Once in a while the velux skylight is still open when it starts to rain and it is easy to forget it is still open. I would like to add a magnetic contact to the window but i`m not sure which one to choose since there is little space available. If possible i would like a build in contact
I already have some of these on the doors just to detect motion and switch the lights on/off but i don`t think it is the best solution for the velux skylight
Magnetic contact for Velux window
Re: Magnetic contact for Velux window
I've mounted similar contacts in my Velux windows. I drilled the holes in the frame without problems. But you're correct, there's not much space.
Mind to share some pics ?
- Member
not sure if these are to big ?
Just picked them up for testing something so your lucky.
There cheap as well
aliexpress.com/item/Free-Shipping-5set- ... 07201.html
There cheap as well
Sureraymonvdm wrote:Mind to share some pics ?
