uAlex73
Post by uAlex73 »
Excellent :mrgreen: Next 'question', you can still update to firmware 3.0/3.2 without subscription (i read a vpn tunnel should exist?)?
SD123
Post by SD123 »
hvxl wrote:I blocked all external traffic. I tried opening up buienrader.nl to get the weather information, but unfortunately it doesn't work that way. So there's nothing the Toon needs from the internet (it pings a local server as a connectivity check and also gets its time from there).
Thanks for your answer.
Today I blocked Toon from accessing my router based on the mac adress. Unfortunately it does not work for me. My toon is not rooted or anything. I only get the standard tiles you get without subscription.
Still it bugs the hell out of me, i can not access my own freaking data. Its ridiculous.
Never tried, but I don't think so. There probably won't be a set of upgrade packages sitting there waiting for you.
File a complaint at Eneco's.
Or root your toon. (Although there's still some work to do, then).
grtz,
Ierlandfan
Post by Ierlandfan »
Software updates are part of the subscription. You have to root it to update it manually.
Manually means root it, copying packages (I have them) and start the update script. That's all.
And no, without subscription you cannot (not without root that is) access your own data.
Toon op afstand is also part of the same subscription.
So without subscription, even the basic subscription, Toon is nothing but a very expensive useless Thermostat.
Root it and you're king.
To continue with my resuscitation activities:
The patient's not dead yet ;-).
Today I got my tftpboot setup working and I successfully booted one of the kernels I made with the source tarball of quby's.
Here's the result:
U-Boot 2010.09-R6 (Mar 14 2012 - 11:15:10)
CPU:   Freescale i.MX27 at 400.168 MHz
Prodrive B.V. ED2.0
DRAM:  128 MiB
NAND:  128 MiB
LCD: 800x480, pbb 4
LCD: Drawing the logo...
In:    serial
Out:   serial
Err:   serial
Error: no valid bmp image at a1d214a8 (signature 0xbe 0xda)
Net:   FEC
Address in SROM is         1f:56:1d:17:ee:22
Address in environment is  xx:xx:xx:xx:xx:xx
Enter password - autoboot in 2 sec...
NAND read: device 0 offset 0x300000, size 0x300000
 3145728 bytes read: OK
Wrong Image Format for bootm command
ERROR: can't get kernel image!
U-Boot> dhcp
BOOTP broadcast 1
*** Unhandled DHCP Option in OFFER/ACK: 28
DHCP client bound to address 10.1.0.201
U-Boot> tftpboot 0xa1000000 uImage-toon3
Using FEC device
TFTP from server 10.1.0.10; our IP address is 10.1.0.201
Filename 'uImage-toon3'.
Load address: 0xa1000000
Loading: #################################################################
done
Bytes transferred = 2353828 (23eaa4 hex)
U-Boot> bootm
## Booting kernel from Legacy Image at a1000000 ...
   Image Name:   Linux-2.6.36-R07-h21
   Image Type:   ARM Linux Kernel Image (uncompressed)
   Data Size:    2353764 Bytes = 2.2 MiB
   Load Address: a0008000
   Entry Point:  a0008000
   Verifying Checksum ... OK
   Loading Kernel Image ... OK
OK
Starting kernel ...
Uncompressing Linux... done, booting the kernel.
Linux version 2.6.36-R07-h21 (marcelr@laptop) (gcc version 4.56
CPU: ARM926EJ-S [41069264] revision 4 (ARMv5TEJ), cr=00053177
CPU: VIVT data cache, VIVT instruction cache
Machine: Prodrive B.V ED2.0
Memory policy: ECC disabled, Data cache writeback
Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 32512
Kernel command line: ubi.mtd=4 root=ubi0:rootfs rw rootfstype=ubifs mtdparts=mxM
PID hash table entries: 512 (order: -1, 2048 bytes)
Dentry cache hash table entries: 16384 (order: 4, 65536 bytes)
Inode-cache hash table entries: 8192 (order: 3, 32768 bytes)
Memory: 128MB = 128MB total
Memory: 125288k/125288k available, 5784k reserved, 0K highmem
Virtual kernel memory layout:
    vector  : 0xffff0000 - 0xffff1000   (   4 kB)
    fixmap  : 0xfff00000 - 0xfffe0000   ( 896 kB)
    DMA     : 0xffa00000 - 0xffe00000   (   4 MB)
    vmalloc : 0xc8800000 - 0xf4000000   ( 696 MB)
    lowmem  : 0xc0000000 - 0xc8000000   ( 128 MB)
    modules : 0xbf000000 - 0xc0000000   (  16 MB)
      .init : 0xc0008000 - 0xc0024000   ( 112 kB)
      .text : 0xc0024000 - 0xc0405000   (3972 kB)
      .data : 0xc0420000 - 0xc0467e60   ( 288 kB)
Hierarchical RCU implementation.
        RCU-based detection of stalled CPUs is disabled.
        Verbose stalled-CPUs detection is disabled.
NR_IRQS:272
MXC IRQ initialized
MXC GPIO hardware
Console: colour dummy device 80x30
Calibrating delay loop... 199.88 BogoMIPS (lpj=999424)
pid_max: default: 32768 minimum: 301
Mount-cache hash table entries: 512
CPU: Testing write buffer coherency: ok
NET: Registered protocol family 16
bio: create slab <bio-0> at 0
SCSI subsystem initialized
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
cfg80211: Calling CRDA to update world regulatory domain
Switching to clocksource mxc_timer1
NET: Registered protocol family 2
IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
TCP established hash table entries: 4096 (order: 3, 32768 bytes)
TCP bind hash table entries: 4096 (order: 2, 16384 bytes)
TCP: Hash tables configured (established 4096 bind 4096)
TCP reno registered
UDP hash table entries: 256 (order: 0, 4096 bytes)
UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
RPC: Registered udp transport module.
RPC: Registered tcp transport module.
RPC: Registered tcp NFSv4.1 backchannel transport module.
msgmni has been set to 244
io scheduler noop registered (default)
imx-fb imx-fb.0: PreserveUBootFramebuffer(1): xres=800, yres=480 [skip _update_]
imx-fb imx-fb.0: PreserveUBootFramebuffer(2): xres=800, yres=480 [skip _update_]
imx-fb imx-fb.0: PreserveUBootFramebuffer(3): xres=800, yres=480 [skip _update_]
Serial: IMX driver
imx-uart.0: ttymxc0 at MMIO 0x1000a000 (irq = 20) is a IMX
console [ttymxc0] enabled
imx-uart.1: ttymxc1 at MMIO 0x1000b000 (irq = 19) is a IMX
imx-uart.2: ttymxc2 at MMIO 0x1000c000 (irq = 18) is a IMX
NAND device: Manufacturer ID: 0xec, Chip ID: 0xf1 (Samsung NAND 128MiB 3,3V 8-b)
Scanning device for bad blocks
Bad eraseblock 669 at 0x0000053a0000
Bad eraseblock 926 at 0x0000073c0000
RedBoot partition parsing not available
5 cmdlinepart partitions found on MTD device mxc_nand
Creating 5 MTD partitions on "mxc_nand":
0x000000100000-0x000000180000 : "u-boot-env"
0x000000180000-0x000000300000 : "splash-image"
0x000000300000-0x000000600000 : "kernel"
0x000000600000-0x000000900000 : "kernel-backup"
0x000000900000-0x000008000000 : "rootfs"
UBI: attaching mtd4 to ubi0
UBI: physical eraseblock size:   131072 bytes (128 KiB)
UBI: logical eraseblock size:    129024 bytes
UBI: smallest flash I/O unit:    2048
UBI: sub-page size:              512
UBI: VID header offset:          512 (aligned 512)
UBI: data offset:                2048
UBI warning: check_what_we_have: 946 PEBs are corrupted
corrupted PEBs are: 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 1
UBI error: check_what_we_have: too many corrupted PEBs, refusing this device
UBI error: ubi_init: cannot attach mtd4
at25 spi0.0: 32 KByte at25640B eeprom, pagesize 64
spi_imx spi_imx.0: probed
FEC Ethernet Driver
fec_enet_mii_bus: probed
tun: Universal TUN/TAP device driver, 1.6
tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
mxc-ehci mxc-ehci.0: initializing i.MX USB Controller
mxc-ehci mxc-ehci.0: portsc setup 1: 0x80000000
mxc-ehci mxc-ehci.0: Work around for USB enabled
ULPI transceiver vendor/product ID 0x04cc/0x1505
mxc-ehci mxc-ehci.0: Freescale On-Chip EHCI Host Controller
mxc-ehci mxc-ehci.0: new USB bus registered, assigned bus number 1
mxc-ehci mxc-ehci.0: irq 56, io mem 0x10024000
mxc-ehci mxc-ehci.0: USB 2.0 started, EHCI 1.00
usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
usb usb1: Product: Freescale On-Chip EHCI Host Controller
usb usb1: Manufacturer: Linux 2.6.36-R07-h21 ehci_hcd
usb usb1: SerialNumber: mxc-ehci.0
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 1 port detected
mxc-ehci mxc-ehci.2: initializing i.MX USB Controller
mxc-ehci mxc-ehci.2: portsc setup 1: 0x80000000
mxc-ehci mxc-ehci.2: Work around for USB enabled
mxc-ehci mxc-ehci.2: Freescale On-Chip EHCI Host Controller
mxc-ehci mxc-ehci.2: new USB bus registered, assigned bus number 2
mxc-ehci mxc-ehci.2: irq 55, io mem 0x10024400
mxc-ehci mxc-ehci.2: USB 2.0 started, EHCI 1.00
usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
usb usb2: Product: Freescale On-Chip EHCI Host Controller
usb usb2: Manufacturer: Linux 2.6.36-R07-h21 ehci_hcd
usb usb2: SerialNumber: mxc-ehci.2
hub 2-0:1.0: USB hub found
hub 2-0:1.0: 1 port detected
Initializing USB Mass Storage driver...
usbcore: registered new interface driver usb-storage
USB Mass Storage support registered.
usbcore: registered new interface driver usbserial
usbserial: USB Serial Driver core
USB Serial support registered for cp210x
usbcore: registered new interface driver cp210x
cp210x: v0.09:Silicon Labs CP210x RS232 serial adaptor driver
USB Serial support registered for FTDI USB Serial Device
usbcore: registered new interface driver ftdi_sio
ftdi_sio: v1.6.0:USB FTDI Serial Converters Driver
USB Serial support registered for pl2303
usbcore: registered new interface driver pl2303
pl2303: Prolific PL2303 USB to serial adaptor driver
input: TSC2007 Touchscreen as /devices/virtual/input/input0
rtc-isl1208 1-006f: chip found, driver version 0.3
rtc-isl1208 1-006f: rtc core: registered rtc-isl1208 as rtc0
i2c /dev entries driver
imx2-wdt imx2-wdt.0: IMX2+ Watchdog Timer enabled. timeout=60s (nowayout=0)
adt7410 0-0048: adt7410 temperature sensor registered.
adt7410 0-0049: adt7410 temperature sensor registered.
usbcore: registered new interface driver r871x_usb_drv
nf_conntrack version 0.5.0 (1957 buckets, 7828 max)
ip_tables: (C) 2000-2006 Netfilter Core Team
TCP cubic registered
NET: Registered protocol family 10
ip6_tables: (C) 2000-2006 Netfilter Core Team
NET: Registered protocol family 17
lib80211: common routines for IEEE802.11 drivers
rtc-isl1208 1-006f: setting system clock to 2016-02-20 20:01:37 UTC (1455998497)
UBIFS error (pid 1): ubifs_get_sb: cannot open "ubi0:rootfs", error -19
VFS: Cannot open root device "ubi0:rootfs" or unknown-block(0,0)
Please append a correct "root=" boot option; here are the available partitions:
1f00             512 mtdblock0 (driver?)
1f01            1536 mtdblock1 (driver?)
1f02            3072 mtdblock2 (driver?)
1f03            3072 mtdblock3 (driver?)
1f04          121856 mtdblock4 (driver?)
Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(0,0)
[<c00293d0>] (unwind_backtrace+0x0/0xf0) from [<c0326da4>] (panic+0x60/0x190)
[<c0326da4>] (panic+0x60/0x190) from [<c0008ea0>] (mount_block_root+0x15c/0x20c)
[<c0008ea0>] (mount_block_root+0x15c/0x20c) from [<c00090d0>] (prepare_namespac)
[<c00090d0>] (prepare_namespace+0x8c/0x178) from [<c0008b50>] (kernel_init+0x10)
[<c0008b50>] (kernel_init+0x10c/0x14c) from [<c00258ec>] (kernel_thread_exit+0x)
The kernel loads, can read the NAND chip, and then decides that the root filesystem on it is really fucked up beyond any recognition, resulting in a kernel panic.
But that's OK. Not a thing that can't be fixed.
The good News is that kernels built from the source tree actually boot the way they should. This opens new ways for adapting toon to other needs. We can basically add anything we like, from printers to webcams, remotely mounted filesystems, data acquisition hardware, whatever, take you pick.
grtz,
The patient's still in ICU, but stable :-), he's gonna make it.
Last week, one of the forum members sent me a set of mtd dumps, and these turned out to be quite useless. Wasn't his fault, the rootfs, as flashed onto toon, is hard to mount without the right hardware (i.e. nand flash memory). So I sent him a script to dump the rootfs over ssh. That rendered a useful tarball, holding a complete root filesystem with a recent copy of toon's firmware.
The tarball holding the rootfs of his toon, together with a modified linux kernel, could be used to revive my toon (or any other, for that matter). It took some effort, the description of the inner workings of u-boot, nfsd and the combination, on modern linuxes, as found on the internet is less than optimal, let's put it that way ..
The kernel loads via tftp, the rootfs via nfs, from a dedicated set of servers (NFS, DHCP, TFTP) in combination with an old router limited to issuing 1 IP address only.
In case anyone's interested in the details, not sure if I will find the time to post them all, it's quite a long story ...
Now I will need to find a way to turn this rootfs into a flashable file for my toon, that's the easy part, before that I would like to return the rootfs to a more or less virgin state, i.e., get rid of all the data, settings, serial number-specific entries etc.
grtz,
hayman
Post by hayman »
i'n new hier thanks all for the nice work,
i'm planing to buy Toon is there how to root and this kind of thing ,
is it possible to use there app on the go ....?
i'm planing to enjoy Eneco but without monthly toon subscribe...
thanks all
Read this thread.
Completely, that is. Start at page 1, and work yourself all the way through.
grtz,
hayman
Post by hayman »
thanks
You're welcome,
A quick summary is posted here:
http://www.domoticaforum.eu/viewtopic.p ... =75#p77439
Getting your data on screen without subscription is possible, not sure about the app.
Good luck,
Me and my big mouth ...
Stripping the rootfs down to an anonymous, virgin, root filesystem turned out to be the easy part. That's done. Toon installs like it should, had to patch
/HCBv2/config/config_happ_scsync.xml manually, but that all works, now I have the whole lot of tiles as presented to "customers only". Just traffic and weather aren't working, known issue.
Flashing the rootfs onto toon is easy. Booting toon from it, that's a totally different kettle of fish.
Will keep trying, playing with bootloader, kernel flags, UBI layout, that sort of stuff. If anyone's an expert on UBIfs and flashing boot partitions on NAND flash, please come forward.
In the meantime another question:
I have solar panels on my roof, and just for fun switched on the solar option in toon. Now it complains about some connection to a kWh meter (see attached image, top right on toon's screen, although hard to see). Does anyone have toon solar? What's extra in the hardware/software with respect to the "normal" version?
grtz,
My rig to resuscitate toon: laptop with CentOS 6 + openembedded toolchain for toon, 100MBit router, 24V power supply, toon removed from housing, with serial connection to laptop.
al_n
Post by al_n »
As far as I know there isn't any special hardware but the information is coming from the smart meter port P1, your meter supposes to slow down or even turn backwards if you produce energy.
I don't think so. I have a meter with P1 port, apparently another kWh meter should be installed. This makes sense because there's no way for the kWh meter that's installed for metering your energy consumption, to tell the difference between gross power generation and direction consumption of your home-produced energy. This energy never passes the meter.
According to this page:
http://www.klimaatgids.nl/nieuws/toon-l ... nelen-zien
(in Dutch, I'm afraid), extra software and an extra kWh meter are required. The question is: which software, which hardware, and even more interesting: how is it connected?
grtz,
SD123
Post by SD123 »
hayman wrote:i'n new hier thanks all for the nice work,
thanks all
No, app won't work without subscription.
Ierlandfan pretty much sums it up:
Ierlandfan wrote: ... without subscription, even the basic subscription, Toon is nothing but a very expensive useless Thermostat.
Regarding expensive. I suggest you buy a used one. Not worth 200 euro + for a new one, plus installation is a piece of cake, if you can handle a screwdriver, you can do it. Avoid marktplaats.nl people ask way too much. From time to time usedproducts have them for sale at reasonable price including 1 month warrenty. I got mine for 95 Euro shipped.
Last weekend I built a newer version of dropbear. This one should resolve issues with no longer secure encryption algorithms in version 0.51, which was posted earlier.
Unzip, copy to toon and install: opkg install <name of package>.
enjoy.
EDIT: dropbear has been moved to the downloads section in the new subforum:
http://www.domoticaforum.eu/viewtopic.php?f=87&t=11236
Did some new search on the solar thing. Apparently, the meter adapter wants S0 pulses plugged into it, next to the P1 data coming from the meter. Most likely it will need a firmware upgrade for that. The good News is that my power inverter already generates those pulses, so an extra (3 phase, in my case) kWh meter shouldn't be necessary.
Anyway, will have to get my machine cranked up properly again, first ...
I wouldn't call it useless. It's a thermostat, and with a small hack it gives you a lot of information about your energy status, for free. It's not a lot more expensive than a native thermostat for any boiler, with the same level of control flexibility.
Return to “Toon Rooting”
