Toon mobile access
Toon mobile access
Post by TheHogNL »
Happy to release a new app in the toonstore called "ToonMobile". This is a TSC modification of the old 'www-toon-mobile' package which was provided by Quby ages ago.
It is available to install from toonstore. It is not a GUI app as the rest is but a webpage/javascript application (in /qmf/www).
This will allow you to control your toon on your computer or mobile phone via the url http://[toon-ip]/mobile from your home network.
And if you open op your router or create a proxy-forward or have VPN towards you home network, you could also control your Toon outside of your home network.
MyZ
Re: Toon mobile access
Post by MyZ »
Nice! I already have the "old" Quby webinterface running. What is the difference between the TSC version and the old one?
For now it's the same, although our icons are nicer :-).
We are going to develop this one further.
First change coming soon is the rounding of the actual temperature to 0.1 degree instead of 0.5 degrees.
This to match the value displayed on Toon.
More to come, ideas for future functionality can be posted here.
MyZ
Post by MyZ »
Good one. Ideal for the people without Home Assistant / Domoticz!
My ideas:
-If a smart meter is connected, show the daily gas usage instead of liters/hour
-Login page
-Turn on "vacation mode"
version 1.0.3 is available.
Changelog:
- round actual temperature to 0,1 degrees instead of 0,5 degrees
MyZ wrote:Good one. Ideal for the people without Home Assistant / Domoticz!
My ideas:
-Login page
Thanks, I like the vacation mode option, will look into the others as well
newwolf
Post by newwolf »
Nice, are you also going to have a look on the consum page?
Because it's telling me I'm using "237 liter/uur", but with a year usage of 950m3 I'm believing that. :)
Post by TheHogNL »
newwolf wrote:Nice, are you also going to have a look on the consum page?
950m3 divided by roughly 100 days of cold in a year makes 9,5m3 per day which makes around 395 liters per hour, close enough at 237 for this rough guessing. So those numbers are ok I think.
MyZ
Post by MyZ »
The usage page uses "real-time" readings. For a smart meter this is the last hour (gas), as the smart meter only does one reading per hour. I think that these numbers make sense if you have an anolog meter (it will be real-time), but for a smart meter it doesn't have much added value imho.
newwolf
Post by newwolf »
Damn, you should also become a accountant :P
Did not calculated it that way :-)
But it looks a little bit strange, because Power is real-time and for Gas it's more per hour.
Nevermind at all, you did the calculation trick that convinced me :-)
WickedMaster
Post by WickedMaster »
In my customized webpage I'm able to turn on/off the connected smart plugs, it also updates the on/off status on the Toon itself. Will post the code when it's fancy enough.
Post by TheHogNL »
newwolf wrote: But it looks a little bit strange, because Power is real-time and for Gas it's more per hour.
Yes that is because the gas information is only realiable available once per hour as the gas meter isn't providing better data. Only on newer smart meters the gas information is sent more frequenly.
But giving a gas 'liters per second' is never going to be realistic :)
MyZ
Post by MyZ »
Toonz wrote:Hi all,
Changelog:
Doesn't work here? Can it be interfering with my previous "old Quby" installation?
running ok here on two Toon 2's and one Toon 1.
Did 1.0.2 work for you?
can try to uninstall the old Quby one first before installing this one?
MyZ
Post by MyZ »
Yes, 1.0.2 did seem working. Saw the new logo.
How can I safely uninstall the whole old Quby?
