Moderators: Rene, Willem4ever
Hi, is it possible to "arm away" or "arm home" in instant mode with this app?
I use it with "arm home" at night, to make perimeter sensors around house work without "entry delay".
According this, PowerMax plugin for Vera can do it and use same interface, http://code.mios.com/trac/mios_visonic-powermax
thanks.
thanks.
- Advanced Member
- Contact:
I think this can be done by scripting in domoticz but dont use domoticz myself.
(ON ESXI )on NUC
(ON ESXI )on NUC
I would like to use the PIR to turn on and off lights when it is not arm and detect motion. The issue is that the PIR is detecting motion and the is reset very fast. I know that I can set the reset time on the PIR. But is it not possible to config the PIR to keep in "detect motion" state as long as there is movement?
Thanks
/Claus
Thanks
/Claus
- Advanced Member
- Contact:
No sorry this is how the visonic panel is designed...
(ON ESXI )on NUC
(ON ESXI )on NUC
I have a MCM-140 unit. Visonic driver setting does not seem to register when I arm and disarm.
Am I not able to see events when I use MCM-140 remote keypad?
Thanks
/Claus
Thanks
/Claus
- Advanced Member
- Contact:
claus,Blaabjerg wrote:Hi,
Thanks
/Claus
NO, first of all the panel events will be registered whatever used, but you can even trigger events on use of the MCW-140 (disarm/arm etc) as a separate event. I use them as well (2 of them) and this works great. So my panel status updates in HS3 obviously, but I also created to virtual devices which shows me when and which mcw-140 is used to arm/disarm.
bart
(ON ESXI )on NUC
(ON ESXI )on NUC
Ok. But can you detect witch user / kode that have disarmed / armed the alarm?bartbakels wrote:claus,Blaabjerg wrote:Hi,
Thanks
/Claus
bart
/Claus
I'm able to run the DISARM_[securityAdditionString] to disarm my alarm. But i would like to detect witch user that disarm my alarm.
Is that possible?
Ex: DISARM_[USERCODE]
Thanks
Regards
Claus
Is that possible?
Thanks
Regards
Claus
- Advanced Member
- Contact:
Claus,Blaabjerg wrote:I'm able to run the DISARM_[securityAdditionString] to disarm my alarm. But i would like to detect witch user that disarm my alarm.
Is that possible?
Thanks
Regards
Claus
sorry for the late response, again I didn't get an update from the board, and was on holiday
I far as I know I cant detect the used usercode, however I don't use this my self. I have similar functionality but I use keyfobs, proxytags and wireless commanders. These can be userspecific off course, and I defined in the user event config tab the following actions;
keyfob 3 arm home httpcall1
keyfob 4 disarm httpcall2
to determine the actions of these devices and report these back to hs3, or vera, domoticz etc.
hope this helps?
Bart
(ON ESXI )on NUC
(ON ESXI )on NUC
Yes, I have also configured my keyforbs like that. But ex. a wireless commander can have multiple users entering a code. And that could be cool get what number that have been entered, because then I know with user who have disarm/armed the alarm.bartbakels wrote:Claus,Blaabjerg wrote:I'm able to run the DISARM_[securityAdditionString] to disarm my alarm. But i would like to detect witch user that disarm my alarm.
Is that possible?
Thanks
Regards
Claus
hope this helps?
Bart
Do you use HS3?
If you do, do you know if it is possible to disarm the alarm from a tablet interface (On a security panel) with the user code that have been assigned in the Powermax alarm?
Thanks
/Claus
- Advanced Member
- Contact:
claus,
No its not possible to determine which code is used on the keypads. These codes are not stored in the panel but in the keypad itself.
Yes im using Hs3, and you can create an HStopucyh window to arm and disarm, but again, i cant extract the codes from the panel, to do so. You could create your own codeentry object in hstouch probably with stored codes.
regards
Bart
regards
Bart
(ON ESXI )on NUC
(ON ESXI )on NUC
- Member
Getting armed status from HS3
Hi Bart
Sometimes HS3 looses sync with the visonic driver status (armed, disarmed, arm, home, etc). How can I get the armed status from HS?
I tried http://ip:3011/VisonicDriver/jsonget?se ... tionString but it only returns {"Alarm":"FALSE","Alert in memory":"FALSE","Arm/disarm":"FALSE","ByPass":"FALSE","Last 10 seconds delay":"FALSE","Log Events":"","Ready":"FALSE","System Status":"","Trouble":"FALSE","Zone Event":"FALSE","Zone/User":"","ZoneEvent Types":"","Zones State":]} without status about the arm status.
Also, anyway to do something similar to get the status of each zone?
Thank you.
Mario
Thank you.
Mario
- Member
Hi Bart.
I still have this issue with many errors each hour I suspect it has something to do with the loss of sync I suffer from time to time (maybe the program isn't processing communications with the popup with the error appears?).
It's a serious problem for me now as my system each time relies more on the data received from my Powermax system. Look at the frequency of errors:
2018-03-16 10:02:29,314 VisonicDriver.exe error 56 0 LabVIEW: The network operation exceeded the user-specified or system time limit.
HTTP GET TCP Read in Example HTTP GET method.vi->Zones ChangeHandler.vi->SensorStatesHandler.vi->decode hex.vi->VISONIC DAQ.vi->Visonic MAIN.vi
2018-03-16 10:02:36,080 VisonicDriver.exe error 56 0 LabVIEW: The network operation exceeded the user-specified or system time limit.
2018-03-16 10:09:37,448 VisonicDriver.exe error 56 0 LabVIEW: The network operation exceeded the user-specified or system time limit.
2018-03-16 10:09:44,363 VisonicDriver.exe error 56 0 LabVIEW: The network operation exceeded the user-specified or system time limit.
2018-03-16 10:10:49,563 VisonicDriver.exe error 56 0 LabVIEW: The network operation exceeded the user-specified or system time limit.
HTTP GET TCP Read in Example HTTP GET method.vi->Zones ChangeHandler.vi->SensorStatesHandler.vi->VISONIC GUI.vi->Visonic MAIN.vi
2018-03-16 10:11:00,020 VisonicDriver.exe error 56 0 LabVIEW: The network operation exceeded the user-specified or system time limit.
2018-03-16 10:11:09,294 VisonicDriver.exe error 56 0 LabVIEW: The network operation exceeded the user-specified or system time limit.
2018-03-16 10:11:19,102 VisonicDriver.exe error 56 0 LabVIEW: The network operation exceeded the user-specified or system time limit.
2018-03-16 10:11:51,132 VisonicDriver.exe error 56 0 LabVIEW: The network operation exceeded the user-specified or system time limit.
2018-03-16 10:11:59,849 VisonicDriver.exe error 56 0 LabVIEW: The network operation exceeded the user-specified or system time limit.
2018-03-16 10:14:14,969 VisonicDriver.exe error 56 0 LabVIEW: The network operation exceeded the user-specified or system time limit.
2018-03-16 10:14:20,806 VisonicDriver.exe error 56 0 LabVIEW: The network operation exceeded the user-specified or system time limit.
2018-03-16 10:15:49,397 VisonicDriver.exe error 56 0 LabVIEW: The network operation exceeded the user-specified or system time limit.
2018-03-16 10:15:56,098 VisonicDriver.exe error 56 0 LabVIEW: The network operation exceeded the user-specified or system time limit.
2018-03-16 10:16:03,489 VisonicDriver.exe error 56 0 LabVIEW: The network operation exceeded the user-specified or system time limit.
2018-03-16 10:16:31,687 VisonicDriver.exe error 56 0 LabVIEW: The network operation exceeded the user-specified or system time limit.
2018-03-16 10:21:46,918 VisonicDriver.exe error 56 0 LabVIEW: The network operation exceeded the user-specified or system time limit.
2018-03-16 10:21:55,747 VisonicDriver.exe error 56 0 LabVIEW: The network operation exceeded the user-specified or system time limit.
2018-03-16 10:22:04,561 VisonicDriver.exe error 56 0 LabVIEW: The network operation exceeded the user-specified or system time limit.
2018-03-16 10:22:29,303 VisonicDriver.exe error 56 0 LabVIEW: The network operation exceeded the user-specified or system time limit.
2018-03-16 10:29:39,007 VisonicDriver.exe error 56 0 LabVIEW: The network operation exceeded the user-specified or system time limit.
2018-03-16 10:29:48,042 VisonicDriver.exe error 56 0 LabVIEW: The network operation exceeded the user-specified or system time limit.
2018-03-16 10:29:55,430 VisonicDriver.exe error 56 0 LabVIEW: The network operation exceeded the user-specified or system time limit.
2018-03-16 10:30:24,641 VisonicDriver.exe error 56 0 LabVIEW: The network operation exceeded the user-specified or system time limit.
2018-03-16 10:35:03,600 VisonicDriver.exe error 56 0 LabVIEW: The network operation exceeded the user-specified or system time limit.
2018-03-16 10:35:11,330 VisonicDriver.exe error 56 0 LabVIEW: The network operation exceeded the user-specified or system time limit.
2018-03-16 10:35:18,411 VisonicDriver.exe error 56 0 LabVIEW: The network operation exceeded the user-specified or system time limit.
2018-03-16 10:35:41,723 VisonicDriver.exe error 56 0 LabVIEW: The network operation exceeded the user-specified or system time limit.
2018-03-16 10:37:32,898 VisonicDriver.exe error 56 0 LabVIEW: The network operation exceeded the user-specified or system time limit.
2018-03-16 10:37:39,071 VisonicDriver.exe error 56 0 LabVIEW: The network operation exceeded the user-specified or system time limit.
2018-03-16 10:37:49,201 VisonicDriver.exe error 56 0 LabVIEW: The network operation exceeded the user-specified or system time limit.
bartbakels wrote:Mario,
First the easy part, The error, is an error when the http get call can not be exectuted, probably you have a wrong url in the configurations somewhere, check the http calls you make if they are all correct.
regarding your zones, i have an idea, but is it correct that you now have for example zone 1 until 15 in use and zone 20, and 16 until 19 are not in use?
Bart
Mario from Spain wrote:Hi Bart.bartbakels wrote:released new version;
v1.0.7 Release With Build IN Webserver Installer Location V1.0.7 UPDATED
Changes
- BUG in HTTP GET which prevented Get command with (") and spaces
- Signal strength indicator of sensors available
MARIO please try this build for your HTTP Get Issue
Bart
I'm back from my vacation trip (good things are always very short).
Tried the HTTP GET issue with (") and spaces with the new 1.0.7 version and it's working fine now. Thank you!![]()
One of my sensors (zone 20) where not reporting correctly (can see the Open and Close events in the log but Last change was always 00:00:00.000 and didn't call the HTTP URL. I deleted the sensor and recreated it as zone 21 and now it's working fine. I'm not sure if the fault was on my Powermax system or in the Visonic Driver but it looks to me like a bug in the Visonic Driver affecting Zone 20 (don't know for sure if all other zones are working fine as I use just 15 zones out of the 28 my panel permits).
I still get this error very often (I don't thing it's related to previous issue):
2016-07-07 14:19:19,179 VisonicDriver.exe error 56 0 LabVIEW: The network operation exceeded the user-specified or system time limit. HTTP GET TCP Read in Example HTTP GET method.vi->Zones ChangeHandler.vi->SensorStatesHandler.vi->decode hex.vi->VISONIC DAQ.vi->Visonic MAIN.vi 2016-07-09 15:20:21,185 VisonicDriver.exe error 56 0 LabVIEW: The network operation exceeded the user-specified or system time limit. HTTP GET TCP Read in Example HTTP GET method.vi->Zones ChangeHandler.vi->SensorStatesHandler.vi->decode hex.vi->VISONIC DAQ.vi->Visonic MAIN.vi 2016-07-09 15:36:28,743 VisonicDriver.exe error 56 0 LabVIEW: The network operation exceeded the user-specified or system time limit. HTTP GET TCP Read in Example HTTP GET method.vi->Zones ChangeHandler.vi->SensorStatesHandler.vi->decode hex.vi->VISONIC DAQ.vi->Visonic MAIN.vi 2016-07-11 09:53:10,209 VisonicDriver.exe error 56 0 LabVIEW: The network operation exceeded the user-specified or system time limit. HTTP GET TCP Read in Example HTTP GET method.vi->Zones ChangeHandler.vi->SensorStatesHandler.vi->decode hex.vi->VISONIC DAQ.vi->Visonic MAIN.vi 2016-07-11 10:01:13,140 VisonicDriver.exe error 56 0 LabVIEW: The network operation exceeded the user-specified or system time limit. HTTP GET TCP Read in Example HTTP GET method.vi->Zones ChangeHandler.vi->SensorStatesHandler.vi->decode hex.vi->VISONIC DAQ.vi->Visonic MAIN.vi 2016-07-17 09:36:56,728 VisonicDriver.exe error 56 0 LabVIEW: The network operation exceeded the user-specified or system time limit. HTTP GET TCP Read in Example HTTP GET method.vi->Zones ChangeHandler.vi->SensorStatesHandler.vi->decode hex.vi->VISONIC DAQ.vi->Visonic MAIN.vi 2016-07-19 10:08:46,858 VisonicDriver.exe error 56 0 LabVIEW: The network operation exceeded the user-specified or system time limit. HTTP GET TCP Read in Example HTTP GET method.vi->Zones ChangeHandler.vi->SensorStatesHandler.vi->decode hex.vi->VISONIC DAQ.vi->Visonic MAIN.vi 2016-07-19 15:53:02,932 VisonicDriver.exe error 56 0 LabVIEW: The network operation exceeded the user-specified or system time limit. HTTP GET TCP Read in Example HTTP GET method.vi->Zones ChangeHandler.vi->SensorStatesHandler.vi->decode hex.vi->VISONIC DAQ.vi->Visonic MAIN.vi 2016-07-21 09:57:08,998 VisonicDriver.exe error 56 0 LabVIEW: The network operation exceeded the user-specified or system time limit. HTTP GET TCP Read in Example HTTP GET method.vi->Zones ChangeHandler.vi->SensorStatesHandler.vi->decode hex.vi->VISONIC DAQ.vi->Visonic MAIN.vi 2016-07-24 09:40:17,615 VisonicDriver.exe error 56 0 LabVIEW: The network operation exceeded the user-specified or system time limit. HTTP GET TCP Read in Example HTTP GET method.vi->Zones ChangeHandler.vi->SensorStatesHandler.vi->decode hex.vi->VISONIC DAQ.vi->Visonic MAIN.vi 2016-07-25 04:08:30,888 VisonicDriver.exe error 56 0 LabVIEW: The network operation exceeded the user-specified or system time limit. HTTP GET TCP Read in Example HTTP GET method.vi->Zones ChangeHandler.vi->SensorStatesHandler.vi->decode hex.vi->VISONIC DAQ.vi->Visonic MAIN.vi 2016-07-25 23:12:17,631 VisonicDriver.exe error 56 0 LabVIEW: The network operation exceeded the user-specified or system time limit. HTTP GET TCP Read in Example HTTP GET method.vi->Zones ChangeHandler.vi->SensorStatesHandler.vi->decode hex.vi->VISONIC DAQ.vi->Visonic MAIN.vi 2016-07-26 03:40:49,023 VisonicDriver.exe error 56 0 LabVIEW: The network operation exceeded the user-specified or system time limit. HTTP GET TCP Read in Example HTTP GET method.vi->Zones ChangeHandler.vi->SensorStatesHandler.vi->decode hex.vi->VISONIC DAQ.vi->Visonic MAIN.vi 2016-07-27 10:03:06,990 VisonicDriver.exe error 56 0 LabVIEW: The network operation exceeded the user-specified or system time limit. HTTP GET TCP Read in Example HTTP GET method.vi->Zones ChangeHandler.vi->SensorStatesHandler.vi->decode hex.vi->VISONIC DAQ.vi->Visonic MAIN.vi 2016-07-27 10:49:39,349 VisonicDriver.exe error 56 0 LabVIEW: The network operation exceeded the user-specified or system time limit. HTTP GET TCP Read in Example HTTP GET method.vi->Zones ChangeHandler.vi->SensorStatesHandler.vi->decode hex.vi->VISONIC DAQ.vi->Visonic MAIN.vi 2016-07-27 10:49:44,889 VisonicDriver.exe error 56 0 LabVIEW: The network operation exceeded the user-specified or system time limit. HTTP GET TCP Read in Example HTTP GET method.vi->Zones ChangeHandler.vi->SensorStatesHandler.vi->decode hex.vi->VISONIC DAQ.vi->Visonic MAIN.vi 2016-07-27 10:49:50,285 VisonicDriver.exe error 56 0 LabVIEW: The network operation exceeded the user-specified or system time limit. HTTP GET TCP Read in Example HTTP GET method.vi->Zones ChangeHandler.vi->SensorStatesHandler.vi->decode hex.vi->VISONIC DAQ.vi->Visonic MAIN.vi 2016-07-27 10:51:43,563 VisonicDriver.exe error 56 0 LabVIEW: The network operation exceeded the user-specified or system time limit. HTTP GET TCP Read in Example HTTP GET method.vi->Zones ChangeHandler.vi->SensorStatesHandler.vi->decode hex.vi->VISONIC DAQ.vi->Visonic MAIN.vi 2016-07-27 10:52:11,349 VisonicDriver.exe error 56 0 LabVIEW: The network operation exceeded the user-specified or system time limit. HTTP GET TCP Read in Example HTTP GET method.vi->Zones ChangeHandler.vi->SensorStatesHandler.vi->VISONIC CONTROL.vi->Visonic MAIN.vi 2016-07-27 11:06:46,550 VisonicDriver.exe error 56 0 LabVIEW: The network operation exceeded the user-specified or system time limit. HTTP GET TCP Read in Example HTTP GET method.vi->Zones ChangeHandler.vi->SensorStatesHandler.vi->VISONIC CONTROL.vi->Visonic MAIN.vi 2016-07-27 11:06:48,434 VisonicDriver.exe error 56 0 LabVIEW: The network operation exceeded the user-specified or system time limit. HTTP GET TCP Read in Example HTTP GET method.vi->Zones ChangeHandler.vi->SensorStatesHandler.vi->decode hex.vi->VISONIC DAQ.vi->Visonic MAIN.vi 2016-07-27 11:06:49,572 VisonicDriver.exe error 56 0 LabVIEW: The network operation exceeded the user-specified or system time limit. HTTP GET TCP Read in Example HTTP GET method.vi->Zones ChangeHandler.vi->SensorStatesHandler.vi->decode hex.vi->VISONIC DAQ.vi->Visonic MAIN.vi 2016-07-27 11:07:18,802 VisonicDriver.exe error 56 0 LabVIEW: The network operation exceeded the user-specified or system time limit. HTTP GET TCP Read in Example HTTP GET method.vi->Zones ChangeHandler.vi->SensorStatesHandler.vi->VISONIC CONTROL.vi->Visonic MAIN.vi 2016-07-27 11:10:18,299 VisonicDriver.exe error 56 0 LabVIEW: The network operation exceeded the user-specified or system time limit. HTTP GET TCP Read in Example HTTP GET method.vi->Zones ChangeHandler.vi->SensorStatesHandler.vi->decode hex.vi->VISONIC DAQ.vi->Visonic MAIN.vi 2016-07-27 11:11:27,691 VisonicDriver.exe error 56 0 LabVIEW: The network operation exceeded the user-specified or system time limit. HTTP GET TCP Read in Example HTTP GET method.vi->Zones ChangeHandler.vi->SensorStatesHandler.vi->decode hex.vi->VISONIC DAQ.vi->Visonic MAIN.vi 2016-07-27 11:11:45,525 VisonicDriver.exe error 56 0 LabVIEW: The network operation exceeded the user-specified or system time limit. HTTP GET TCP Read in Example HTTP GET method.vi->Zones ChangeHandler.vi->SensorStatesHandler.vi->decode hex.vi->VISONIC DAQ.vi->Visonic MAIN.vi 2016-07-27 11:12:12,608 VisonicDriver.exe error 56 0 LabVIEW: The network operation exceeded the user-specified or system time limit. HTTP GET TCP Read in Example HTTP GET method.vi->Zones ChangeHandler.vi->SensorStatesHandler.vi->VISONIC GUI.vi->Visonic MAIN.vi 2016-07-27 11:21:44,812 VisonicDriver.exe error 56 0 LabVIEW: The network operation exceeded the user-specified or system time limit. HTTP GET TCP Read in Example HTTP GET method.vi->Zones ChangeHandler.vi->SensorStatesHandler.vi->decode hex.vi->VISONIC DAQ.vi->Visonic MAIN.vi 2016-07-27 11:22:58,424 VisonicDriver.exe error 56 0 LabVIEW: The network operation exceeded the user-specified or system time limit. HTTP GET TCP Read in Example HTTP GET method.vi->Zones ChangeHandler.vi->SensorStatesHandler.vi->decode hex.vi->VISONIC DAQ.vi->Visonic MAIN.vi 2016-07-27 11:23:26,228 VisonicDriver.exe error 56 0 LabVIEW: The network operation exceeded the user-specified or system time limit. HTTP GET TCP Read in Example HTTP GET method.vi->Zones ChangeHandler.vi->SensorStatesHandler.vi->VISONIC CONTROL.vi->Visonic MAIN.vi 2016-07-27 11:24:54,174 VisonicDriver.exe error 56 0 LabVIEW: The network operation exceeded the user-specified or system time limit. HTTP GET TCP Read in Example HTTP GET method.vi->Zones ChangeHandler.vi->SensorStatesHandler.vi->decode hex.vi->VISONIC DAQ.vi->Visonic MAIN.vi 2016-07-27 11:25:18,502 VisonicDriver.exe error 56 0 LabVIEW: The network operation exceeded the user-specified or system time limit. HTTP GET TCP Read in Example HTTP GET method.vi->Zones ChangeHandler.vi->SensorStatesHandler.vi->decode hex.vi->VISONIC DAQ.vi->Visonic MAIN.vi 2016-07-27 11:29:13,624 VisonicDriver.exe error 56 0 LabVIEW: The network operation exceeded the user-specified or system time limit. HTTP GET TCP Read in Example HTTP GET method.vi->Zones ChangeHandler.vi->SensorStatesHandler.vi->decode hex.vi->VISONIC DAQ.vi->Visonic MAIN.vi 2016-07-27 11:30:20,142 VisonicDriver.exe error 56 0 LabVIEW: The network operation exceeded the user-specified or system time limit. HTTP GET TCP Read in Example HTTP GET method.vi->Zones ChangeHandler.vi->SensorStatesHandler.vi->decode hex.vi->VISONIC DAQ.vi->Visonic MAIN.vi 2016-07-27 11:30:48,220 VisonicDriver.exe error 56 0 LabVIEW: The network operation exceeded the user-specified or system time limit. HTTP GET TCP Read in Example HTTP GET method.vi->Zones ChangeHandler.vi->SensorStatesHandler.vi->VISONIC CONTROL.vi->Visonic MAIN.vi 2016-07-27 11:34:46,448 VisonicDriver.exe error 56 0 LabVIEW: The network operation exceeded the user-specified or system time limit. HTTP GET TCP Read in Example HTTP GET method.vi->Zones ChangeHandler.vi->SensorStatesHandler.vi->decode hex.vi->VISONIC DAQ.vi->Visonic MAIN.vi 2016-07-27 11:37:33,806 VisonicDriver.exe error 56 0 LabVIEW: The network operation exceeded the user-specified or system time limit. HTTP GET TCP Read in Example HTTP GET method.vi->Zones ChangeHandler.vi->SensorStatesHandler.vi->decode hex.vi->VISONIC DAQ.vi->Visonic MAIN.vi 2016-07-27 11:40:08,695 VisonicDriver.exe error 56 0 LabVIEW: The network operation exceeded the user-specified or system time limit. HTTP GET TCP Read in Example HTTP GET method.vi->Zones ChangeHandler.vi->SensorStatesHandler.vi->decode hex.vi->VISONIC DAQ.vi->Visonic MAIN.vi 2016-07-27 11:40:57,669 VisonicDriver.exe error 56 0 LabVIEW: The network operation exceeded the user-specified or system time limit. HTTP GET TCP Read in Example HTTP GET method.vi->Zones ChangeHandler.vi->SensorStatesHandler.vi->decode hex.vi->VISONIC DAQ.vi->Visonic MAIN.vi 2016-07-27 11:42:41,710 VisonicDriver.exe error 56 0 LabVIEW: The network operation exceeded the user-specified or system time limit. HTTP GET TCP Read in Example HTTP GET method.vi->Zones ChangeHandler.vi->SensorStatesHandler.vi->decode hex.vi->VISONIC DAQ.vi->Visonic MAIN.vi 2016-07-27 11:44:04,358 VisonicDriver.exe error 56 0 LabVIEW: The network operation exceeded the user-specified or system time limit. HTTP GET TCP Read in Example HTTP GET method.vi->Zones ChangeHandler.vi->SensorStatesHandler.vi->decode hex.vi->VISONIC DAQ.vi->Visonic MAIN.vi 2016-07-27 11:45:11,436 VisonicDriver.exe error 56 0 LabVIEW: The network operation exceeded the user-specified or system time limit. HTTP GET TCP Read in Example HTTP GET method.vi->Zones ChangeHandler.vi->SensorStatesHandler.vi->decode hex.vi->VISONIC DAQ.vi->Visonic MAIN.vi 2016-07-27 11:45:39,062 VisonicDriver.exe error 56 0 LabVIEW: The network operation exceeded the user-specified or system time limit. HTTP GET TCP Read in Example HTTP GET method.vi->Zones ChangeHandler.vi->SensorStatesHandler.vi->VISONIC GUI.vi->Visonic MAIN.vi 2016-07-27 13:34:03,654 VisonicDriver.exe error 56 0 LabVIEW: The network operation exceeded the user-specified or system time limit. HTTP GET TCP Read in Example HTTP GET method.vi->Zones ChangeHandler.vi->SensorStatesHandler.vi->VISONIC GUI.vi->Visonic MAIN.vi 2016-07-27 13:34:09,082 VisonicDriver.exe error 56 0 LabVIEW: The network operation exceeded the user-specified or system time limit. HTTP GET TCP Read in Example HTTP GET method.vi->Zones ChangeHandler.vi->SensorStatesHandler.vi->VISONIC GUI.vi->Visonic MAIN.vi 2016-07-27 13:34:14,287 VisonicDriver.exe error 56 0 LabVIEW: The network operation exceeded the user-specified or system time limit. HTTP GET TCP Read in Example HTTP GET method.vi->Zones ChangeHandler.vi->SensorStatesHandler.vi->VISONIC GUI.vi->Visonic MAIN.vi 2016-07-27 13:34:19,509 VisonicDriver.exe error 56 0 LabVIEW: The network operation exceeded the user-specified or system time limit. HTTP GET TCP Read in Example HTTP GET method.vi->Zones ChangeHandler.vi->SensorStatesHandler.vi->decode hex.vi->VISONIC DAQ.vi->Visonic MAIN.vi 2016-07-27 13:34:24,755 VisonicDriver.exe error 56 0 LabVIEW: The network operation exceeded the user-specified or system time limit. HTTP GET TCP Read in Example HTTP GET method.vi->Zones ChangeHandler.vi->SensorStatesHandler.vi->decode hex.vi->VISONIC DAQ.vi->Visonic MAIN.vi 2016-07-27 13:34:29,979 VisonicDriver.exe error 56 0 LabVIEW: The network operation exceeded the user-specified or system time limit. HTTP GET TCP Read in Example HTTP GET method.vi->Zones ChangeHandler.vi->SensorStatesHandler.vi->decode hex.vi->VISONIC DAQ.vi->Visonic MAIN.vi 2016-07-27 13:34:35,308 VisonicDriver.exe error 56 0 LabVIEW: The network operation exceeded the user-specified or system time limit. HTTP GET TCP Read in Example HTTP GET method.vi->Zones ChangeHandler.vi->SensorStatesHandler.vi->decode hex.vi->VISONIC DAQ.vi->Visonic MAIN.vi 2016-07-27 13:34:40,871 VisonicDriver.exe error 56 0 LabVIEW: The network operation exceeded the user-specified or system time limit. HTTP GET TCP Read in Example HTTP GET method.vi->Zones ChangeHandler.vi->SensorStatesHandler.vi->VISONIC GUI.vi->Visonic MAIN.vi 2016-07-27 13:34:46,189 VisonicDriver.exe error 56 0 LabVIEW: The network operation exceeded the user-specified or system time limit. HTTP GET TCP Read in Example HTTP GET method.vi->Zones ChangeHandler.vi->SensorStatesHandler.vi->VISONIC CONTROL.vi->Visonic MAIN.vi 2016-07-27 13:34:51,426 VisonicDriver.exe error 56 0 LabVIEW: The network operation exceeded the user-specified or system time limit. HTTP GET TCP Read in Example HTTP GET method.vi->Zones ChangeHandler.vi->SensorStatesHandler.vi->decode hex.vi->VISONIC DAQ.vi->Visonic MAIN.vi 2016-07-27 13:34:56,642 VisonicDriver.exe error 56 0 LabVIEW: The network operation exceeded the user-specified or system time limit. HTTP GET TCP Read in Example HTTP GET method.vi->Zones ChangeHandler.vi->SensorStatesHandler.vi->VISONIC CONTROL.vi->Visonic MAIN.vi 2016-07-27 13:35:02,031 VisonicDriver.exe error 56 0 LabVIEW: The network operation exceeded the user-specified or system time limit. HTTP GET TCP Read in Example HTTP GET method.vi->Zones ChangeHandler.vi->SensorStatesHandler.vi->decode hex.vi->VISONIC DAQ.vi->Visonic MAIN.vi 2016-07-27 13:35:07,361 VisonicDriver.exe error 56 0 LabVIEW: The network operation exceeded the user-specified or system time limit. HTTP GET TCP Read in Example HTTP GET method.vi->Zones ChangeHandler.vi->SensorStatesHandler.vi->decode hex.vi->VISONIC DAQ.vi->Visonic MAIN.vi 2016-07-27 13:35:12,659 VisonicDriver.exe error 56 0 LabVIEW: The network operation exceeded the user-specified or system time limit. HTTP GET TCP Read in Example HTTP GET method.vi->Zones ChangeHandler.vi->SensorStatesHandler.vi->decode hex.vi->VISONIC DAQ.vi->Visonic MAIN.vi 2016-07-27 13:35:17,934 VisonicDriver.exe error 56 0 LabVIEW: The network operation exceeded the user-specified or system time limit. HTTP GET TCP Read in Example HTTP GET method.vi->Zones ChangeHandler.vi->SensorStatesHandler.vi->decode hex.vi->VISONIC DAQ.vi->Visonic MAIN.vi 2016-07-27 13:35:23,205 VisonicDriver.exe error 56 0 LabVIEW: The network operation exceeded the user-specified or system time limit. HTTP GET TCP Read in Example HTTP GET method.vi->Zones ChangeHandler.vi->SensorStatesHandler.vi->decode hex.vi->VISONIC DAQ.vi->Visonic MAIN.vi 2016-07-27 13:35:28,754 VisonicDriver.exe error 56 0 LabVIEW: The network operation exceeded the user-specified or system time limit. HTTP GET TCP Read in Example HTTP GET method.vi->Zones ChangeHandler.vi->SensorStatesHandler.vi->VISONIC CONTROL.vi->Visonic MAIN.vi 2016-07-27 13:35:34,663 VisonicDriver.exe error 56 0 LabVIEW: The network operation exceeded the user-specified or system time limit. HTTP GET TCP Read in Example HTTP GET method.vi->Zones ChangeHandler.vi->SensorStatesHandler.vi->decode hex.vi->VISONIC DAQ.vi->Visonic MAIN.vi 2016-07-27 13:35:40,361 VisonicDriver.exe error 56 0 LabVIEW: The network operation exceeded the user-specified or system time limit. HTTP GET TCP Read in Example HTTP GET method.vi->Zones ChangeHandler.vi->SensorStatesHandler.vi->decode hex.vi->VISONIC DAQ.vi->Visonic MAIN.vi 2016-07-27 13:35:44,191 VisonicDriver.exe error 56 0 LabVIEW: The network operation exceeded the user-specified or system time limit. HTTP GET TCP Read in Example HTTP GET method.vi->Zones ChangeHandler.vi->SensorStatesHandler.vi->VISONIC CONTROL.vi->Visonic MAIN.vi 2016-07-27 13:35:47,968 VisonicDriver.exe error 56 0 LabVIEW: The network operation exceeded the user-specified or system time limit. HTTP GET TCP Read in Example HTTP GET method.vi->Zones ChangeHandler.vi->SensorStatesHandler.vi->decode hex.vi->VISONIC DAQ.vi->Visonic MAIN.vi 2016-07-27 13:35:49,036 VisonicDriver.exe error 56 0 LabVIEW: The network operation exceeded the user-specified or system time limit. HTTP GET TCP Read in Example HTTP GET method.vi->Zones ChangeHandler.vi->SensorStatesHandler.vi->decode hex.vi->VISONIC DAQ.vi->Visonic MAIN.vi 2016-07-27 13:35:50,016 VisonicDriver.exe error 56 0 LabVIEW: The network operation exceeded the user-specified or system time limit. HTTP GET TCP Read in Example HTTP GET method.vi->Zones ChangeHandler.vi->SensorStatesHandler.vi->decode hex.vi->VISONIC DAQ.vi->Visonic MAIN.vi 2016-07-27 13:35:51,167 VisonicDriver.exe error 56 0 LabVIEW: The network operation exceeded the user-specified or system time limit. HTTP GET TCP Read in Example HTTP GET method.vi->Zones ChangeHandler.vi->SensorStatesHandler.vi->decode hex.vi->VISONIC DAQ.vi->Visonic MAIN.vi 2016-07-27 13:35:56,586 VisonicDriver.exe error 56 0 LabVIEW: The network operation exceeded the user-specified or system time limit. HTTP GET TCP Read in Example HTTP GET method.vi->Zones ChangeHandler.vi->SensorStatesHandler.vi->decode hex.vi->VISONIC DAQ.vi->Visonic MAIN.vi 2016-07-27 13:36:02,127 VisonicDriver.exe error 56 0 LabVIEW: The network operation exceeded the user-specified or system time limit. HTTP GET TCP Read in Example HTTP GET method.vi->Zones ChangeHandler.vi->SensorStatesHandler.vi->decode hex.vi->VISONIC DAQ.vi->Visonic MAIN.vi 2016-07-27 13:36:07,701 VisonicDriver.exe error 56 0 LabVIEW: The network operation exceeded the user-specified or system time limit. HTTP GET TCP Read in Example HTTP GET method.vi->Zones ChangeHandler.vi->SensorStatesHandler.vi->decode hex.vi->VISONIC DAQ.vi->Visonic MAIN.vi 2016-07-27 13:36:13,346 VisonicDriver.exe error 56 0 LabVIEW: The network operation exceeded the user-specified or system time limit. HTTP GET TCP Read in Example HTTP GET method.vi->Zones ChangeHandler.vi->SensorStatesHandler.vi->decode hex.vi->VISONIC DAQ.vi->Visonic MAIN.vi 2016-07-27 13:36:19,485 VisonicDriver.exe error 56 0 LabVIEW: The network operation exceeded the user-specified or system time limit. HTTP GET TCP Read in Example HTTP GET method.vi->Zones ChangeHandler.vi->SensorStatesHandler.vi->VISONIC CONTROL.vi->Visonic MAIN.vi 2016-07-27 13:36:24,796 VisonicDriver.exe error 56 0 LabVIEW: The network operation exceeded the user-specified or system time limit. HTTP GET TCP Read in Example HTTP GET method.vi->Zones ChangeHandler.vi->SensorStatesHandler.vi->decode hex.vi->VISONIC DAQ.vi->Visonic MAIN.vi 2016-07-27 13:36:30,121 VisonicDriver.exe error 56 0 LabVIEW: The network operation exceeded the user-specified or system time limit. HTTP GET TCP Read in Example HTTP GET method.vi->Zones ChangeHandler.vi->SensorStatesHandler.vi->VISONIC CONTROL.vi->Visonic MAIN.vi 2016-07-27 13:36:35,597 VisonicDriver.exe error 56 0 LabVIEW: The network operation exceeded the user-specified or system time limit. HTTP GET TCP Read in Example HTTP GET method.vi->Zones ChangeHandler.vi->SensorStatesHandler.vi->decode hex.vi->VISONIC DAQ.vi->Visonic MAIN.vi 2016-07-27 13:36:40,893 VisonicDriver.exe error 56 0 LabVIEW: The network operation exceeded the user-specified or system time limit. HTTP GET TCP Read in Example HTTP GET method.vi->Zones ChangeHandler.vi->SensorStatesHandler.vi->decode hex.vi->VISONIC DAQ.vi->Visonic MAIN.vi 2016-07-27 13:36:46,197 VisonicDriver.exe error 56 0 LabVIEW: The network operation exceeded the user-specified or system time limit. HTTP GET TCP Read in Example HTTP GET method.vi->Zones ChangeHandler.vi->SensorStatesHandler.vi->decode hex.vi->VISONIC DAQ.vi->Visonic MAIN.vi 2016-07-27 13:36:51,546 VisonicDriver.exe error 56 0 LabVIEW: The network operation exceeded the user-specified or system time limit. HTTP GET TCP Read in Example HTTP GET method.vi->Zones ChangeHandler.vi->SensorStatesHandler.vi->VISONIC CONTROL.vi->Visonic MAIN.vi 2016-07-27 13:36:56,865 VisonicDriver.exe error 56 0 LabVIEW: The network operation exceeded the user-specified or system time limit. HTTP GET TCP Read in Example HTTP GET method.vi->Zones ChangeHandler.vi->SensorStatesHandler.vi->decode hex.vi->VISONIC DAQ.vi->Visonic MAIN.vi 2016-07-27 13:37:02,235 VisonicDriver.exe error 56 0 LabVIEW: The network operation exceeded the user-specified or system time limit. HTTP GET TCP Read in Example HTTP GET method.vi->Zones ChangeHandler.vi->SensorStatesHandler.vi->VISONIC CONTROL.vi->Visonic MAIN.vi 2016-07-27 13:37:07,609 VisonicDriver.exe error 56 0 LabVIEW: The network operation exceeded the user-specified or system time limit. HTTP GET TCP Read in Example HTTP GET method.vi->Zones ChangeHandler.vi->SensorStatesHandler.vi->decode hex.vi->VISONIC DAQ.vi->Visonic MAIN.vi 2016-07-27 13:37:12,992 VisonicDriver.exe error 56 0 LabVIEW: The network operation exceeded the user-specified or system time limit. HTTP GET TCP Read in Example HTTP GET method.vi->Zones ChangeHandler.vi->SensorStatesHandler.vi->decode hex.vi->VISONIC DAQ.vi->Visonic MAIN.vi 2016-07-27 13:37:18,302 VisonicDriver.exe error 56 0 LabVIEW: The network operation exceeded the user-specified or system time limit. HTTP GET TCP Read in Example HTTP GET method.vi->Zones ChangeHandler.vi->SensorStatesHandler.vi->decode hex.vi->VISONIC DAQ.vi->Visonic MAIN.vi 2016-07-27 13:37:23,576 VisonicDriver.exe error 56 0 LabVIEW: The network operation exceeded the user-specified or system time limit. HTTP GET TCP Read in Example HTTP GET method.vi->Zones ChangeHandler.vi->SensorStatesHandler.vi->VISONIC CONTROL.vi->Visonic MAIN.vi 2016-07-27 13:37:27,339 VisonicDriver.exe error 56 0 LabVIEW: The network operation exceeded the user-specified or system time limit. HTTP GET TCP Read in Example HTTP GET method.vi->Zones ChangeHandler.vi->SensorStatesHandler.vi->decode hex.vi->VISONIC DAQ.vi->Visonic MAIN.vi 2016-07-27 13:37:30,415 VisonicDriver.exe error 56 0 LabVIEW: The network operation exceeded the user-specified or system time limit. HTTP GET TCP Read in Example HTTP GET method.vi->Zones ChangeHandler.vi->SensorStatesHandler.vi->decode hex.vi->VISONIC DAQ.vi->Visonic MAIN.vi 2016-07-27 13:37:35,691 VisonicDriver.exe error 56 0 LabVIEW: The network operation exceeded the user-specified or system time limit. HTTP GET TCP Read in Example HTTP GET method.vi->Zones ChangeHandler.vi->SensorStatesHandler.vi->decode hex.vi->VISONIC DAQ.vi->Visonic MAIN.vi 2016-07-27 13:37:40,961 VisonicDriver.exe error 56 0 LabVIEW: The network operation exceeded the user-specified or system time limit. HTTP GET TCP Read in Example HTTP GET method.vi->Zones ChangeHandler.vi->SensorStatesHandler.vi->decode hex.vi->VISONIC DAQ.vi->Visonic MAIN.vi 2016-07-27 13:37:44,300 VisonicDriver.exe error 56 0 LabVIEW: The network operation exceeded the user-specified or system time limit. HTTP GET TCP Read in Example HTTP GET method.vi->Zones ChangeHandler.vi->SensorStatesHandler.vi->decode hex.vi->VISONIC DAQ.vi->Visonic MAIN.vi 2016-07-27 13:37:45,435 VisonicDriver.exe error 56 0 LabVIEW: The network operation exceeded the user-specified or system time limit. HTTP GET TCP Read in Example HTTP GET method.vi->Zones ChangeHandler.vi->SensorStatesHandler.vi->VISONIC CONTROL.vi->Visonic MAIN.vi 2016-07-27 13:37:46,432 VisonicDriver.exe error 56 0 LabVIEW: The network operation exceeded the user-specified or system time limit. HTTP GET TCP Read in Example HTTP GET method.vi->Zones ChangeHandler.vi->SensorStatesHandler.vi->decode hex.vi->VISONIC DAQ.vi->Visonic MAIN.vi 2016-07-27 13:37:47,419 VisonicDriver.exe error 56 0 LabVIEW: The network operation exceeded the user-specified or system time limit. HTTP GET TCP Read in Example HTTP GET method.vi->Zones ChangeHandler.vi->SensorStatesHandler.vi->decode hex.vi->VISONIC DAQ.vi->Visonic MAIN.vi 2016-07-27 13:37:48,769 VisonicDriver.exe error 56 0 LabVIEW: The network operation exceeded the user-specified or system time limit. HTTP GET TCP Read in Example HTTP GET method.vi->Zones ChangeHandler.vi->SensorStatesHandler.vi->VISONIC CONTROL.vi->Visonic MAIN.vi 2016-07-27 13:37:49,767 VisonicDriver.exe error 56 0 LabVIEW: The network operation exceeded the user-specified or system time limit. HTTP GET TCP Read in Example HTTP GET method.vi->Zones ChangeHandler.vi->SensorStatesHandler.vi->decode hex.vi->VISONIC DAQ.vi->Visonic MAIN.vi 2016-07-27 13:37:50,710 VisonicDriver.exe error 56 0 LabVIEW: The network operation exceeded the user-specified or system time limit. HTTP GET TCP Read in Example HTTP GET method.vi->Zones ChangeHandler.vi->SensorStatesHandler.vi->decode hex.vi->VISONIC DAQ.vi->Visonic MAIN.vi 2016-07-27 13:37:51,748 VisonicDriver.exe error 56 0 LabVIEW: The network operation exceeded the user-specified or system time limit. HTTP GET TCP Read in Example HTTP GET method.vi->Zones ChangeHandler.vi->SensorStatesHandler.vi->VISONIC CONTROL.vi->Visonic MAIN.vi 2016-07-27 13:37:52,631 VisonicDriver.exe error 56 0 LabVIEW: The network operation exceeded the user-specified or system time limit. HTTP GET TCP Read in Example HTTP GET method.vi->Zones ChangeHandler.vi->SensorStatesHandler.vi->decode hex.vi->VISONIC DAQ.vi->Visonic MAIN.vi 2016-07-27 13:38:46,956 VisonicDriver.exe error 56 0 LabVIEW: The network operation exceeded the user-specified or system time limit. HTTP GET TCP Read in Example HTTP GET method.vi->Zones ChangeHandler.vi->SensorStatesHandler.vi->decode hex.vi->VISONIC DAQ.vi->Visonic MAIN.vi 2016-07-27 13:42:32,473 VisonicDriver.exe error 56 0 LabVIEW: The network operation exceeded the user-specified or system time limit. HTTP GET TCP Read in Example HTTP GET method.vi->Zones ChangeHandler.vi->SensorStatesHandler.vi->decode hex.vi->VISONIC DAQ.vi->Visonic MAIN.vi 2016-07-27 13:43:00,411 VisonicDriver.exe error 56 0 LabVIEW: The network operation exceeded the user-specified or system time limit. HTTP GET TCP Read in Example HTTP GET method.vi->Zones ChangeHandler.vi->SensorStatesHandler.vi->VISONIC GUI.vi->Visonic MAIN.vi 2016-07-27 13:44:41,563 VisonicDriver.exe error 56 0 LabVIEW: The network operation exceeded the user-specified or system time limit. HTTP GET TCP Read in Example HTTP GET method.vi->Zones ChangeHandler.vi->SensorStatesHandler.vi->decode hex.vi->VISONIC DAQ.vi->Visonic MAIN.vi 2016-07-27 13:44:57,206 VisonicDriver.exe error 56 0 LabVIEW: The network operation exceeded the user-specified or system time limit. HTTP GET TCP Read in Example HTTP GET method.vi->Zones ChangeHandler.vi->SensorStatesHandler.vi->decode hex.vi->VISONIC DAQ.vi->Visonic MAIN.vi 2016-07-27 13:45:32,282 VisonicDriver.exe error 56 0 LabVIEW: The network operation exceeded the user-specified or system time limit. HTTP GET TCP Read in Example HTTP GET method.vi->Zones ChangeHandler.vi->SensorStatesHandler.vi->decode hex.vi->VISONIC DAQ.vi->Visonic MAIN.vi 2016-07-27 13:45:38,000 VisonicDriver.exe error 56 0 LabVIEW: The network operation exceeded the user-specified or system time limit. HTTP GET TCP Read in Example HTTP GET method.vi->Zones ChangeHandler.vi->SensorStatesHandler.vi->decode hex.vi->VISONIC DAQ.vi->Visonic MAIN.vi 2016-07-27 13:45:47,855 VisonicDriver.exe error 56 0 LabVIEW: The network operation exceeded the user-specified or system time limit. HTTP GET TCP Read in Example HTTP GET method.vi->Zones ChangeHandler.vi->SensorStatesHandler.vi->decode hex.vi->VISONIC DAQ.vi->Visonic MAIN.vi 2016-07-27 13:46:01,799 VisonicDriver.exe error 56 0 LabVIEW: The network operation exceeded the user-specified or system time limit. HTTP GET TCP Read in Example HTTP GET method.vi->Zones ChangeHandler.vi->SensorStatesHandler.vi->VISONIC GUI.vi->Visonic MAIN.vi 2016-07-27 13:46:14,175 VisonicDriver.exe error 56 0 LabVIEW: The network operation exceeded the user-specified or system time limit. HTTP GET TCP Read in Example HTTP GET method.vi->Zones ChangeHandler.vi->SensorStatesHandler.vi->VISONIC GUI.vi->Visonic MAIN.vi 2016-07-27 14:28:10,211 VisonicDriver.exe error 56 0 LabVIEW: The network operation exceeded the user-specified or system time limit. HTTP GET TCP Read in Example HTTP GET method.vi->Zones ChangeHandler.vi->SensorStatesHandler.vi->decode hex.vi->VISONIC DAQ.vi->Visonic MAIN.vi 2016-07-27 14:28:15,492 VisonicDriver.exe error 56 0 LabVIEW: The network operation exceeded the user-specified or system time limit. HTTP GET TCP Read in Example HTTP GET method.vi->Zones ChangeHandler.vi->SensorStatesHandler.vi->decode hex.vi->VISONIC DAQ.vi->Visonic MAIN.vi 2016-07-27 14:28:25,583 VisonicDriver.exe error 56 0 LabVIEW: The network operation exceeded the user-specified or system time limit. HTTP GET TCP Read in Example HTTP GET method.vi->Zones ChangeHandler.vi->SensorStatesHandler.vi->decode hex.vi->VISONIC DAQ.vi->Visonic MAIN.vi 2016-07-27 14:28:45,736 VisonicDriver.exe error 56 0 LabVIEW: The network operation exceeded the user-specified or system time limit. HTTP GET TCP Read in Example HTTP GET method.vi->Zones ChangeHandler.vi->SensorStatesHandler.vi->VISONIC GUI.vi->Visonic MAIN.vi 2016-07-27 14:50:00,349 VisonicDriver.exe error 56 0 LabVIEW: The network operation exceeded the user-specified or system time limit. HTTP GET TCP Read in Example HTTP GET method.vi->Zones ChangeHandler.vi->SensorStatesHandler.vi->decode hex.vi->VISONIC DAQ.vi->Visonic MAIN.vi 2016-07-27 14:50:28,173 VisonicDriver.exe error 56 0 LabVIEW: The network operation exceeded the user-specified or system time limit. HTTP GET TCP Read in Example HTTP GET method.vi->Zones ChangeHandler.vi->SensorStatesHandler.vi->VISONIC GUI.vi->Visonic MAIN.vi 2016-07-27 14:51:02,513 VisonicDriver.exe error 56 0 LabVIEW: The network operation exceeded the user-specified or system time limit. HTTP GET TCP Read in Example HTTP GET method.vi->Zones ChangeHandler.vi->SensorStatesHandler.vi->decode hex.vi->VISONIC DAQ.vi->Visonic MAIN.vi 2016-07-27 14:51:08,233 VisonicDriver.exe error 56 0 LabVIEW: The network operation exceeded the user-specified or system time limit. HTTP GET TCP Read in Example HTTP GET method.vi->Zones ChangeHandler.vi->SensorStatesHandler.vi->decode hex.vi->VISONIC DAQ.vi->Visonic MAIN.vi 2016-07-27 14:51:18,015 VisonicDriver.exe error 56 0 LabVIEW: The network operation exceeded the user-specified or system time limit. HTTP GET TCP Read in Example HTTP GET method.vi->Zones ChangeHandler.vi->SensorStatesHandler.vi->decode hex.vi->VISONIC DAQ.vi->Visonic MAIN.vi 2016-07-27 14:51:31,945 VisonicDriver.exe error 56 0 LabVIEW: The network operation exceeded the user-specified or system time limit. HTTP GET TCP Read in Example HTTP GET method.vi->Zones ChangeHandler.vi->SensorStatesHandler.vi->VISONIC GUI.vi->Visonic MAIN.vi 2016-07-27 14:51:45,306 VisonicDriver.exe error 56 0 LabVIEW: The network operation exceeded the user-specified or system time limit. HTTP GET TCP Read in Example HTTP GET method.vi->Zones ChangeHandler.vi->SensorStatesHandler.vi->VISONIC GUI.vi->Visonic MAIN.vi 2016-07-27 14:53:08,991 VisonicDriver.exe error 56 0 LabVIEW: The network operation exceeded the user-specified or system time limit. HTTP GET TCP Read in Example HTTP GET method.vi->Zones ChangeHandler.vi->SensorStatesHandler.vi->decode hex.vi->VISONIC DAQ.vi->Visonic MAIN.vi 2016-07-27 14:53:14,274 VisonicDriver.exe error 56 0 LabVIEW: The network operation exceeded the user-specified or system time limit. HTTP GET TCP Read in Example HTTP GET method.vi->Zones ChangeHandler.vi->SensorStatesHandler.vi->decode hex.vi->VISONIC DAQ.vi->Visonic MAIN.vi 2016-07-27 14:53:39,287 VisonicDriver.exe error 56 0 LabVIEW: The network operation exceeded the user-specified or system time limit. HTTP GET TCP Read in Example HTTP GET method.vi->Zones ChangeHandler.vi->SensorStatesHandler.vi->decode hex.vi->VISONIC DAQ.vi->Visonic MAIN.vi 2016-07-27 14:55:27,717 VisonicDriver.exe error 56 0 LabVIEW: The network operation exceeded the user-specified or system time limit. HTTP GET TCP Read in Example HTTP GET method.vi->Zones ChangeHandler.vi->SensorStatesHandler.vi->decode hex.vi->VISONIC DAQ.vi->Visonic MAIN.vi 2016-07-27 14:55:55,594 VisonicDriver.exe error 56 0 LabVIEW: The network operation exceeded the user-specified or system time limit. HTTP GET TCP Read in Example HTTP GET method.vi->Zones ChangeHandler.vi->SensorStatesHandler.vi->VISONIC GUI.vi->Visonic MAIN.vi 2016-07-27 14:57:50,331 VisonicDriver.exe error 56 0 LabVIEW: The network operation exceeded the user-specified or system time limit. HTTP GET TCP Read in Example HTTP GET method.vi->Zones ChangeHandler.vi->SensorStatesHandler.vi->decode hex.vi->VISONIC DAQ.vi->Visonic MAIN.vi 2016-07-27 14:58:18,091 VisonicDriver.exe error 56 0 LabVIEW: The network operation exceeded the user-specified or system time limit. HTTP GET TCP Read in Example HTTP GET method.vi->Zones ChangeHandler.vi->SensorStatesHandler.vi->VISONIC GUI.vi->Visonic MAIN.vi 2016-07-27 14:58:23,411 VisonicDriver.exe error 56 0 LabVIEW: The network operation exceeded the user-specified or system time limit. HTTP GET TCP Read in Example HTTP GET method.vi->Zones ChangeHandler.vi->SensorStatesHandler.vi->decode hex.vi->VISONIC DAQ.vi->Visonic MAIN.vi 2016-07-27 14:58:33,871 VisonicDriver.exe error 56 0 LabVIEW: The network operation exceeded the user-specified or system time limit. HTTP GET TCP Read in Example HTTP GET method.vi->Zones ChangeHandler.vi->SensorStatesHandler.vi->decode hex.vi->VISONIC DAQ.vi->Visonic MAIN.vi 2016-07-27 14:58:39,128 VisonicDriver.exe error 56 0 LabVIEW: The network operation exceeded the user-specified or system time limit. HTTP GET TCP Read in Example HTTP GET method.vi->Zones ChangeHandler.vi->SensorStatesHandler.vi->decode hex.vi->VISONIC DAQ.vi->Visonic MAIN.vi 2016-07-27 14:59:01,419 VisonicDriver.exe error 56 0 LabVIEW: The network operation exceeded the user-specified or system time limit. HTTP GET TCP Read in Example HTTP GET method.vi->Zones ChangeHandler.vi->SensorStatesHandler.vi->VISONIC GUI.vi->Visonic MAIN.vi 2016-07-27 14:59:37,936 VisonicDriver.exe error 56 0 LabVIEW: The network operation exceeded the user-specified or system time limit. HTTP GET TCP Read in Example HTTP GET method.vi->Zones ChangeHandler.vi->SensorStatesHandler.vi->decode hex.vi->VISONIC DAQ.vi->Visonic MAIN.vi 2016-07-27 15:00:06,391 VisonicDriver.exe error 56 0 LabVIEW: The network operation exceeded the user-specified or system time limit. HTTP GET TCP Read in Example HTTP GET method.vi->Zones ChangeHandler.vi->SensorStatesHandler.vi->VISONIC GUI.vi->Visonic MAIN.vi 2016-07-27 15:12:00,252 VisonicDriver.exe error 56 0 LabVIEW: The network operation exceeded the user-specified or system time limit. HTTP GET TCP Read in Example HTTP GET method.vi->Zones ChangeHandler.vi->SensorStatesHandler.vi->decode hex.vi->VISONIC DAQ.vi->Visonic MAIN.vi 2016-07-27 15:12:27,714 VisonicDriver.exe error 56 0 LabVIEW: The network operation exceeded the user-specified or system time limit. HTTP GET TCP Read in Example HTTP GET method.vi->Zones ChangeHandler.vi->SensorStatesHandler.vi->VISONIC GUI.vi->Visonic MAIN.vi 2016-07-27 15:17:58,470 VisonicDriver.exe error 56 0 LabVIEW: The network operation exceeded the user-specified or system time limit. HTTP GET TCP Read in Example HTTP GET method.vi->Zones ChangeHandler.vi->SensorStatesHandler.vi->decode hex.vi->VISONIC DAQ.vi->Visonic MAIN.vi 2016-07-27 15:18:26,333 VisonicDriver.exe error 56 0 LabVIEW: The network operation exceeded the user-specified or system time limit. HTTP GET TCP Read in Example HTTP GET method.vi->Zones ChangeHandler.vi->SensorStatesHandler.vi->VISONIC GUI.vi->Visonic MAIN.vi 2016-07-27 15:21:50,481 VisonicDriver.exe error 56 0 LabVIEW: The network operation exceeded the user-specified or system time limit. HTTP GET TCP Read in Example HTTP GET method.vi->Zones ChangeHandler.vi->SensorStatesHandler.vi->decode hex.vi->VISONIC DAQ.vi->Visonic MAIN.vi 2016-07-27 15:22:18,028 VisonicDriver.exe error 56 0 LabVIEW: The network operation exceeded the user-specified or system time limit. HTTP GET TCP Read in Example HTTP GET method.vi->Zones ChangeHandler.vi->SensorStatesHandler.vi->VISONIC GUI.vi->Visonic MAIN.vi 2016-07-27 15:38:41,633 VisonicDriver.exe error 56 0 LabVIEW: The network operation exceeded the user-specified or system time limit. HTTP GET TCP Read in Example HTTP GET method.vi->Zones ChangeHandler.vi->SensorStatesHandler.vi->decode hex.vi->VISONIC DAQ.vi->Visonic MAIN.vi 2016-07-27 15:39:09,523 VisonicDriver.exe error 56 0 LabVIEW: The network operation exceeded the user-specified or system time limit. HTTP GET TCP Read in Example HTTP GET method.vi->Zones ChangeHandler.vi->SensorStatesHandler.vi->VISONIC GUI.vi->Visonic MAIN.vi 2016-07-27 15:40:53,255 VisonicDriver.exe error 56 0 LabVIEW: The network operation exceeded the user-specified or system time limit. HTTP GET TCP Read in Example HTTP GET method.vi->Zones ChangeHandler.vi->SensorStatesHandler.vi->decode hex.vi->VISONIC DAQ.vi->Visonic MAIN.vi 2016-07-27 15:41:21,095 VisonicDriver.exe error 56 0 LabVIEW: The network operation exceeded the user-specified or system time limit. HTTP GET TCP Read in Example HTTP GET method.vi->Zones ChangeHandler.vi->SensorStatesHandler.vi->VISONIC GUI.vi->Visonic MAIN.vi 2016-07-27 15:44:03,064 VisonicDriver.exe error 56 0 LabVIEW: The network operation exceeded the user-specified or system time limit. HTTP GET TCP Read in Example HTTP GET method.vi->Zones ChangeHandler.vi->SensorStatesHandler.vi->decode hex.vi->VISONIC DAQ.vi->Visonic MAIN.vi 2016-07-27 15:44:30,869 VisonicDriver.exe error 56 0 LabVIEW: The network operation exceeded the user-specified or system time limit. HTTP GET TCP Read in Example HTTP GET method.vi->Zones ChangeHandler.vi->SensorStatesHandler.vi->VISONIC GUI.vi->Visonic MAIN.vi 2016-07-27 15:53:38,818 VisonicDriver.exe error 56 0 LabVIEW: The network operation exceeded the user-specified or system time limit. HTTP GET TCP Read in Example HTTP GET method.vi->Zones ChangeHandler.vi->SensorStatesHandler.vi->decode hex.vi->VISONIC DAQ.vi->Visonic MAIN.vi 2016-07-27 15:53:54,962 VisonicDriver.exe error 56 0 LabVIEW: The network operation exceeded the user-specified or system time limit. HTTP GET TCP Read in Example HTTP GET method.vi->Zones ChangeHandler.vi->SensorStatesHandler.vi->decode hex.vi->VISONIC DAQ.vi->Visonic MAIN.vi 2016-07-27 15:54:08,147 VisonicDriver.exe error 56 0 LabVIEW: The network operation exceeded the user-specified or system time limit. HTTP GET TCP Read in Example HTTP GET method.vi->Zones ChangeHandler.vi->SensorStatesHandler.vi->VISONIC GUI.vi->Visonic MAIN.vi 2016-07-27 15:55:47,334 VisonicDriver.exe error 56 0 LabVIEW: The network operation exceeded the user-specified or system time limit. HTTP GET TCP Read in Example HTTP GET method.vi->Zones ChangeHandler.vi->SensorStatesHandler.vi->decode hex.vi->VISONIC DAQ.vi->Visonic MAIN.vi 2016-07-27 16:01:38,133 VisonicDriver.exe error 56 0 LabVIEW: The network operation exceeded the user-specified or system time limit. HTTP GET TCP Read in Example HTTP GET method.vi->Zones ChangeHandler.vi->SensorStatesHandler.vi->decode hex.vi->VISONIC DAQ.vi->Visonic MAIN.vi 2016-07-27 16:02:06,274 VisonicDriver.exe error 56 0 LabVIEW: The network operation exceeded the user-specified or system time limit. HTTP GET TCP Read in Example HTTP GET method.vi->Zones ChangeHandler.vi->SensorStatesHandler.vi->VISONIC GUI.vi->Visonic MAIN.vi 2016-07-27 16:08:04,734 VisonicDriver.exe error 56 0 LabVIEW: The network operation exceeded the user-specified or system time limit. HTTP GET TCP Read in Example HTTP GET method.vi->Zones ChangeHandler.vi->SensorStatesHandler.vi->decode hex.vi->VISONIC DAQ.vi->Visonic MAIN.vi 2016-07-27 16:08:34,227 VisonicDriver.exe error 56 0 LabVIEW: The network operation exceeded the user-specified or system time limit. HTTP GET TCP Read in Example HTTP GET method.vi->Zones ChangeHandler.vi->SensorStatesHandler.vi->VISONIC GUI.vi->Visonic MAIN.vi 2016-07-27 16:08:39,580 VisonicDriver.exe error 56 0 LabVIEW: The network operation exceeded the user-specified or system time limit. HTTP GET TCP Read in Example HTTP GET method.vi->Zones ChangeHandler.vi->SensorStatesHandler.vi->decode hex.vi->VISONIC DAQ.vi->Visonic MAIN.vi 2016-07-27 16:08:44,871 VisonicDriver.exe error 56 0 LabVIEW: The network operation exceeded the user-specified or system time limit. HTTP GET TCP Read in Example HTTP GET method.vi->Zones ChangeHandler.vi->SensorStatesHandler.vi->decode hex.vi->VISONIC DAQ.vi->Visonic MAIN.vi 2016-07-27 16:09:09,565 VisonicDriver.exe error 56 0 LabVIEW: The network operation exceeded the user-specified or system time limit. HTTP GET TCP Read in Example HTTP GET method.vi->Zones ChangeHandler.vi->SensorStatesHandler.vi->VISONIC GUI.vi->Visonic MAIN.vi 2016-07-27 16:09:44,208 VisonicDriver.exe error 56 0 LabVIEW: The network operation exceeded the user-specified or system time limit. HTTP GET TCP Read in Example HTTP GET method.vi->Zones ChangeHandler.vi->SensorStatesHandler.vi->decode hex.vi->VISONIC DAQ.vi->Visonic MAIN.vi 2016-07-27 16:10:59,545 VisonicDriver.exe error 56 0 LabVIEW: The network operation exceeded the user-specified or system time limit. HTTP GET TCP Read in Example HTTP GET method.vi->Zones ChangeHandler.vi->SensorStatesHandler.vi->decode hex.vi->VISONIC DAQ.vi->Visonic MAIN.vi 2016-07-27 16:12:02,713 VisonicDriver.exe error 56 0 LabVIEW: The network operation exceeded the user-specified or system time limit. HTTP GET TCP Read in Example HTTP GET method.vi->Zones ChangeHandler.vi->SensorStatesHandler.vi->decode hex.vi->VISONIC DAQ.vi->Visonic MAIN.vi 2016-07-27 16:40:50,195 VisonicDriver.exe error 56 0 LabVIEW: The network operation exceeded the user-specified or system time limit. HTTP GET TCP Read in Example HTTP GET method.vi->Zones ChangeHandler.vi->SensorStatesHandler.vi->decode hex.vi->VISONIC DAQ.vi->Visonic MAIN.vi 2016-07-27 16:40:55,477 VisonicDriver.exe error 56 0 LabVIEW: The network operation exceeded the user-specified or system time limit. HTTP GET TCP Read in Example HTTP GET method.vi->Zones ChangeHandler.vi->SensorStatesHandler.vi->decode hex.vi->VISONIC DAQ.vi->Visonic MAIN.vi 2016-07-27 16:41:18,484 VisonicDriver.exe error 56 0 LabVIEW: The network operation exceeded the user-specified or system time limit. HTTP GET TCP Read in Example HTTP GET method.vi->Zones ChangeHandler.vi->SensorStatesHandler.vi->decode hex.vi->VISONIC DAQ.vi->Visonic MAIN.vi
- Advanced Member
- Contact:
Mario,
Sorry i dont get the forum updates somehow again :s
Regarding your issue, please check if the status of the panel is correct in the driver and i suspect it is:) no errors regarding the panel connection.
The issue you see is as stated before, that the http calls configured can not be executed , prob because a typo. It is not good practise to query the driver for the panel and zone state but these are being trasferred by the http cals to homeseer.
Bart
Bart
(ON ESXI )on NUC
(ON ESXI )on NUC
hello
do you know what can be wrong? my powermax complete only shows current status of panel(disarm, delay,armed...) (with some lags) but doestn show any other information (panel info, zones etc.) and doesn't react on pressing arm or disarm in windows app.
thanks
thanks
- IMG_9143.JPG (272.07 KiB) Viewed 19969 times
