Rooting Toon (or boxx)
Re: Rooting Toon
I also rooted my Toon tonight withJTAG, first of all Marcelr (and others) thanks for the extensive info!
As i did not have a JTAG interface i used my Rpi with openocd. I assume i'm not the only one with a Rpi lying around so here's the wiring info:
Toon --> RPI GPIO
1 --> NC (RTCK)
2 --> 24 (TRST)
3 --> 20 (GND)
4 --> 23 (TCK)
5 --> 6 (GND)
6 --> 22 (TMS)
7 --> 18 (SRST)
8 --> 19 (TDI)
9 --> NC (Vt)
10 --> 21 (TDO)
NC = Not Connected
I stumbled on the same problem as balans but the "reset halt" after the "soft_reset_halt" also fixed the issure for me.
Unrelated question:
i can't seem to unzip the x11vnc package. combining them with "cat" also does not help. Does anyone have the complete .ipk file for me?
Toon --> RPI GPIO
1 --> NC (RTCK)
2 --> 24 (TRST)
3 --> 20 (GND)
4 --> 23 (TCK)
5 --> 6 (GND)
6 --> 22 (TMS)
7 --> 18 (SRST)
8 --> 19 (TDI)
9 --> NC (Vt)
10 --> 21 (TDO)
NC = Not Connected
Unrelated question:
Re: Rooting Toon
I do, but please check whether your downloads are correct (look for size). It really should just work.Does anyone have the complete .ipk file for me?
BTW, thanks for the pinout, will add this to the rooting manual.
Re: Rooting Toon
Klaphekje, try to rename the file and try
This worked for me both on Toon and Windows
x11vnc.z01.zip to x11vnc.z01
cat x11vnc.z01 x11vnc.zip > x11vnc_complete.zip
Re: Rooting Toon
eneco-001:~# mv x11vnc.z01.zip x11vnc.z01
eneco-001:~# cat x11vnc.z01 x11vnc.zip > x11vnc_complete.zip
eneco-001-271875:~# ls -lah
drwxr-xr-x 3 root root 448 Feb 23 16:26 .
drwxr-xr-x 15 root root 1.2K Feb 22 18:43 ..
drwx------ 2 root root 232 Feb 22 18:58 .ssh
-rw-r--r-- 1 root root 256.0K Feb 23 16:21 x11vnc.z01
-rw-r--r-- 1 root root 185.2K Feb 23 16:21 x11vnc.zip
-rw-r--r-- 1 root root 441.2K Feb 23 16:26 x11vnc_complete.zip
eneco-001:~# unzip x11vnc_complete.zip
Archive: x11vnc_complete.zip
unzip: invalid zip magic 08074B50
Anyway, thanks for the help
Re: Rooting Toon
eneco-001-xxxxxx:~# opkg install dropbear_2015.71-r0_qb2.ipk
Collected errors:
* deb_extract: dropbear_2015.71-r0_qb2.ipk: invalid magic
* pkg_init_from_file: Failed to extract control file from dropbear_2015.71-r0_qb2.ipk.
any suggestions?
Re: Rooting Toon
You could check the md5 checksum of the installer file:
This should be the same as above, if not, download again.
$ md5sum dropbear_2015.71-r0_qb2.ipk
0385737390810f2b1bca1b25977821fc dropbear_2015.71-r0_qb2.ipk
Re: Rooting Toon
# md5sum dropbear_2015.71-r0_qb2.ipk
444079a1714215ad4fe75d73e0aa6ab7 dropbear_2015.71-r0_qb2.ipk
Re: Rooting Toon
yes, the checksum should be the same, not just the number of bytes in the checksum (that's always the same)
Like this:
... yours is different.
Not sure which software you used to download the code, the file size (after unZipping) should be: 125704 bytes
Like this:
Re: Rooting Toon
Tried again, unfortunalty same error for opkg install.
Checksum is the same now:
Also the file size, download is done via IE tot NAS.
Re: Rooting Toon
Try another browser; chrome, firefox, whatever.
Rooting Toon
So far no joy..
Tried Chrome, Firefox, raspberry pi browser...
Also tried some other packages, older dropbear and openssh-sftp-server_7.3p1-r10.0_qb2.zip
These files gave the same error when opkg install.
Strange thing I noticed, all downloads to toon take 5 minutes.
# opkg install dropbear_0.51-r7.0_qb2.ipk
Collected errors:
* deb_extract: dropbear_0.51-r7.0_qb2.ipk: invalid magic
* pkg_init_from_file: Failed to extract control file from dropbear_0.51-r7.0_qb2.ipk.
Collected errors:
Re: Rooting Toon
Can you send me those files?
Re: Rooting Toon
Marcelr see attachement.
thanks for the help so far!
- dropbear-openssh.rar
- (266.16 KiB) Downloaded 583 times
Re: Rooting Toon
Hmm....
I get the same md5sum (as the one I posted yesterday), after transfer to my toon (3.2.18) it just installs.
What firmware version is your toon?
How do you transfer the packages to toon?
Does the installer work at all?
When you type
or
on your toon, does that render something sensible?
When you type
opkg -h
opkg list
Re: Rooting Toon
* Kernel 2.6.36-R10-h25 (print_boot_msg)
* Firmware qb2/ene/3.6.3-1022-0
Transfering from Nas via: wget http://ip nas:21/public/dropbear_2015.71-r0_qb2.ipk
Not that experienced but looks sensible tot me...
eneco-001-xxxxxx:~# opkg -h
opkg: unrecognized option '-h'
opkg must have one sub-command argument
usage: opkg [options...] sub-command [arguments...]
where sub-command is one of:
Package Manipulation:
update Update list of available packages
upgrade Upgrade installed packages
install <pkgs> Install package(s)
configure <pkgs> Configure unpacked package(s)
remove <pkgs|regexp> Remove package(s)
flag <flag> <pkgs> Flag package(s)
<flag>=hold|noprune|user|ok|installed|unpacked (one per invocation)
Informational Commands:
list List available packages
list-installed List installed packages
list-upgradable List installed and upgradable packages
list-changed-conffiles List user modified configuration files
files <pkg> List files belonging to <pkg>
search <file|regexp> List package providing <file>
info [pkg|regexp] Display all info for <pkg>
status [pkg|regexp] Display all status for <pkg>
download <pkg> Download <pkg> to current directory
compare-versions <v1> <op> <v2>
compare versions using <= < > >= = << >>
print-architecture List installable package architectures
depends [-A] [pkgname|pat]+
whatdepends [-A] [pkgname|pat]+
whatdependsrec [-A] [pkgname|pat]+
whatrecommends[-A] [pkgname|pat]+
whatsuggests[-A] [pkgname|pat]+
whatprovides [-A] [pkgname|pat]+
whatconflicts [-A] [pkgname|pat]+
whatreplaces [-A] [pkgname|pat]+
Options:
-A Query all packages not just those installed
-V[<level>] Set verbosity level to <level>.
--verbosity[=<level>] Verbosity levels:
0 errors only
1 normal messages (default)
2 informative messages
3 debug
4 debug level 2
-f <conf_file> Use <conf_file> as the opkg configuration file
--conf <conf_file>
--cache <directory> Use a package cache
-d <dest_name> Use <dest_name> as the the root directory for
--dest <dest_name> package installation, removal, upgrading.
<dest_name> should be a defined dest name from
the configuration file, (but can also be a
directory name in a pinch).
-o <dir> Use <dir> as the root directory for
--offline-root <dir> offline installation of packages.
--add-arch <arch>:<prio> Register architecture with given priority
--add-dest <name>:<path> Register destination with given path
Force Options:
--force-depends Install/remove despite failed dependencies
--force-maintainer Overwrite preexisting config files
--force-reinstall Reinstall package(s)
--force-overwrite Overwrite files from other package(s)
--force-downgrade Allow opkg to downgrade packages
--force-space Disable free space checks
--force-postinstall Run postinstall scripts even in offline mode
--force-remove Remove package even if prerm script fails
--noaction No action -- test only
--download-only No action -- download only
--nodeps Do not follow dependencies
--force-removal-of-dependent-packages
Remove package and all dependencies
--autoremove Remove packages that were installed
automatically to satisfy dependencies
-t Specify tmp-dir.
--tmp-dir Specify tmp-dir.
regexp could be something like 'pkgname*' '*file*' or similar
e.g. opkg info 'libstd*' or opkg search '*libop*' or opkg remove 'libncur*'
eneco-001-xxxxxx:~# opkg list
base-files - 3.0.14-r100
base-passwd - 3.5.20-r1
base-qb2-ene - 3.6.3-1022-0
boot-logos - 1.64-ene
busybox - 1.18.3-r42.1
busybox-mountall - 1.18.3-r42.1
busybox-syslog - 1.18.3-r42.1
chrony - 1.27-r1
curl - 7.21.2-r5.0
directfb - 1.2.8-r1.0
firmware-ba - 1.40
firmware-ma - 1.88
firmware-zwave-ctrlr - 1.8-4.55-NrNfNm-noeep
flash-gui - 1.651-ene-qeio
flash-lite-adobe - 4.0.3-54-fb0
flash-qwidget-diy - 1.161-qeio
freetype - 2.4.3-r1
glibc - 2.10.1-r37.1
glibc-binary-localedata-de-de - 2.10.1-r37.1
glibc-binary-localedata-en-gb - 2.10.1-r37.1
glibc-binary-localedata-en-us - 2.10.1-r37.1
glibc-binary-localedata-es-es - 2.10.1-r37.1
glibc-binary-localedata-fr-fr - 2.10.1-r37.1
glibc-binary-localedata-it-it - 2.10.1-r37.1
glibc-binary-localedata-nl-nl - 2.10.1-r37.1
glibc-gconv - 2.10.1-r37.1
glibc-gconv-iso8859-1 - 2.10.1-r37.1
glibc-localedata-i18n - 2.10.1-r37.1
glibc-localedata-iso14651-t1 - 2.10.1-r37.1
glibc-localedata-iso14651-t1-common - 2.10.1-r37.1
glibc-localedata-translit-circle - 2.10.1-r37.1
glibc-localedata-translit-cjk-compat - 2.10.1-r37.1
glibc-localedata-translit-compat - 2.10.1-r37.1
glibc-localedata-translit-font - 2.10.1-r37.1
glibc-localedata-translit-fraction - 2.10.1-r37.1
glibc-localedata-translit-narrow - 2.10.1-r37.1
glibc-localedata-translit-neutral - 2.10.1-r37.1
glibc-localedata-translit-small - 2.10.1-r37.1
glibc-localedata-translit-wide - 2.10.1-r37.1
glibc-patch-dns - 2.10.1-r37.2
gnupg - 1.4.10-r3
gnutls - 2.10.4-r11.0
gpgme - 1.1.4-r5
gpgv - 1.4.10-r3
happ-eventmgr - 1.164-master
happ-kpi - 1.295-master
happ-pwrusage - 1.553-ene-master
happ-scsync - 1.196-ene-master
happ-smartplug - 1.146-master
happ-thermstat - 1.852-ene-master
happ-usermsg - 1.48-master
happ-weather - 1.111-master
hcb-bxtproxy - 1.107-master
hcb-comm - 1.165-TN-master
hcb-config - 1.264-master
hcb-log - 1.65-master
hcb-netcon - 1.246
hcb-rrd - 2.138-master
hcb-upnp - 1.87-master
hcb-watchdog - 1.44-master
hdrv-hue - 1.86-master
hdrv-p1 - 1.479-master
hdrv-zwave - 1.850-master
i2c-tools - 3.0.3-r0
initscripts - 1.2-r6-runlvls
iptables - 1.4.9.1-r7.1
jansson - 1.3-r1.0
joe - 3.1-r3
jpeg - 8b-r1
kernel - 2.6.36-R10-h25
kernel-image - 2.6.36-R10-h25
kernel-module-fat - 2.6.36-R10-h25
kernel-module-ftdi-sio - 2.6.36-R10-h25
kernel-module-msdos - 2.6.36-R10-h25
kernel-module-pl2303 - 2.6.36-R10-h25
kernel-module-rt5370sta - 2.6.36-R10-h25
kernel-module-rt5370sta-cfg - 2.6.36-R10-h25
kernel-module-rtl8191su - 2.6.36-R10-h25
kernel-module-vfat - 2.6.36-R10-h25
kernel-module-zwave300 - 2.6.36-R10-h25
less - 436-r1
libbz2 - 1.0.6-r0
libcrypto - 0.9.8m-r14.1
libcurl - 7.21.2-r5.0
libgcc - 4.5-r33.1+svnr170443
libgcrypt - 1.4.1-r0
libgpg-error - 1.4-r7.1
libhcb-base - 1.232-master
libhcb-boxtalk - 1.107-master
libhcb-com - 1.108-TN-master
libhcb-drv - 1.295-master
libhcb-xml - 1.93-master
libnetfilter-conntrack - 0.0.101-r0
libnfnetlink - 1.0.0-r0.0
libopkg - 0.1.8+svns635-r7-gcv
libpcre - 7.6-r8
libpng12 - 1.2.44-r3.0
libssl - 0.9.8m-r14.1
libstdc++ - 4.5-r33.1+svnr170443
libsysfs - 2.1.0-r3
libuuid - 2.18-r36.0
lighttpd - 1.4.33-17
lighttpd-mod-hcb-web - 1.4.33-26
locale-base-de-de - 2.10.1-r37.1
locale-base-en-gb - 2.10.1-r37.1
locale-base-en-us - 2.10.1-r37.1
locale-base-es-es - 2.10.1-r37.1
locale-base-fr-fr - 2.10.1-r37.1
locale-base-it-it - 2.10.1-r37.1
locale-base-nl-nl - 2.10.1-r37.1
lzo2 - 2.03-r0
makedevs - 1.0.0-r10
module-init-tools - 3.12-r6
module-init-tools-depmod - 3.12-r6
modutils-initscripts - 1.0-r3
mtd-utils - 1.4.1-r0
ncurses - 5.7+20110115-r16
ncurses-libncurses - 5.7+20110115-r16
ncurses-libtinfo - 5.7+20110115-r16
ncurses-terminfo - 5.7+20110115-r16
ncurses-terminfo-base - 5.7+20110115-r16
netbase - 4.21-r50
openssl - 0.9.8m-r14.1
openssl-conf - 0.9.8m-r14.1
openvpn - 2.3.6-r2.1
opkg-collateral - 1.0-r3
pointercal - 0.0-r22
pth - 2.0.2-r2
qt-gui - 1.6144-ene-develop
qt-libs - 5.3.1-06-setpos
readline - 5.2-r8
samba-nmbd - 3.0.20-r8
sysvinit - 2.86-r63
sysvinit-inittab - 2.86-r63
sysvinit-pidof - 2.86-r63
sysvinit-utils - 2.86-r63
tslib - 1.0-r28.7hae
tslib-calibrate - 1.0-r28.7hae
tslib-conf - 1.0-r28.7hae
tzdata-americas - 2011b-r8.0
tzdata-europe - 2011b-r8.0
update-modules - 1.0-r10
update-rc.d - 0.7-r2
wget - 1.12-r8.2
wireless-tools - 29-r5
wpa-supplicant - 2.0-r3
wpa-supplicant-cli - 2.0-r3
wpa-supplicant-passphrase - 2.0-r3
www-jquery-ui - 1.8.21-16
www-resources - 1.16
zlib - 1.2.3-r7.0
