Toon firmware 5.18.8 released
Postby TheHogNL » Tue Dec 03, 2019 10:22 pm
Eneco released toon firmware 5.18.8 and after a few checks TSC also released 5.18.8 to the rooted community. Easiest is to check their forum to read what's new: https://forum.eneco.nl/software-en-hard ... gaan-22580
Download fase of the update is a bit slow currently due to the auto update on regular toons causing tons of toons downloading the update right now.
Re: Toon firmware 5.18.8 released
Postby Ron_nl » Wed Dec 04, 2019 3:19 pm
OMG :shock: those themes are so tacky and tasteless.
Wondering what was the person thinking when he/she made that executive decision to implement this into the software update..
I hope there is a possibility to switch them off.
Ron.
Ron_nl
Postby TheHogNL » Wed Dec 04, 2019 4:41 pm
Ron_nl wrote:OMG :shock: those themes are so tacky and tasteless.
Ron.
Let me look if I can find an easy option for this :)
Postby TerrorSource » Fri Dec 06, 2019 8:14 pm
Ron.
Yup, we saw them before the release... no-one liked the theme's. They should be focusing on solving the issues Toon has instead of making tasteless themes. :roll:
TerrorSource
Postby rbak » Sun Dec 15, 2019 5:54 pm
Decided to update my rooted Toon from firmware 5.15.6 to 5.18.8 however when running the update-rooted.sh script and selected to upgrade to version 5.18.8 I get the following warning: "Warning: upgrade script from Eneco server is changed. Do you want to continue downloading the files (if not sure, type no and report in the forums)?". As I am not 100% sure what this will do I aborted the upgrade. Is this something I shouyld indeed be concerned about or is thsi expected and am I good to go?
5.18.8
Alright, I will try to upgrade to 5.18.8
Tunnel is alive and configured.
n
rbak
Postby TheHogNL » Sun Dec 15, 2019 6:20 pm
This is a safe measure so an update of the official Toon update script can't unroot your toon if they update their script to remove all rooted toons or something like that.
You did the right thing and ask.
However the script isn't changed as I justed checked it. Makes me wonder why your Toon thinks it is. Can you run "grep feed /etc/hosts" and post the results? Can you also post your toonstore version?
Postby rbak » Sun Dec 15, 2019 6:42 pm
Sure and thanks for the quick response.
Toonstore version is 5.0.0
The result of the "grep feed /etc/hosts" is "172.28.112.1 feed.hae.int feed"
rbak
Postby TheHogNL » Sun Dec 15, 2019 6:54 pm
rbak wrote:Sure and thanks for the quick response.
Ok that looks ok.
Can you try again? And if it shows it again please cancel it again and run:
md5sum /mnt/data/update/upgrade-*.sh
Postby rbak » Sun Dec 15, 2019 7:04 pm
Ok tried just before your reply and got the same response however when I tried again just now I now get the following response:
5.18.8
Upgrade script downloaded. We need to download the upgrade files first. No upgrade is done yet. Do you want me to download the files (yes) or quit (anything else)?
So that looks a lot better. Now instead of typing "y" on the question to upgrade the script I typed "yes" so could that potentially have made the difference?
The result of "md5sum /mnt/data/update/upgrade-*.sh" is "4c06044aaebf7cace0b7aee144498bd2 /mnt/data/update/upgrade-qb2.sh" by the way.
rbak
Postby TheHogNL » Sun Dec 15, 2019 7:07 pm
rbak wrote:Ok tried just before your reply and got the same response however when I tried again just now I now get the following response:
5.18.8
No that should not made any difference. So update works now?
Postby rbak » Sun Dec 15, 2019 7:16 pm
Well it no longer showed the warning. So I believe all is OK now and started the upgrade now.
Are your sure you want to upgrade to 5.18.8 (yes)? This is the last moment you can stop the upgrade. Answer with 'yes' will start the upgrade.
yes
Starting the upgrade now! Just wait a while... It can take a few minutes.
Waiting to finish. Sometimes this takes a minute or two ...
Installing curl as in some update it is removed due to buggy dependencies...
Package curl (7.50.0-r0) installed in root is up to date.
Upgrade done!
Restoring your iptables and passwd files so you can login again after rebooting.
Upgrade is done. However each firmware upgrade will revert the changes to some files needed for a working rooted Toon. Do you want me me to try and fix a few well known issue's for you right now?
yes
creating backup of inittab...
creating backup of hosts...
FIXING: Downloading resources.rcc TSC mod for this version 5.18.8.
-- Updating custom app homeassistant to release 1.0.5 ... Removing package homeassistant from root...
Removing stale link /HCBv2/qml/apps/homeassistant
done.
DONE
-- Updating custom app wastecollection to release 4.28 ... Removing package wastecollection from root...
Running postrm on /HCBv2/qml/qb/base/Globals.qml
Removing stale link /HCBv2/qml/apps/wastecollection
Removing wastecollection from Globals.qml
sed: /HCBv2/qml/qb/base/Globals.qml: No such file or directory
Removing wastecollection from customapps
sed: /HCBv2/qml/customapps: No such file or directory
Removing files
rm: can't remove '/HCBv2/qml/apps/wastecollection-4.26/selected*.txt': No such file or directory
Completed postremove script
DONE
EDITING: disabling Eneco subscription feature apps to free up memory on this toon 1
EDITING: disabling KPI and weather happ as these are not necessary on rooted toons
EDITING: disabling samba nmbd on toon 1 as probably it is not necessary
EDITING: remove boilermonitoring subscription feature
Everything done! You should reboot now! Do NOT power cycle! Just issue the 'reboot' command in your shell. Power cycling can cause file system problems.
After the reboot all looks fine. So succes!
Did you make any changes to the script on your side?
rbak
Postby TheHogNL » Sun Dec 15, 2019 7:44 pm
rbak wrote:Well it no longer showed the warning. So I believe all is OK now and started the upgrade now.
No. So should be related to some issue on your Toon. Or VPN issue's on Eneco side. But it works now and that is the most important :)
Postby rbak » Sun Dec 15, 2019 8:06 pm
TheHogNL wrote:But it works now and that is the most important :)
Absolutely! Thanks for the lightning fast responses :D
rbak
Return to Toon Firmware
