HS3 event "time before" + "time after" ?
Moderator: Ruud
DJF3
Post by DJF3 »
Team,
In HS2 I was able to create an event that had 2 conditions
- time after 01:00 AND time before 07:00
Another event would run this event "If other event conditions are TRUE"
In HS3, I cannot start the event conditions with "IF time AFTER". There's only on/after sunrise conditions.. Why is that?
First "The time is" condition
First TIME IF condition
Screen Shot 2015-10-04 at 11.17.44 .png (75.22 KiB) Viewed 9660 times
Q: Why can't I use "Time After x:xx" as the first condition?
"AND" "The time is" condition
AND TIME IF condition
Screen Shot 2015-10-04 at 11.18.19 .png (173.97 KiB) Viewed 9660 times
NOW I can select "Time After x:xx" ?
Any workarounds? Tips?
raymonvdm
Re: HS3 event "time before" + "time after" ?
Post by raymonvdm »
Just do it like this ?
DJF3
Post by DJF3 »
Won't the event run every 5 minutes between 1-7am?
DJ
raymonvdm
Post by raymonvdm »
Yes :-) But that is just to let you see how it works. Normally i would use a device trigger to start the event :D
stefxx
Post by stefxx »
And that is why you need another condition as well. Just testing between a start and end time would potentially trigger every second.
Maybe if you explain what you are trying to achieve we can better help you.
DJF3
Post by DJF3 »
For example: An event that is triggered only between 22:00 and 08:00
Event conditions
Event conditions
Screen Shot 2015-10-15 at 16.13.22 .png (29.67 KiB) Viewed 9224 times
In HS3 if I do a
............ IF motion livingroom
............ AND time is > 22:00
............ OR <condition>
Now my only choices are
Event conditions HS3
Screen Shot 2015-10-15 at 16.16.22 .png (29.06 KiB) Viewed 9224 times
It feels like I have missed a basic "HS3 thing"... Any idea?
DJ
stefxx
Post by stefxx »
I think you need another AND IF instead of OR IF.
DJF3
Post by DJF3 »
Even though I didn't want to do this I started using an extra device..
HS3 event for night only
Screen Shot 2015-10-18 at 10.44.07 .png (41.64 KiB) Viewed 9104 times
2 Events set a "NIGHT time" device to ON or OFF. This I can now use in other events without having to worry about ">20:00 and <07:00".
Thanks for the help!
DJ
