Fibaro FGBS321 Universal Binary Sensor
raymonvdm
Post by raymonvdm »
Manaul: http://www.fibaro.com/manuals/en/FGBS32 ... .1-2.3.pdf
I have one of these modules but i`m unable to get an instant status update when a button is pressed. It should be working but it`s not. (I`m using HS3) and i think it might be firmware related.
Can someone where it is working fine tell me their Firmware version?
Manufacturer: Fibaro System
Type: 0x501
Listens: Yes
Version: 340 (Unknown)
Firmware: 349
Neighbor Count: 5
Speed: 40.0Kbps
bartbakels
Re: Fibaro FGBS321 Universal Binary Sensor
Post by bartbakels »
I had the same issues, in the beginning of HS3. What I did was to change the alarmframe that was the send upon change, not sure.. was a while ago, but I have 3 of those sensors with instant sensor updates..
(ON ESXI )on NUC
raymonvdm
Post by raymonvdm »
I think we already talked about it once using the forum but i could not find the posts.
Can you give me some more information so i can find out what to do next?
I tried the following
Parameter 5 changed to 0
Parameter 6 changed to 0
Parameter 13 was already 0
And this is the result for testing one button
I would be interrested in this info too
bartbakels
If I recall correctly, the alarmframe for input 1 should be something else then for input 2. I will try to look it up this week.
Bart
(ON ESXI )on NUC
bartbakels
Gents,(oops posted in the wrong topic before)
follow the posts at domoticaforum.eu/viewtopic.php?f=79&amp ... +universal
associations need to have endpoints and par 5 and 6 need to be generic alarm.
In addition, probably good to excluded/reset first, had some issues with including in the past. Devices should be visible as (without connected temp sensors):
board.homeseer.com/showpost.php?p=11199 ... tcount=131
Mine are working now for almost a year without issues, got 2 of them.
Bart
(ON ESXI )on NUC
Akatar
Post by Akatar »
i'm testing 1 ubs with hs3 but only input 1 works, input 2 does nothing.
any thoughts why not?
raymonvdm
Post by raymonvdm »
Does input2 also trigger input1 in HS3. Because that is the issue i'm having with dual relay modules running firmware 20 or higher
Akatar
Post by Akatar »
in my case, input 1 works, 2 does not
raymonvdm
Post by raymonvdm »
Akatar wrote:in my case, input 1 works, 2 does not
Try another module to rule things out. I don't have a "new" module so i cannot test it out. I think this is an amazon module wich might have newer firmware?
Akatar
Post by Akatar »
no, this is version 2.1, i did order a ubs at amazon.it. when it arrivés i will test
Bastiaan
Post by Bastiaan »
Akatar, just did a quick test with one of the 'Italian' sets:
First inclusion showed only 1 'reserved' node but after I connected yellow and green wire to GND for a while it suddenly popped up and started to work.
Do you see the same nodes as me?
Screen Shot 2015-10-18 at 11.32.11.png (162.48 KiB) Viewed 19225 times
Tried a full reset?
In my case when I hold yellow or green wire against (blue) GND it switches the node with a small delay of 1-3 secs.
Akatar
Post by Akatar »
i do see the same nodes, i will connect yellow/green/blue and see what happens
Akatar
Post by Akatar »
still not working
Antoon
Post by Antoon »
Mine Amazone with firmware 2.1 does the following
Input 1 is does nothing in HS3 but the output is working, also in HS3
Input 2 is working in HS3 and also the output.
- Antoon
Return to “Z-Wave Forum”
