Migrate RFXcom device database from HS2 to HS3
Moderator: b_weijenberg
I`m in the process of migrating my home from HomeSeer2 to HomeSeer3 but is there a way to migrate all RFXcom devices from HS2 to HS3 (in an easy way) so i can keep the device id`s which are used to send to my KaKu plugs (so i don`t have to relearn all modules)
- b_weijenberg
- Forum Moderator
Re: Migrate RFXcom device database from HS2 to HS3
See the attached pdf
- Export RFXCOM HS2 to HS3.pdf
- (56.16 KiB) Downloaded 742 times
It seems to be working, but my interface is not yet working in HS3 it keeps hanging on
26 (DeviceCmd) transceiver #1 State:Initializing Command not transmitted!
But after update to 30.0.0.28 the interface now seems to be working
- Advanced Member
Where stands the database of HS3? It's for making a backup.
Wim
Wim
- b_weijenberg
- Forum Moderator
C:\Program Files (x86)\HomeSeer HS3\Data
- Advanced Member
En de file heet dan waarschijnlijk 'HomeseerData_7_3.hsd'.
Maar er staan 3 files met een ander getal op het laatst van dezelfde datum. Wordt de database dan opgebouwd in 3 files?
Wim
Wim
- Advanced Member
I bring all the device in by hand in HS3. By RFXcom devices I can make a lot of choices.
Now I looking for the MS13E. In HS2 it was a a MS13A (Hawkeye II) type.
How must I bring this device in HS3? And which sort of device is it?
B.R. Wim
B.R. Wim
- b_weijenberg
- Forum Moderator
There is an import utility for RFXCOM devices from HS2 to HS3.
An MS13 is a X10 device and must be added by hand on the Homeseer main page.
Select STATUS ONLY for the house code used by the MS13 on the RFXCOM General config page.
- Advanced Member
Thanks Bert. I will try your information later this week for the MS13A device.
I have tried the import utility, but I like to bring in the devices by hand. So I can use the code I like.
B.R. Wim
B.R. Wim
- Advanced Member
In the main page of HS3: I was going to the plug-ins. In this pulldown menu I made the choice of RFXcom and in the second pulldown menu Output devices.
Here I made a X10-module for the MS13A. See attachment. I hope this will work.
- Advanced Member
Which RFXCOM output device type must I choose for a Sun-650 in HS3?
Wim
Wim
