Toon for Android
ikookmaar
Re: Toon for Android
Post by ikookmaar »
Could anyone direct me to some instructions on how and where to configure a redirection service using an an Api token (or login authentication, if it works) to safely control the Toon from the internet with this app?.
This is not exactly the same as a reverse-proxy, is it?
I have a Raspberry Pi I could use, running Apache2 as well as Domoticz (haven't figured out what webserver this runs on) ...
Thanks!
mAiden
Post by mAiden »
ikookmaar wrote:Could anyone direct me to some instructions on how and where to configure a redirection service using an an Api token (or login authentication, if it works) to safely control the Toon from the internet with this app?.
Thanks!
You could look to run OpenVPN on your Raspberry PI, to use the Toon app? I use a Draytek VPN to connect to my PI or my rooted Toon.
RoadXY
Post by RoadXY »
Thanks!
Redirection service could be used with an reverse proxy while adding an extra header.
Based on the header the proxy will proxy the requests through to your internal device (i.e. Toon).
I'm working on using a reverese proxy with basic authentication and ssl.
If I got this working I'll be updating the app to support this scenario.
An nice feature would be to have an cloud connection and have Toon set up an VPN to it.
Maybe someday :D
glsf91
Post by glsf91 »
Thanks!
Configure OpenVPN on your router. Install openVPN on your phone. Then you can access everything from your phone in your house.
_Arjen_
Post by _Arjen_ »
RoadXY wrote: An nice feature would be to have an cloud connection and have Toon set up an VPN to it.
Maybe someday :D
Well, since openvpn is already installed on Toon, one could adapt the config. We can setup Toon as vpn-server or use vpn-client to connect to another server as Eneco so one can access it via that VPN-server.
ikookmaar
Post by ikookmaar »
All nice ideas, but how is (or was) this "Gebruik redirection service" and "Api token" intended to be used?
RoadXY
Post by RoadXY »
ikookmaar wrote:All nice ideas, but how is (or was) this "Gebruik redirection service" and "Api token" intended to be used?
See my previous reply, using a reverse proxy while using custom headers
anconakip
Post by anconakip »
i want to use this app to. But i need to fill in the "Toon poort". how can i find this?
_Arjen_
Post by _Arjen_ »
It is 10080
anconakip
Post by anconakip »
_Arjen_ wrote:It is 10080
Nope. Sorry. The the app say to me: pagina niet gevonden op apparaat.
And if i do 10800 the iT says: geen reactie van apparaat.
WickedMaster
Post by WickedMaster »
You can try port 80 as well.
mAiden
Post by mAiden »
Go to you're iptables (/etc/default/iptables), and look for this line:
-A HCB-INPUT -p tcp -m tcp --dport 22 --tcp-flags SYN,RST,ACK SYN -j ACCEPT
-A HCB-INPUT -p tcp -m tcp --dport 80 --tcp-flags SYN,RST,ACK SYN -j ACCEPT
-A HCB-INPUT -p tcp -m tcp --dport 10080 --tcp-flags SYN,RST,ACK SYN -j ACCEPT
RoadXY
Post by RoadXY »
Anyone using a Nokia Nokia 7.1 (CTL_sprout) on Android 9?
I'v got like 40 crashes on 12 mei at 17:09
I've received a lot of crash reports from this user and I'd like to investigate what goes wrong.
PeJeWe
Post by PeJeWe »
the app starts, then i fill in the IP and the port 10800,i get the positive connection "aangemeld" then the app crashes and keeps crashing after restart.
Android 8.1
edit:
after firmware update 5.5.7 i get the error wrong host.
ip_adress_toon/qmf/www gives an error 404
Rooted Toon 1, Domoticz running on a RPI3b+, RFXCOM XL, RFLINK.
mAiden
Post by mAiden »
PeJeWe wrote:the app starts, then i fill in the IP and the port 10800,i get the positive connection "aangemeld" then the app crashes and keeps crashing after restart.
Android 8.1
edit:
Try to run update-rooted.sh script with the -f parameter.
