Toon for Android
Re: android app TOON
Just installed your app on my ancient Samsung Galaxy S3 mini. Screen resolution barely non-negative ;-).
Apart from my compliments for this functioning app, just a few remarks:
The screen doesn't fit my phone, see attached screenshot. It could be the age of my phone, or the fact that my toon is a toon2? Toon screen resolution 1024*600 or thereabouts?
There's a linefeed "\n" in view in the program step window "Om 23:00 uur \n op..."
As soon as I want to adjust temp I get the message "Fout bij het ophalen van temperatuurgegevens: response data or responseHandler is null". That could also be because of my toon being on my desk and not connected to a boiler. Will attach it to my boiler emulator later this week.
WickedMaster
Post by WickedMaster »
S3 Mini is too old for these days.... So, yes, it's because of the age of your phone.
The newline issue is fixed in the next release. And we're working on the responseHandler error.
Re: Toon for Android
WickedMaster wrote:S3 Mini is too old for these days.... So, yes, it's because of the age of your phone.
It suits my needs. Will start working on the VNC server for toon2 then as an alternative.
RoadXY
Post by RoadXY »
marcelr wrote:Just installed your app on my ancient Samsung Galaxy S3 mini. Screen resolution barely non-negative ;-).
No, we fetch the data and set that in our own UI.
I knew this was an problem however I don't have an solution as of yet and, since most of the devices won't be having this issue, It'll be not very high on the (now very long) to-do list, I'm sorry.
marcelr wrote:As soon as I want to adjust temp I get the message "Fout bij het ophalen van temperatuurgegevens: response data or responseHandler is null". That could also be because of my toon being on my desk and not connected to a boiler. Will attach it to my boiler emulator later this week.
Nope, that's not because of your boiler but an error in the app.
But since like an hour, I too have an rooted Toon (Thanks to WickedMaster!) so I'll be able to try and resolve these issues.
RoadXY
Post by RoadXY »
We'll figure something out, don't worry.
If there are more people having the same issue we'll handle it sooner.
yjb
Post by yjb »
Not sure if this was reported already: Stroom nu gives N/A, while GAS is correct.
Also, I'm not too excited about the 2 digit precision behind the comma: 18.22. It gives the impression that the temperature measurement is very accurate (while it's not that precise).
Other than that: Good Job!
RoadXY
Post by RoadXY »
yjb wrote:Hi,
Not sure if this was reported already: Stoom nu gives N/A, while GAS is correct.
Could you provide me the output of:
http://[toonip]/hdrv_zwave?action=getDevices.json
yjb wrote:Also, I'm not too excited about the 2 digit precision behind the comma: 18.22. It gives the impression that the temperature measurement is very accurate (while it's not that precise).
The 'two digi issue' is already solved in the upcoming alpha version: see here https://github.com/fabianblom/Toon-Android/issues/14
yjb wrote:Other than that: Good Job!
Thanks!
RoadXY
Post by RoadXY »
Updated the first post on where to check if there isn't already an issue created.
yjb
Post by yjb »
[/quote]
Here you go:
<SNIP>
   "dev_3":{
      "uuid":"8535fd22-4500-45bb-8852-f5c7160a5c90",
      "name":"HAE_METER_v3",
      "internalAddress":"3",
      "type":"HAE_METER_v3",
      "supportsCrc":"1",
      "ccList":"5e 86 72 32 56 5a 59 85 73 7a 60 8e 22 70 8b 3c 3d 3e",
      "supportedCC":"5e 86 72 32 56 5a 59 85 73 7a 60 8e 22 70 8b 3c 3d 3e",
      "nodeFlags":[
      "IsConnected":"1",
      "HealthValue":"10",
      "DeviceName":"HAE_METER_v3"
   "dev_3.1":{
      "uuid":"d776e6d1-24e5-4b4e-8d89-2c68735489b3",
      "name":"HAE_METER_v3_1",
      "internalAddress":"3.1",
      "type":"HAE_METER_v3_1",
      "supportsCrc":"0",
      "ccList":"5e 59 85 8e 3c 3d 3e",
      "supportedCC":"5e 59 85 8e 3c 3d 3e",
      "nodeFlags":[
      "CurrentGasFlow":"3.00",
      "CurrentGasQuantity":"1243684.00",
      "DeviceName":"HAE_METER_v3_1"
   "dev_3.2":{
      "uuid":"a85b3097-3076-45bf-9ab1-7f671dc13f5b",
      "name":"HAE_METER_v3_2",
      "internalAddress":"3.2",
      "type":"HAE_METER_v3_2",
      "supportsCrc":"0",
      "nodeFlags":[
      "DeviceName":"HAE_METER_v3_2",
      "CurrentElectricityFlow":"NaN",
      "CurrentElectricityQuantity":"NaN"
   "dev_3.3":{
      "uuid":"aacf62a8-80d5-4061-885a-d27d4c7c2162",
      "name":"HAE_METER_v3_3",
      "internalAddress":"3.3",
      "type":"HAE_METER_v3_3",
      "supportsCrc":"0",
      "nodeFlags":[
      "DeviceName":"HAE_METER_v3_3",
      "CurrentElectricityFlow":"221.00",
      "CurrentElectricityQuantity":"207653.00"
   "dev_3.4":{
      "uuid":"0cef5b2b-7272-4143-906f-59b284070bb4",
      "name":"HAE_METER_v3_4",
      "internalAddress":"3.4",
      "type":"HAE_METER_v3_4",
      "supportsCrc":"0",
      "nodeFlags":[
      "DeviceName":"HAE_METER_v3_4",
      "CurrentElectricityFlow":"378.00",
      "CurrentElectricityQuantity":"828564.00"
   "dev_3.5":{
      "uuid":"eb6ba2f9-558d-4944-b238-258a70115c77",
      "name":"HAE_METER_v3_5",
      "internalAddress":"3.5",
      "type":"HAE_METER_v3_5",
      "supportsCrc":"0",
      "nodeFlags":[
      "DeviceName":"HAE_METER_v3_5",
      "CurrentElectricityFlow":"0.00",
      "CurrentElectricityQuantity":"146780.00"
   "dev_3.6":{
      "uuid":"efe14178-7bdc-4d14-b1fa-32a5deaf4d6a",
      "name":"HAE_METER_v3_6",
      "internalAddress":"3.6",
      "type":"HAE_METER_v3_6",
      "supportsCrc":"0",
      "nodeFlags":[
      "DeviceName":"HAE_METER_v3_6",
      "CurrentElectricityQuantity":"1110590.00"
   "dev_3.7":{
      "uuid":"22397305-82e3-46c1-b0f0-05dbe3263f30",
      "name":"HAE_METER_v3_7",
      "internalAddress":"3.7",
      "type":"HAE_METER_v3_7",
      "supportsCrc":"0",
      "nodeFlags":[
      "DeviceName":"HAE_METER_v3_7",
      "CurrentElectricityQuantity":"71583.00"
   "dev_3.8":{
      "uuid":"e0a42332-622a-43a4-bbf7-c516ef5f8745",
      "name":"HAE_METER_v3_8",
      "internalAddress":"3.8",
      "type":"HAE_METER_v3_8",
      "supportsCrc":"0",
      "nodeFlags":[
      "DeviceName":"HAE_METER_v3_8",
      "CurrentHeatQuantity":"NaN"
   "dev_settings_device":{
      "uuid":"d6d5ce1d-2055-40f4-b9b3-991f1a8f6848",
      "name":"settings_device",
      "internalAddress":"settings_device",
      "type":"settings_device"
<SNIP>
(I believe the dev devices are not always the same, so you might want to make this a configurable option.
As you can see I have also zon op toon with feed in quantities (dev_3.3)
RoadXY
Post by RoadXY »
Versie 0.5.3 is naar de alpha:
  • Verbetering: Slechts 1 cijfer achter de comma (Lost issue 14 op)
    Bug fix: Laat alleen een melding zien als er echt iets fout gaat (Lost issue 13 op)
    Verbetering: Terugkoppeling als je de 'ververs knop' gebruikt (Lost issue 15 op)
    Verbetering: Gebruik 'burner info' (alleen op OpenTherm?) om a.d.h. daarvan een vlam te tonen (of niet).
    Bug fix: Als de app gestart word, werd niet de juiste mode knop ingeschakeld
    Verbetering: Verander de layout van de mode knoppen om meer overeen te komen met Toon
_Arjen_
Post by _Arjen_ »
Installed the app on a Huawei Mate 10 Lite, after connecting to Toon the app immediately crashes.
When I am back home I will see if I can get a logcat.
RoadXY
Post by RoadXY »
_Arjen_ wrote:Installed the app on a Huawei Mate 10 Lite, after connecting to Toon the app immediately crashes.
Did you leave an review on the Play Store?
I got an crash report about a Huawei Mate 10 Lite but it didn't mention anithing about any code/app.
java.lang.NullPointerException:
  at android.app.assist.AssistStructure$WindowNode.<init> (AssistStructure.java:484)
  at android.app.assist.AssistStructure.<init> (AssistStructure.java:1908)
  at android.app.ActivityThread.handleRequestAssistContextExtras (ActivityThread.java:3580)
  at android.app.ActivityThread$H.handleMessage (ActivityThread.java:2238)
  at android.os.Handler.dispatchMessage (Handler.java:108)
  at android.os.Looper.loop (Looper.java:166)
  at android.app.ActivityThread.main (ActivityThread.java:7529)
  at java.lang.reflect.Method.invoke (Native Method)
  at com.android.internal.os.Zygote$MethodAndArgsCaller.run (Zygote.java:245)
  at com.android.internal.os.ZygoteInit.main (ZygoteInit.java:921)
RoadXY
Post by RoadXY »
https://github.com/fabianblom/Toon-Android/issues/24
Much better in 0.5.4
marcelr wrote:There's a linefeed "\n" in view in the program step window "Om 23:00 uur \n op..."
Fixed in 0.5.4
Fixed in 0.5.4
_Arjen_
Post by _Arjen_ »
That was me ;)
Didn't have any time yet to troubleshoot, but will add my findings to the issues on Github
RoadXY
Post by RoadXY »
_Arjen_ wrote:That was me ;)
Great.
I did find something which could be related to your issue:
https://stackoverflow.com/questions/458 ... utedittext
