in? And if yes how do I use this? (How do I sent these 24 digit commands)
Thx,
Rob
b_weijenberg
Re: Rfxcom homeseer plug-in and lighting4
Post by b_weijenberg »
See chapter 11.6 in the RFXCOM HS3 User Guide.pdf
rvdvoort
Post by rvdvoort »
Can you please tell me where I can find the HS3 RFXcom user guide (can only find the hs2 guide on Rfxcom page).
I cannot find it anywhere on the homeseer pages or on the rfxcom page. In the homeseer forum you refer to the homseer documentation page. But it is not there (at least not under help / documentation).
Thx for your help.
b_weijenberg
This document is in the Homeseer3 Docs directory (after the plug-in is installed)
rvdvoort
Post by rvdvoort »
Ok, thx found it.
I was looking on the homeseer side / rfxcom side. Didn't think about my own homeseer 3 drectory. You mentioning the plug-in did the trick.
Thanks for pointing me in the correct direction....now its clear (also chapter 11.6 :-))
Thx,
Rob
