Toon app: Kalender
Re: Toon app: Kalender
Postby Toonz » Fri Nov 01, 2019 11:22 am
ArieKanarie wrote:The current one, or the one I am trying to make?
both would be helpful
Postby ArieKanarie » Fri Nov 01, 2019 4:26 pm
It is the default file, with only one line, the dutch holidays.
ArieKanarie
Postby Toonz » Fri Nov 01, 2019 5:30 pm
ArieKanarie wrote:It is the default file, with only one line, the dutch holidays.
which file are you editing exactly (full path)?
Postby ArieKanarie » Sat Nov 02, 2019 10:44 am
/qmf/qml/apps/calendar-1.1.4/userSettings.json
ArieKanarie
Postby Toonz » Sat Nov 02, 2019 11:05 am
weird, the file is only created during first installation from the ToonStore.
After a reboot it should stay untouched.
Almost feels like your changes are not saved properly on the Toon.
I can help you via TeamViewer if you want somewhere next week to see what is going on.....
Just send me a PM with your phone number where I can reach you.
Postby ArieKanarie » Sat Nov 02, 2019 11:33 am
hmmm, did another try: edited the file again, saved it.
Closed the connection and reconnected to check if the file was really saved (which it was) , rebooted, and now the Toon hangs with 'retrieving calendars' which usually was a good sign.
looking good so far....
-edit-
It is amazing mike! Now the calendar is loaded without problems. Shoot me but leak :wink:
ArieKanarie
Postby ArieKanarie » Sat Nov 02, 2019 2:53 pm
And now the reboots are back :cry:
Going to change the file back, to make sure it is the calendar.
ArieKanarie
Postby Toonz » Mon Nov 04, 2019 10:12 pm
a small maintenance release 1.1.5 is available in the ToonStore.
Changelog:
- settings are now stored in the /mnt/tsc/data folder
- firmware 5 compatible only, support for lower firmwares has been dropped
Kind regards,
Postby ArieKanarie » Sat Nov 09, 2019 11:34 am
Toonz wrote:/mnt/tsc/data folder
/mnt/data/tsc :)
ArieKanarie
Postby Strijker » Sun Nov 10, 2019 11:33 pm
installed 1.1.5, but no userSettings.json file to be found anywhere.
It seems one needs be added as /mnt/data/tsc/calendar.userSettings.json
(note the addition of 'calendar.' in front of userSettings.json)
Strijker
Postby Toonz » Mon Nov 11, 2019 8:43 pm
Strijker wrote:installed 1.1.5, but no userSettings.json file to be found anywhere.
you're right that the file is not created automatically if you never had the app before and install thelatest version for the first time.
Maybe I will change that.
Anyway , you can create the file yourself with this content:
{"ShowNotifications":"Yes", "Calendar_URL":[ "https://<calendarurl_to_basic.ics>" , "https://calendar.google.com/calendar/ical/nl.dutch%23holiday%40group.v.calendar.google.com/public/basic.ics" ]}
and/or go to the Instellingen page and press 'Opslaan'
Postby Ossegek » Tue Dec 10, 2019 8:17 am
Sinds gisteren de Toon geroot, dus ben nog zoekende. Maar via Filezilla een verbinding opgesteld, maar ik krijg dit bestand of andere niet gevonden hoor.
Dus om mijn eigen Agenda toe te voegen.
Wat me ook opgevallen is dat ik 2 mappen met calenders heb. Zie afbeelding
Ossegek
Postby ArieKanarie » Wed Dec 11, 2019 9:32 pm
je kijkt niet op de juist plek: /mnt/data/tsc moet het tekstbestand staan
ArieKanarie
Postby Dmeuwissen » Tue Dec 31, 2019 4:31 pm
Ik heb een geroote Toon gekocht en zou graag mijn kalender toegevoegd hebben, heb echter helaas geen kennis van domotica, wie kan mij helpen
Dmeuwissen
Postby TerrorSource » Thu Jan 02, 2020 1:26 pm
Dmeuwissen wrote:Ik heb een geroote Toon gekocht en zou graag mijn kalender toegevoegd hebben, heb echter helaas geen kennis van domotica, wie kan mij helpen
Lees deze topic eens door :) Daarin worden de meeste vragen beantwoord.
TerrorSource
PreviousNext
Return to Toon Apps
Users browsing this forum: memo1996 and 0 guests
