Toon app: Buienradar
makkie2002
Re: Toon app: Buienradar
Post by makkie2002 »
Toonz,
Thank you for the buienradar app, love it !
One thing I noticed early this morning is that the 5 day weather predictions (the icons, not the text) is missing the current day.
It would be nice to have a quick look at the screen and get the max temperature and weather type of the day that is still to unfold :).
Another thing: luckily I live in the north of Belgium and I can set the weatherstation to Eindhoven and get weather data relatively representative for my place!
Fellow counrtymen that live further from the border with Netherlands or out of luck with this app.
Maybe it is worthwile to think about a more international weather app and use data provided by free weather API's: superdevresources.com/weather-forecast- ... ping-apps/.
Just a suggestion. I am afraid my qml programming skills are too limited to pull this off on my own.
makkie2002 wrote:Toonz,
Hi makkie2002,
I am only displaying the data which is provided in xml.buienradar.nl.
The 5-day weather forecast is for the next 5 days, current day is not included in that format at all.
I will have a look at the international weather stuff but that will be a different application, next to buienradar.
Thanks for the hint.
makkie2002
I already thought this was the reason :mrgreen:
But maybe there is a solution! Wouldn't it be possible to "remember" the prediction of today's weather from the predictions from yesterday? Hope you understand what I mean ...
Can be done but how accurate would it be compared to actuals during the day.... But will keep it in mind (no promises)
makkie2002
Toonz, it does not have to be accurate because it is a prediction of the day that is unfolding.
Imagine in the morning you get up 7am and you go to the thermostat ... the actual outside temperature could be 15°, but it would be nice to know if the rest of the day we could expect 30° as maximum temperature :)
You could take the information from yr.no.
The Norwegian met office publishes weather forecasts for most of western Europe in xml format, with hour-by-hour granularity. Just pop in your GPS coordinates, and off you go.
Guys, thanks for all your input. I wasn't aware about the norwegian site.
They provide a wealth of information for sure. But that will likely qualify for a new app ('International Weather').
Back to buienradar, it is relatively easy to remember today's prediction and there is room on the screen to display it.
I just plan to keep that data in memory, meaning that if you reboot the gui you will not see todays prediction anymore until somewhere after midnight (normally between 00:30 and 01:00).
makkie2002
Toonz,
You got my support for an international weather app!
And I am happy to hear that you looked into the effort needed to implement the forcast of the current day into the buienradar app :) !
Great work!
TerrorSource
Post by TerrorSource »
Great work!
Well, i would love a international version too! Put my holiday city in it so i can imagen myself in the sun every day :D
makkie2002
You are welcome in Mol, but the sun might be an issue 8)
A new version of buienradar (8.0.9) will hit the ToonStore soon.
In this release 'today' is added to the 5 days forecast table (thanks for the hint makkie2002).
Because buienradar is not providing the forecast for today in this format, the last forecast for today which was published yesterday is shown.
This also means that after each gui restart, this column is empty and will be populated again from the next day onwards.
hayman
Post by hayman »
thanks for the app,
after update to 8.0.8 i didn't get any update about the weather only the (!) should i delet the old version befor install the new one ..?
thanks
If you have installed the earlier version via the ToonStore then you don't need to do anything. The installer of the ToonStore will take care of the removal of the old version.
In general it is advised to remove manually installed versions of apps which you plan to install via ToonStore going forward.
I learned today that Buienradar 8.0.8 and higher are not compatible with firmwares below 4.x.
I will have a look later how to proceed.
makkie2002
Installed! ... thanks for the modification :D
