Controlling Toon via Domoticz
Edwin66
Re: Controlling Toon via Domoticz
Post by Edwin66 »
Before I could also see how much energy the plug was using on domoticz, not any more however.
Toon® (rooted) | Hue bulbs | TRÅDFRI bulbs | Smart Plugs | some TUYA stuff |
I'm not a programmer, just wish things work MY way
TerrorSource
Post by TerrorSource »
mAiden wrote:For the people with smart plugs, here a detailed explanation, how to connect them to Domoticz.
This way you can also switch your plugs on time, and you are totally independent of Olisto or a Service Center. ;-)
English version comes as soon as possible .. Here the Dutch version ..
Slimme stekkers Toon in Domoticz.pdf
Can you make a separate topic for this? Makes it easier to find for others.
v2 of the manuals will be uploaded soon.
- fixed some typo's
- added LUA/DzVents option enabling.
Rudolf
Post by Rudolf »
There's already a very similar description of controlling smart-plugs via curl. (Works for Home Assistant or Domoticz too).
It's all written down here:
viewtopic.php?f=102&t=11857
That approach doesn't use the uuid, but the node_id, which is easier to remember for us simple humans.
That ID does change when unpairing and re-pairing.
Here's my config for HA, what's lacking is the actual state of the switch. That information is available via http, but that requires some extra effort.
- platform: command_line
  switches:
    switch_naam_1:
      command_on: curl --data "action=basicCommand&nodeID=14&state=1"  http://192.168.1.115:10080/hdrv_zwave?
      command_off: curl --data "action=basicCommand&nodeID=14&state=0"  http://192.168.1.115:10080/hdrv_zwave?
    switch_naam_2:
      command_on: curl --data "action=basicCommand&nodeID=15&state=1"  http://192.168.1.115:10080/hdrv_zwave?
      command_off: curl --data "action=basicCommand&nodeID=15&state=0"  http://192.168.1.115:10080/hdrv_zwave?
BOverdevest
Post by BOverdevest »
Based on several posts, I combined getting all Toon data to Domoticz in a single DzVents script. So both boiler data, thermostat data and the P1 data.
Now that I have a rooted Toon2 :D I had to update the script, as the P1 data apparently changed in the http://<ToonIP>/hdrv_zwave?action=getDevices.json.
return {
	on = {
		timer = {
			'every minute'
	execute = function(domoticz)
        local ToonThermostat        = domoticz.variables('UV_ToonThermostat').value -- Sensor showing current setpoint
        local ToonTemperature       = domoticz.variables('UV_ToonTemperature').value -- Sensor showing current room temperature
        local ToonBoilerTempIn      = domoticz.variables('UV_ToonBoilerTempIn').value -- Sensor showing water temp return
        local ToonBoilerTempOut     = domoticz.variables('UV_ToonBoilerTempOut').value -- Sensor showing current water temp out
        local ToonBoilerPressure    = domoticz.variables('UV_ToonBoilerPressure').value -- Sensor showing current room temperature
        local ToonBoilerModulation  = domoticz.variables('UV_ToonBoilerModulation').value -- Sensor showing current Boiler Modulation
        local ToonScenes            = domoticz.variables('UV_ToonScenes').value -- Sensor showing current program
        local ToonAutoProgram       = domoticz.variables('UV_ToonAutoProgram').value -- Sensor showing current auto program status
        local ToonProgramInformation = domoticz.variables('UV_ToonProgramInformation').value -- Sensor showing displaying program information status
        local ToonIP                = domoticz.variables('UV_ToonIP').value
        local DomoticzIP            = domoticz.variables('UV_DomoticzIP').value
        local ToonBurnerName        = domoticz.variables('UV_ToonBurnerName').value
        local P1SmartMeterPower     = domoticz.variables('UV_P1SmartMeterElectra').value
        local P1SmartMeterGas1      = domoticz.variables('UV_P1SmartMeterGasMeterStand').value
        local ToonBoilerSetpoint    = domoticz.variables('UV_ToonBoilerTempSetpoint').value  -- Sensor showing current boiler set point water temp out
        -- Handle json
        local json = assert(loadfile "/home/pi/domoticz/scripts/lua/JSON.lua")()  -- For Linux
        local handle = assert(io.popen(string.format('curl http://%s/happ_thermstat?action=getThermostatInfo', ToonIP)))
        local ThermostatInfo = handle:read('*all')
        handle:close()
        local jsonThermostatInfo = json:decode(ThermostatInfo)
        if jsonThermostatInfo == nil then
            return
        end
        local handle2 = assert(io.popen(string.format('curl http://%s/boilerstatus/boilervalues.txt', ToonIP)))
        local BoilerInfo = handle2:read('*all')
        handle2:close()
        -- JSON data from Toon contains a extra "," which should not be there.
        BoilerInfo = string.gsub(BoilerInfo, ",}", "}")
        jsonBoilerInfo = json:decode(BoilerInfo)
         -- http://IP_TOON/hdrv_zwave?action=getDevices.json
        local handle4 = assert(io.popen(string.format('curl http://%s/hdrv_zwave?action=getDevices.json', ToonIP)))
        local GasPowerInfo = handle4:read('*all')
        handle4:close()
        -- JSON data from Toon contains a extra "." which should not be there.
        GasPowerInfo = string.gsub(GasPowerInfo, "dev_4.", "dev_4")
        GasPowerInfo = string.gsub(GasPowerInfo, "dev_4:", "dev_4\":")
        local jsonGasPower = json:decode(GasPowerInfo)
       -- domoticz.log(jsonGasPower)
         local CurrentElectricityFlowHoog = tonumber(jsonGasPower.dev_44.CurrentElectricityFlow )
         local CurrentElectricityQuantityHoog = tonumber(jsonGasPower.dev_44.CurrentElectricityQuantity)
         local CurrentElectricityFlowLaag = tonumber(jsonGasPower.dev_46.CurrentElectricityFlow )
         local CurrentElectricityQuantityLaag = tonumber(jsonGasPower.dev_46.CurrentElectricityQuantity)
         local CurrentGasFlow = tonumber(jsonGasPower.dev_41.CurrentGasFlow)
         local CurrentGasQuantity = tonumber(jsonGasPower.dev_41.CurrentGasQuantity)
         local CurrentElectricityQuantity =   CurrentElectricityFlowHoog + CurrentElectricityFlowLaag
         local CurrentElectricityDeliveredLaag = 0
         local CurrentElectricityDeliveredHoog = 0
         local totalDeliveredPower = 0
        domoticz.devices(P1SmartMeterPower).updateP1(CurrentElectricityQuantityLaag, CurrentElectricityQuantityHoog, CurrentElectricityDeliveredLaag, CurrentElectricityDeliveredHoog, CurrentElectricityQuantity, totalDeliveredPower).silent()
        domoticz.devices(P1SmartMeterGas1).updateGas(CurrentGasQuantity).silent()
 -- Update the Boiler Water In to current value
         local currentboilerInTemp = tonumber(jsonBoilerInfo.boilerInTemp)
        if domoticz.utils.round(domoticz.devices(ToonBoilerTempIn).temperature,0) ~= domoticz.utils.round(currentboilerInTemp,0) then
            -- domoticz.log('Updating Boiler Water In to current value: ' ..currentboilerInTemp)
            domoticz.devices(ToonBoilerTempIn).updateTemperature(currentboilerInTemp).silent()
        end
 -- Update the Boiler water Out to current value
     local currentboilerOutTemp = tonumber(jsonBoilerInfo.boilerOutTemp)
        if domoticz.utils.round(domoticz.devices(ToonBoilerTempOut).temperature,0) ~= domoticz.utils.round(currentboilerOutTemp,0) then
            -- domoticz.log('Updating Boiler Water Out to current value: ' ..currentboilerOutTemp)
            domoticz.devices(ToonBoilerTempOut).updateTemperature(currentboilerOutTemp).silent()
        end
 -- Update the Boiler water Pressure to current value
        local currentBoilerPressure = tonumber(jsonBoilerInfo.boilerPressure) * 10
        if domoticz.utils.round(domoticz.devices(ToonBoilerPressure)._nValue,0) ~= domoticz.utils.round(currentBoilerPressure,0) then
            -- domoticz.log('Updating Boiler Pressure to current value: ' ..currentBoilerPressure)
            domoticz.devices(ToonBoilerPressure).updatePressure(currentBoilerPressure).silent()
        end
        local currentSetpoint = tonumber(jsonThermostatInfo.currentSetpoint) / 100
        local currentTemperature = tonumber(jsonThermostatInfo.currentTemp) / 100
        local currentProgramState = tonumber(jsonThermostatInfo.programState)
            if currentProgramState == 0 then currentProgramState = 10 -- No
                elseif currentProgramState == 1 then currentProgramState = 20 -- Yes
                elseif currentProgramState == 2 then currentProgramState = 30 -- Temporary
            end
        local currentActiveState = tonumber(jsonThermostatInfo.activeState)
            if currentActiveState == -1 then currentActiveState = 50 -- Manual
                elseif currentActiveState == 0 then currentActiveState = 40 -- Comfort
                elseif currentActiveState == 1 then currentActiveState = 30 -- Home
                elseif currentActiveState == 2 then currentActiveState = 20 -- Sleep
                elseif currentActiveState == 3 then currentActiveState = 10 -- Away
            end
        -- Update the toon burner selector to current program state
        local currentBurnerInfo = tonumber(jsonThermostatInfo.burnerInfo)
        local CurrentToonBurnerValue = domoticz.devices(ToonBurnerName).level
        if currentBurnerInfo == 0 then currentBurnerInfo = 0 -- uit
            elseif currentBurnerInfo == 1 then currentBurnerInfo = 10 -- cv aan
            elseif currentBurnerInfo == 2 then currentBurnerInfo = 20 -- warmwater aan
        end
        if CurrentToonBurnerValue ~= currentBurnerInfo then  -- Update toon burner selector if it has changed
            -- domoticz.log('Updating Toon burner info:')
            domoticz.devices(ToonBurnerName).switchSelector(currentBurnerInfo)
        end
        -- Update the modulation level of the burner
        local currentModulationLevel = tonumber(jsonThermostatInfo.currentModulationLevel)
        if domoticz.devices(ToonBoilerModulation).percentage + 1 ~= currentModulationLevel + 1 then
            -- domoticz.log('Updating the Modulation sensor to new value: ' ..currentModulationLevel)
            domoticz.devices(ToonBoilerModulation).updatePercentage(currentModulationLevel)
        end
         -- Update the temperature Boiler setpoint to current boiler set point
        local currentInternalBoilerSetpoint = jsonThermostatInfo.currentInternalBoilerSetpoint+1
        if domoticz.utils.round(domoticz.devices(ToonBoilerSetpoint).temperature, 1) ~= domoticz.utils.round(currentInternalBoilerSetpoint, 1) then
            -- domoticz.log('Updating the Boiler internal temperature setpoint to new value: ' ..currentInternalBoilerSetpoint)
            domoticz.devices(ToonBoilerSetpoint).updateTemperature(currentInternalBoilerSetpoint)
        end
        -- Update the thermostat sensor to current setpoint
        if domoticz.devices(ToonThermostat).setPoint*100 ~= currentSetpoint*100 then
            -- domoticz.log('Updating thermostat sensor to new set point: ' ..currentSetpoint)
            domoticz.devices(ToonThermostat).updateSetPoint(currentSetpoint).silent()
        end
        -- Update the temperature sensor to current room temperature
        if domoticz.utils.round(domoticz.devices(ToonTemperature).temperature, 1) ~= domoticz.utils.round(currentTemperature, 1) then
            -- domoticz.log('Updating the temperature sensor to new value: ' ..currentTemperature)
            domoticz.devices(ToonTemperature).updateTemperature(currentTemperature)
        end
        -- Update the toon scene selector sensor to current program state
        if domoticz.devices(ToonScenes).level ~= currentActiveState then  -- Update toon selector if it has changed
            -- domoticz.log('Updating Toon Scenes selector to: '..currentActiveState)
            domoticz.devices(ToonScenes).switchSelector(currentActiveState).silent()
        end
        -- Updates the toon auto program switch
        if domoticz.devices(ToonAutoProgram).level ~= currentProgramState then -- Update toon auto program selector if it has changed
            -- domoticz.log('Updating Toon Auto Program selector to: '..currentProgramState)
            domoticz.devices(ToonAutoProgram).switchSelector(currentProgramState).silent()
        end
        -- Updates the toon program information text box
        local currentNextTime = jsonThermostatInfo.nextTime
        local currentNextSetPoint = tonumber(jsonThermostatInfo.nextSetpoint) / 100
        if currentNextTime == 0 or currentNextSetPoint == 0 then
            ToonProgramInformationSensorValue = 'Op ' ..currentSetpoint.. '°'
        else
            ToonProgramInformationSensorValue = 'Om ' ..os.date('%H:%M', currentNextTime).. ' op ' ..currentNextSetPoint.. '°'
        end
        if domoticz.devices(ToonProgramInformation).text ~= ToonProgramInformationSensorValue then
            -- domoticz.log('Updating Toon Program Information to: '..ToonProgramInformationSensorValue)
            domoticz.devices(ToonProgramInformation).updateText(ToonProgramInformationSensorValue)
        end
	end
B Overdevest
Rooted Toon, Raspberry 3B+, Domoticz
madpatrick
Post by madpatrick »
BOverdevest wrote:Based on several posts, I combined getting all Toon data to Domoticz in a single DzVents script. So both boiler data, thermostat data and the P1 data.
Great work !!
Only i'm not able to get the P1 meters.
I'm getting errors and then the script stops.
2018-10-28 17:43:00.506 Status: dzVents: Info: ------ Start internal script: Toon:, trigger: every minute
2018-10-28 17:43:00.585 Status: dzVents: Error (2.4.6): An error occured when calling event handler Toon
2018-10-28 17:43:00.585 Status: dzVents: Error (2.4.6): /var/domoticz/scripts/dzVents/generated_scripts/Toon.lua:58: attempt to index field 'dev_44' (a nil value)
2018-10-28 17:43:00.585 Status: dzVents: Info: ------ Finished Toon
Am i missing maybe some strings ?
NaDeToon
Post by NaDeToon »
I have everything working in Domoticz. It’s working great.
Is there a solution to control Toon by a custom temperature instead of the 4 setpoints?
I would like to say to Google Home for example “set temperature to 21 degrees”.
Cheers!
Edwin66
Post by Edwin66 »
Seems to be using some other user-variables.
madpatrick
Edwin66 wrote:Seems to be using some other user-variables.
Corrrect. but you can adjust these easily
The only thing i'm not getting to work in the P1 powerconsumption and P1 Powerdelivery (solarpanels)
Edwin66
Post by Edwin66 »
I don't have solarpanels, and P1 is only hooked to Toon, so I don't get any reading from them at all.
Edwin66
Post by Edwin66 »
madpatrick wrote: Only i'm not able to get the P1 meters.
Got those at line 57, but it looks like the same error.
madpatrick
Try to change dev_44 to dev_24
Edwin66
Post by Edwin66 »
Tried, but still same error.
Time to look a bit further, but for now I'll just comment out those lines for the P1 meter
Log:
018-11-04 09:30:00.070 Status: dzVents: Info: ------ Start internal script: TOON:, trigger: every minute
2018-11-04 09:30:00.463 Status: dzVents: Info: {["dev_2.1"]={["CurrentGasQuantity"]="672281.00", ["internalAddress"]="2.1", ["name"]="HAE_METER_v3_1", ["supportedCC"]="5e 59 85 8e 3c 3d 3e", ["uuid"]="f2393423-dde2-4f30-a5ea-561a19361126", ["ccList"]="5e 59 85 8e 3c 3d 3e", ["CurrentGasFlow"]="422.00", ["DeviceName"]="HAE_METER_v3_1", ["supportsCrc"]="0", ["type"]="HAE_METER_v3_1", ["nodeFlags"]={}}, ["dev_2.2"]={["internalAddress"]="2.2", ["name"]="HAE_METER_v3_2", ["supportedCC"]="5e 59 85 8e 3c 3d 3e", ["uuid"]="84ecf9de-3ff7-4b94-b14e-9add4e9a55c5", ["ccList"]="5e 59 85 8e 3c 3d 3e", ["DeviceName"]="HAE_METER_v3_2", ["supportsCrc"]="0", ["type"]="HAE_METER_v3_2", ["nodeFlags"]={}}, ["dev_2.5"]={["internalAddress"]="2.5", ["name"]="HAE_METER_v3_5", ["supportedCC"]="5e 59 85 8e 3c 3d 3e", ["uuid"]="95a0485e-f462-43c4-a2b6-a58b47230f53", ["CurrentElectricityFlow"]="0.00", ["ccList"]="5e 59 85 8e 3c 3d 3e", ["DeviceName"]="HAE_METER_v3_5", ["CurrentElectricityQuantity"]="0.00", ["supportsCrc"]="0", ["type"]="HAE_METER_v3_5", ["nodeFlags"]={}}, ["dev_2.6"]={["internalAddress"]="2.6", ["name"]="HAE_METER_v3_6", ["supportedCC"]="5e 59 85 8e 3c 3d 3e", ["uuid"]="ec38b1d6-fa71-43e6-bc36-a26acceb7c52", ["CurrentElectricityFlow"]="383.00", ["ccList"]="5e 59 85 8e 3c 3d 3e", ["DeviceName"]="HAE_METER_v3_6", ["CurrentElectricityQuantity"]="2516398.00", ["supportsCrc"]="0", ["type"]="HAE_METER_v3_6", ["nodeFlags"]={}}, ["dev_2.8"]={["internalAddress"]="2.8", ["name"]="HAE_METER_v3_8", ["supportedCC"]="5e 59 85 8e 3c 3d 3e", ["uuid"]="95f2ab46-e8b5-4ae1-bd95-b599782e5852", ["ccList"]="5e 59 85 8e 3c 3d 3e", ["CurrentHeatQuantity"]="NaN", ["DeviceName"]="HAE_METER_v3_8", ["supportsCrc"]="0", ["type"]="HAE_METER_v3_8", ["nodeFlags"]={}}, ["dev_2.4"]={["internalAddress"]="2.4", ["name"]="HAE_METER_v3_4", ["supportedCC"]="5e 59 85 8e 3c 3d 3e", ["uuid"]="ed4642ef-285a-487c-b1e5-e5fd9f7e1aa1", ["CurrentElectricityFlow"]="0.00", ["ccList"]="5e 59 85 8e 3c 3d 3e", ["DeviceName"]="HAE_METER_v3_4", ["CurrentElectricityQuantity"]="2620126.00", ["supportsCrc"]="0", ["type"]="HAE_METER_v3_4", ["nodeFlags"]={}}, ["dev_settings_device"]={["type"]="settings_device", ["internalAddress"]="settings_device", ["uuid"]="6b6a1f78-bea9-46f9-a053-87461583d393", ["name"]="settings_device"}, ["dev_2.3"]={["internalAddress"]="2.3", ["name"]="HAE_METER_v3_3", ["supportedCC"]="5e 59 85 8e 3c 3d 3e", ["uuid"]="956d126a-a3c5-4964-91c0-1af315fb9f2c", ["CurrentElectricityFlow"]="NaN", ["ccList"]="5e 59 85 8e 3c 3d 3e", ["DeviceName"]="HAE_METER_v3_3", ["CurrentElectricityQuantity"]="NaN", ["supportsCrc"]="0", ["type"]="HAE_METER_v3_3", ["nodeFlags"]={}}, ["dev_4"]={["internalAddress"]="4", ["name"]="NAS_WR01Z-1", ["supportedCC"]="5e 72 86 85 59 5a 73 70 25 27 71 32 20", ["HealthValue"]="10", ["uuid"]="51c4226e-9bd0-4768-8336-60889fe24f5b", ["CurrentElectricityFlow"]="0.00", ["IsConnected"]="1", ["ccList"]="5e 72 86 85 59 5a 73 70 25 27 71 32 20", ["TargetStatus"]="1", ["DeviceName"]="NAS_WR01Z-1", ["CurrentElectricityQuantity"]="3860.00", ["supportsCrc"]="0", ["type"]="NAS_WR01Z", ["nodeFlags"]={}}, ["dev_2"]={["internalAddress"]="2", ["name"]="HAE_METER_v3", ["supportedCC"]="5e 86 72 32 56 5a 59 85 73 7a 60 8e 22 70 8b 3c 3d 3e", ["uuid"]="613a67ae-0412-45b3-9a1a-c147570fa19a", ["IsConnected"]="1", ["ccList"]="5e 86 72 32 56 5a 59 85 73 7a 60 8e 22 70 8b 3c 3d 3e", ["DeviceName"]="HAE_METER_v3", ["HealthValue"]="10", ["supportsCrc"]="1", ["type"]="HAE_METER_v3", ["nodeFlags"]={}}, ["dev_2.7"]={["internalAddress"]="2.7", ["name"]="HAE_METER_v3_7", ["supportedCC"]="5e 59 85 8e 3c 3d 3e", ["uuid"]="7400faa9-f92f-4fb5-b7f2-4ffde650469f", ["CurrentElectricityFlow"]="0.00", ["ccList"]="5e 59 85 8e 3c 3d 3e", ["DeviceName"]="HAE_METER_v3_7", ["CurrentElectricityQuantity"]="0.00", ["supportsCrc"]="0", ["type"]="HAE_METER_v3_7", ["nodeFlags"]={}}}
2018-11-04 09:30:00.468 Status: dzVents: Error (2.4.6): An error occured when calling event handler TOON
2018-11-04 09:30:00.471 Status: dzVents: Error (2.4.6): ...e/pi/domoticz/scripts/dzVents/generated_scripts/TOON.lua:57: attempt to index field 'dev_44' (a nil value)
2018-11-04 09:30:00.471 Status: dzVents: Info: ------ Finished TOON
mAiden
Post by mAiden »
@Edwin66
dev_2.2 is your're dev, Try that one?
or: dev_2.1
or: dev_2.5
or: dev_2.6
or: dev_2.8
Don't forget the underscore _ and the dot between 2 and 8 ;)
Edwin66
Post by Edwin66 »
Thanks. Will try those numbers :)
Edwin66
Post by Edwin66 »
Screen Shot 2018-11-04 at 22.16.18.png (46.95 KiB) Viewed 14582 times
When i enter a number like dev_2.1 it gives an error right after putting it in, complaining about " expected ')' near '0.1' "
Guess this is something I need to work on tomorrow. Now it's time for other fun things
