Toonz and I compiled a set of guidelines for submission of toonstore apps. Please find these guidelines here:
viewtopic.php?f=87&t=11235#p83091
Yes, when you feel ready for it...TheHogNL wrote: The code is far from complete. Still need a lot of santizing. But it works and I can share it. Better to create a new topic from now I guess?
And a warm welcome to the dev community.
- Member
Hi all. I made my first app! It is showing images from my webcam on a Toon tile. If you click on the tile you get a fullscreen image of the webcam.
The app uses the fact that my webcam has an URL with the latest jpg image. The images are refreshed every 10s for now. If I refresh more quickly the Toon processor is too heavily loaded. I would like to have the refresh rate for the full screen somewhat faster than for the tile, but I am afraid my programming skills hold me back
. So if someone wants to look into the code and help out ... very much appreciated !
- webcam.zip
- (4.88 KiB) Downloaded 527 times
- Administrator
Nice work! Haven’t heard anyone about this idea so far!makkie2002 wrote:Hi all. I made my first app! It is showing images from my webcam on a Toon tile. If you click on the tile you get a fullscreen image of the webcam.
The app uses the fact that my webcam has an URL with the latest jpg image. The images are refreshed every 10s for now. If I refresh more quickly the Toon processor is too heavily loaded. I would like to have the refresh rate for the full screen somewhat faster than for the tile, but I am afraid my programming skills hold me back. So if someone wants to look into the code and help out ... very much appreciated !
Can you make a settings part in the app so I can edit the IP/Port/image url via the Toon itself? Like in the Sonos app
Would be nice to have it in the ToonStore also!
- Member
I will have to study some other apps to get this functionality in ... but I will manageCan you make a settings part in the app so I can edit the IP/Port/image url via the Toon itself? Like in the Sonos app
- Member
I was just wondering ... since qml is able to run javascript code ... is it possible to use a MQTT javascript library and add mqtt functionality to Toon https://eclipse.org/paho/clients/js/?
This would greatly easy integration with other home automation system anyone should have as we could link measured temperature as well as the temperature to a MQTT variable for automatic syncing over all devices.
- Member
Mosquitto can be installed through opkg
libmosquitto - 1.4.9-r0 - Mosquitto is an open source (BSD licensed) message broker that implements the MQ Telemetry Transport protocol version 3.1. MQTT provides a lightweight method of carrying out messaging using a publish/subscribe model.
libmosquittopp1 - 1.4.9-r0 - Mosquitto is an open source (BSD licensed) message broker that implements the MQ Telemetry Transport protocol version 3.1. MQTT provides a lightweight method of carrying out messaging using a publish/subscribe model.
mosquitto-clients - 1.4.9-r0 - Mosquitto is an open source (BSD licensed) message broker that implements the MQ Telemetry Transport protocol version 3.1. MQTT provides a lightweight method of carrying out messaging using a publish/subscribe model.
Any idea where I can find a bitbake recipe for it?
- Member
Could be, will try.
- Member
How do I do that?Mosquitto can be installed through opkg
I think my repositories are only limited to this forum?
How do I get other repositories?
eneco-xyz:~# opkg update
Downloading http://files.domoticaforum.eu/uploads/Toon/apps/wastecollection-2.2/Packages.gz.
Inflating http://files.domoticaforum.eu/uploads/Toon/apps/wastecollection-2.2/Packages.gz.
Updated list of available packages in /var/lib/opkg/tsc1.
Downloading http://files.domoticaforum.eu/uploads/Toon/apps/wastecollection-2.2/Packages.sig.
Signature check passed.
Downloading http://files.domoticaforum.eu/uploads/Toon/apps/toonstore-0.9.5/Packages.gz.
Inflating http://files.domoticaforum.eu/uploads/Toon/apps/toonstore-0.9.5/Packages.gz.
Updated list of available packages in /var/lib/opkg/tsc2.
Downloading http://files.domoticaforum.eu/uploads/Toon/apps/toonstore-0.9.5/Packages.sig.
Small question, where are located on the toon the different qt library's that are used inside the apps?
__________________
/usr/lib/Qt-5.3.1/lib
You can't.makkie2002 wrote:How do I do that?Mosquitto can be installed through opkg
You have installed toonstore, which cuts the connection between your toon and eneco.
To restore the connection, you will have to remove the toonstore.
That will not help you, because mosquito is not part of the openembedded tree for toon, so there is no package to install, from any repository. It is true that there is a bitbake recipe for mosquito, but that needs to be inserted into the openembedded tree for toon, and subsequently used to build the mosquito package(s).
I tried that last week, but the build fails with some major errors.
Is it possible to use the QT creator to build app's? I have already try to import an existing one but get serval errors that the librarys not can been loaded.
__________________
