ZonOpToon alternative
Forum about Toon hardware, both versions 1 and 2 of Toon
Re: ZonOpToon alternative
Postby Cctl01 » Sat Nov 10, 2018 1:55 pm
Sorry for the double posting but I already found the answer to my question here.
https://www.domoticaforum.eu/viewtopic.php?t=11587
Would in your opinion the next best solution be to create a tile that displays the p1 reading and solar out from Domoticz?
I have everything setup there, I'm just looking for a nifty way to display the readings on Toon.
Cctl01
Postby madpatrick » Fri Nov 23, 2018 4:45 pm
TerrorSource wrote:Hi guys,
I found an interesting way to do the ZonOpToon cheaper then the usual way.
Someone pointed me to the KWH1073PRO fuse box module, as a replacement for an official ZonOpToon fuse box module.
shop1: https://mdhelektroshop.nl/dmmetering-kw ... p-u-mid-23
shop2: https://www.installatievakwinkel.nl/ine ... kwh1073pro (slightly cheaper)
1. Buy it
2. Put it in the fuse box
3. Connect 1 analog wire to the module and the meteradapter
4. change the value's of "SolarDisplay" and "SolarActivated" in scsync.xml in 1 (instead of 0)
5. Reboot the toon
6. Wait untill the sun's up :)
Maybe a "stupid" question, but can you use the standard (Eneco) optic sensor with this module ?
madpatrick
Postby TerrorSource » Fri Nov 23, 2018 5:09 pm
Well you need to. There is no other option to read the data from the Solar module with the Meteradapter.
TerrorSource
Postby TheHogNL » Fri Nov 23, 2018 5:49 pm
TerrorSource wrote:Well you need to. There is no other option to read the data from the Solar module with the Meteradapter.
Led optic (via the sensor) or wired using S0 is both possible. Eneco doesn't connect using S0, only using the optic sensor though.
Postby madpatrick » Sun Dec 09, 2018 11:18 am
Where can you get the mountingclip to mount the sensor to the KwH meter ?
Is this supplied with the Toon ? it was not with the KwH module
madpatrick
Postby TheHogNL » Sun Dec 09, 2018 7:55 pm
madpatrick wrote:Where can you get the mountingclip to mount the sensor to the KwH meter ?
It is supplied with the sensors. Nowadays the sensors are not included standard in a new toon.
But I would advice to make a s0 wired connection instead of reading the led with the sensor. This is much more precise.
Postby madpatrick » Sun Dec 09, 2018 11:12 pm
It is working bit indeed not accurate.
Even at night is say it is producing 6w
madpatrick
Postby TheHogNL » Mon Dec 10, 2018 8:01 am
madpatrick wrote:It is working bit indeed not accurate.
This is your inverter in night mode taking some power. Which kWh meter are you using? Some calculate in both directions indepently, some caclulate both directions together.
Postby madpatrick » Mon Dec 10, 2018 8:40 am
TheHogNL wrote:This is your inverter in night mode taking some power. Which kWh meter are you using? Some calculate in both directions indepently, some caclulate both directions together.
I'm using the INEPRO KWH1073PRO.
Not sure if this is calculating both directions.
Will this be resolvd by wiring S0 instead of optic sensor?
madpatrick
Postby TheHogNL » Mon Dec 10, 2018 4:54 pm
Eneco also is using this meter (pro1-s, not the pro1-2t but almost the same).
S0 or led doesn't make a difference in what is is doing.
However, look at the manual https://ineprometering.com/wp-content/u ... -V2.18.pdf section 7.11. I'm not sure but it looks like you can config if you want forward, reverse, both, the difference etc only.
Postby madpatrick » Mon Dec 10, 2018 9:22 pm
TheHogNL wrote:Eneco also is using this meter (pro1-s, not the pro1-2t but almost the same).
I will try to change the setup
Only now find the button....
madpatrick
Postby TheHogNL » Mon Dec 10, 2018 9:33 pm
Isn't it the big arrow? Just like in this video (different brand, 3 fase.. but you see what i mean :) https://www.youtube.com/watch?v=zazgV3QtJaA )
Postby madpatrick » Mon Dec 31, 2018 3:37 pm
TheHogNL wrote:Isn't it the big arrow? Just like in this video (different brand, 3 fase.. but you see what i mean :) https://www.youtube.com/watch?v=zazgV3QtJaA )
Yep. this scrolls through the menu.
Unfortunately i can get in to the program menu.
Tried everything and scrolled the complete menu >20x. Hold the button 3-5 sec ....
Looks like you need the USB IR-eye, but unable to find one on the internet.
madpatrick
Postby dennis071nl » Mon Jan 21, 2019 5:07 am
Hey guys,
I really would like to have the Zon op Toon functionality but i'm not really into electrical stuff...:-)
I got a 3 *25 connection at my home, the solar panels have a integrated inverter. All panels are connected to a separate group.
Would it be better to buy the 3 or 1 phase Kwh meter for replacement of the existing fuse??
Thanks, Dennis
dennis071nl
Postby TheHogNL » Mon Jan 21, 2019 8:18 am
First of all. You don't replace the fuse :-) The kWh meter is added in series between the installation wires and the fuse.
Which kWh meter depends on if your solar panels are wired 3-fase or 1-fase to the rest of your fusebox. Doesn't matter if your house is 3-fase or 1-fase connected to the grid.
It is easy to check how it is connected. Is your extra fuse for the solar panels group a 1-fase or 3-fase? 1-fase is ofter 1 or 2 slots big. 3-fase is 4-slots big.
PreviousNext
Return to Toon Hardware
