HS3 MQTT Plugin
Alles m.b.t. de Homeseer MQTT Broker Plugin van Willem Eradus (Dutch Forum)
Moderator: Willem4ever
tominthevan
Re: HS3 MQTT Plugin
Post by tominthevan »
Geert-Jan
That was quick! I had the wrong plug-in installed. I'll fix that and see how it goes.
Thanks
Tom
tominthevan
Re: HS3 MQTT Plugin
Hi
Thanks that worked. I should have read the forum more closely. That suggestion moved me forward a lot. Now I need to install a broker somewhere on my network.
Would it be asking too much of the little Pi to have the broker also running on it beside HS3?
Tom
geert-jan
Re: HS3 MQTT Plugin
Post by geert-jan »
Hereby an updated version, but not thoroughly tested yet.
Changelog:
- Added filter on the 'Publish' page, which will make selecting a device more easy and reduces page loading time.
Note that per default ALL check marks are off, meaning that NO devices will be displayed until you select the Room and Type (aka location and location2).
Geert-Jan
HSPI_MQTT_v0.6.2.zip
(37.42 KiB) Downloaded 630 times
raymonvdm
Re: HS3 MQTT Plugin
Post by raymonvdm »
geert-jan wrote:Hi,
the MQTT plugin writes the MQTT data in a Homeseer device, the device values are available in events and scripts.
I use 'location2' as device type; Electra, Water, Gas.
The script below is called from a Homeseer event every hour, and writes the actual device values for each device where the type is 'Electra', 'Gas' or 'Water' to a MySQL database. The types can easily be extended, with Temperature, Humidity, etc.
Imports MySql.Data.MySqlClient
Sub main(Optional ByVal pParms As String = "")
  Dim en
  Dim dv
  en = hs.GetDeviceEnumerator
  if IsReference(en) Then
    do while not en.Finished
      dv = en.GetNext
      if not dv is nothing then
          select case dv.location2(hs)
          case "Electra"
            writeDB("electra", dv, 1000)
          case "Gas"
            writeDB("gas", dv, 1000)
          case "Water"
            writeDB("water", dv, 1)
          end select
      end if
    loop
  end if
End Sub
Sub writeDB(ByVal dbTable as String, ByVal dvRef as Object, devFactor as Integer)
  Dim conn As MySqlConnection
  Dim myCommand As New MySqlCommand
  Dim timestamp As String
  Dim devValue As Integer
  timestamp = Datepart("yyyy",Now()) & "-" & Right("0" & DatePart("m",Now()),2) & "-" & Right("0" & DatePart("d",Now()),2) & " " & Right("0" & DatePart("h",Now()),2) & ":" & "00:00"
  if NOT dbTable = Nothing
    conn = New MySqlConnection()
    conn.ConnectionString = "server=<ip address>; user id=<user id>; password=<password>; database=<database>"
    devValue = Convert.Toint64(dvRef.devValue(hs) * devFactor)
    Try
          conn.Open()
          myCommand.CommandText = "INSERT INTO " _
		& dbTable _
		&  " (deviceName, timestamp, deviceValue, deviceType, deviceId)" _
		& " VALUES ('" _
                  & dvRef.Name(hs) & "','" _
                  & timestamp & "','" _
                  & devValue  & "','" _
                  & dvRef.location2(hs) & "','" _
                  & dvRef.Code(hs) & "')"
      myCommand.Connection = conn
      myCommand.ExecuteNonQuery()
      conn.Close()
   Catch myerror As MySqlException
      hs.writelog ("datalog", "Error Connecting to Database: " & myerror.Message)
   End Try
 end If
End Sub
Sub updateCounter(Optional ByVal pParms As String = "")
    dim electraTotal as double
    dim dev1 as integer
    dim dev2 as integer
    dim dev3 as integer
    Dim arrParm() As String
    ' Extract parameters
    arrParm = pParms .ToString.Split(";")
    dev1= arrParm(0)
    dev2= arrParm(1)
    dev3= arrParm(2)
    electraTotal = hs.devicevalueex(dev1) + hs.devicevalueex(dev2)
    hs.setdevicevaluebyref(dev3, electraTotal, true)
    hs.setdevicestring(dev3, electraTotal & " KWh", true)
end sub
Adapt the fields between'<>' in conn.ConnectionString = "server=<ip address>; user id=<user id>; password=<password>; database=<database>" to your configuration.
Geert-Jan
I have installed http://dev.mysql.com/downloads/connector/net/ but the script is not yet working
Compiling script C:\Program Files\HomeSeer HS3\scripts\LogDataToMysql.vb: Type 'MySqlException' is not defined.
Compiling script C:\Program Files\HomeSeer HS3\scripts\LogDataToMysql.vb: Type 'MySqlConnection' is not defined.
Sparkman
Re: HS3 MQTT Plugin
Post by Sparkman »
Great, thanks very much. Trying it right now.
Cheers
Al
Reason: please stop quoting while not needed...thanks
geert-jan
Re: HS3 MQTT Plugin
Post by geert-jan »
@raymonvdm:
I got VB and MySql working by downloading the MySql connector from Microsoft:
- http://dev.mysql.com/downloads/connector/net/1.0.html
- Select platform '.Net and Mono'
- Download the zip file
- Extract the .dll files to your Homeseer folder
Geert-Jan
raymonvdm
Re: HS3 MQTT Plugin
Post by raymonvdm »
Which version did you select? I tried 1.0.10 and 6.8.7 but stil no go
Error	Compiling script C:\Program Files\HomeSeer HS3\scripts\LogDataToMysql.vb: Type 'MySqlException' is not defined.
Error	Compiling script C:\Program Files\HomeSeer HS3\scripts\LogDataToMysql.vb: Type 'MySqlConnection' is not defined.
Error	Compiling script C:\Program Files\HomeSeer HS3\scripts\LogDataToMysql.vb: Type 'MySqlCommand' is not defined.
Error	Compiling script C:\Program Files\HomeSeer HS3\scripts\LogDataToMysql.vb: Namespace or type specified in the Imports 'MySql.Data.MySqlClient' doesn't contain any public member or cannot be found. Make sure the namespace or the type is defined and contains at least one public member. Make sure the imported element name doesn't use any aliases.
Error	Compiling script C:\Program Files\HomeSeer HS3\scripts\LogDataToMysql.vb: Namespace or type specified in the Imports 'System.Core' doesn't contain any public member or cannot be found. Make sure the namespace or the type is defined and contains at least one public member. Make sure the imported element name doesn't use any aliases.
Note: My HS3 is running on Windows 7
geert-jan
Re: HS3 MQTT Plugin
Post by geert-jan »
I am using MySql connector version 6.7.4, date 19-06-2013, on a Windows XP system (running in a VirtualBox).
Geert-Jan
raymonvdm
Re: HS3 MQTT Plugin
Post by raymonvdm »
Is it also possible to add the Reference ID to the list of devices visable under MQTT -> Publish ?
I have found a way to export the MQTT data to file to create my cacti graphs but i need to manually lookup the reference id for each device which is quite time consuming
geert-jan
Re: HS3 MQTT Plugin
Post by geert-jan »
Adding the reference ID is no issue. I will add it to the overview.
Geert-Jan
raymonvdm
Re: HS3 MQTT Plugin
Post by raymonvdm »
I did some extra testing and it looks like some value updates are not MQTTed out. I have an OpenThermGateway script and the HomeSeer device status seems to be updated but the values are never send out by MQTT
geert-jan
Re: HS3 MQTT Plugin
Post by geert-jan »
Hereby an updated version.
Changelog v0.6.4:
- Added device Id to 'Publish' page
- Publish value on value change (/homeseer/ + <dvRef> + /value)
- Publish string on string change (/homeseer/ + <dvRef> + /string)
This may lead to 2 publish messages per value update, since mostly also the string value is updated.
Geert-Jan
HSPI_MQTT_v0.6.4.zip
HS3 MQTT v0.6.4
(37.5 KiB) Downloaded 574 times
raymonvdm
Re: HS3 MQTT Plugin
Post by raymonvdm »
Is it possible to select the value or sting to publish to prevent dual MQTT messages. Usually the value is sufficient but sometimes you indeed need a string instead of a value :D
geert-jan
Re: HS3 MQTT Plugin
Post by geert-jan »
I will add a feature to select if you want to publish the value on value change, or publish the string on string change.
Geert-Jan
raymonvdm
Re: HS3 MQTT Plugin
Post by raymonvdm »
geert-jan wrote:Hi,
Geert-Jan
Or both perhaps :D
Return to “Homeseer MQTT Plugin Forum”
