Yeah not an good idea, my Toon is still up and running but after a reboot it's propably dead.
It removed openvpn, so I can't install the packages that have been removed.
Can somebody post the openvpn_2.3.11-r1_qb2.ipk for the Toon1 running 5.18 if I remember correctly.
These are the packages that are removed:
Removing package x11vnc from root...
Removing package openssh-sftp-server from root...
Removing package directfb from root...
libpng12 was autoinstalled and is now orphaned, removing.
Removing package libpng12 from root...
libsysfs was autoinstalled and is now orphaned, removing.
Removing package libsysfs from root...
Removing package glibc-localedata-i18n from root...
glibc-localedata-translit-neutral was autoinstalled and is now orphaned, removing.
Removing package glibc-localedata-translit-neutral from root...
glibc-localedata-translit-circle was autoinstalled and is now orphaned, removing.
Removing package glibc-localedata-translit-circle from root...
glibc-localedata-translit-cjk-compat was autoinstalled and is now orphaned, removing.
Removing package glibc-localedata-translit-cjk-compat from root...
glibc-localedata-translit-compat was autoinstalled and is now orphaned, removing.
Removing package glibc-localedata-translit-compat from root...
glibc-localedata-translit-font was autoinstalled and is now orphaned, removing.
Removing package glibc-localedata-translit-font from root...
glibc-localedata-translit-fraction was autoinstalled and is now orphaned, removing.
Removing package glibc-localedata-translit-fraction from root...
glibc-localedata-translit-narrow was autoinstalled and is now orphaned, removing.
Removing package glibc-localedata-translit-narrow from root...
glibc-localedata-translit-small was autoinstalled and is now orphaned, removing.
Removing package glibc-localedata-translit-small from root...
glibc-localedata-translit-wide was autoinstalled and is now orphaned, removing.
Removing package glibc-localedata-translit-wide from root...
glibc-localedata-iso14651-t1 was autoinstalled and is now orphaned, removing.
Removing package glibc-localedata-iso14651-t1 from root...
glibc-localedata-iso14651-t1-common was autoinstalled and is now orphaned, removing.
Removing package glibc-localedata-iso14651-t1-common from root...
Removing package modutils-initscripts from root...
Loading modules: rtl8191su rt5370sta
Removing any system startup links for modutils.sh ...
/etc/rcS.d/S20modutils.sh
Removing package tsc-certificates from root...
Cant't restore backup of ca-certificates.crt, file is newer ...
Removing package cron from root...
Stopping Vixie-cron.
Removing any system startup links for cron ...
/etc/rc0.d/K65cron
/etc/rc1.d/K65cron
/etc/rc2.d/S65cron
/etc/rc3.d/S65cron
/etc/rc4.d/S65cron
/etc/rc5.d/S65cron
/etc/rc6.d/K65cron
Removing package base-files from root...
Not deleting modified conffile /etc/fstab.
Not deleting modified conffile /etc/hostname.
Removing package openvpn from root...
lzo was autoinstalled and is now orphaned, removing.
Removing package lzo from root...
Removing package psplash-toon from root...
update-alternatives: Linking //usr/bin/psplash to /usr/bin/psplash-quby
Removing package boilerstatus from root...
Running postrm on /HCBv2/qml/qb/base/Globals.qml
Removing stale link /HCBv2/qml/apps/boilerstatus
Removing boilerstatus from Globals.qml
sed: /HCBv2/qml/qb/base/Globals.qml: No such file or directory
Removing text files
Removing package tenant-all from root...
Removing package less from root...
update-alternatives: Linking //usr/bin/less to ../../bin/busybox
Removing package base-qb2-uni from root...
qmf-release was autoinstalled and is now orphaned, removing.
Removing package qmf-release from root...
packagegroup-qb2-required-priv was autoinstalled and is now orphaned, removing.
Removing package packagegroup-qb2-required-priv from root...
packagegroup-qb2-required was autoinstalled and is now orphaned, removing.
Removing package packagegroup-qb2-required from root...
tzdata-americas was autoinstalled and is now orphaned, removing.
Removing package tzdata-americas from root...
Removing package locale-base-en-gb from root...
glibc-binary-localedata-en-gb was autoinstalled and is now orphaned, removing.
Removing package glibc-binary-localedata-en-gb from root...
Removing package mtd-utils from root...
Removing package homeassistant from root...
Removing stale link /HCBv2/qml/apps/homeassistant
done.
Removing package gdbserver from root...
Removing package ozwcp from root...
Removing package dropbear from root...
Stopping Dropbear SSH server: stopped /usr/sbin/dropbear (pid 729)
dropbear.
update-alternatives: Linking //usr/bin/ssh to /usr/sbin/dropbearmulti
update-alternatives: Linking //usr/bin/scp to /usr/sbin/dropbearmulti
Removing any system startup links for dropbear ...
/etc/rc0.d/K10dropbear
/etc/rc1.d/K10dropbear
/etc/rc2.d/S10dropbear
/etc/rc3.d/S10dropbear
/etc/rc4.d/S10dropbear
/etc/rc5.d/S10dropbear
/etc/rc6.d/K10dropbear
Removing package libnetfilter-conntrack from root...
libnfnetlink was autoinstalled and is now orphaned, removing.
Removing package libnfnetlink from root...
Removing package happ-weather from root...
Removing package i2c-tools from root...
Removing package kernel-module-rt5370sta from root...
^CInterrupted. Writing out status database.
acl - 2.2.49-r5
attr - 2.4.44-r4
aws-iot-device-sdk-cpp - 1.4.0-r0
base-passwd - 3.5.20-r1
busybox - 1.27.2-r4
busybox-mountall - 1.27.2-r4
busybox-syslog - 1.27.2-r4
bxt - 1.9-master
ca-certificates - 20180409-r1
chrony - 1.27-r1
curl - 7.50.0-r0
dropbear - 2015.71-r0
expat - 2.0.1-r3.0
firmware-ba - 1.58-master
firmware-ma - 1.155-master
firmware-zwave-ctrlr - 1.48-master
gdb - 7.2-r9.0
gettext - 0.18-r5
glib-2.0 - 2.28.0-r1
glibc-binary-localedata-de-de - 2.10.1-r37.1
glibc-binary-localedata-en-us - 2.10.1-r37.1
glibc-binary-localedata-es-es - 2.10.1-r37.1
glibc-binary-localedata-fr-be - 2.10.1-r37.1
glibc-binary-localedata-fr-fr - 2.10.1-r37.1
glibc-binary-localedata-it-it - 2.10.1-r37.1
glibc-binary-localedata-nl-be - 2.10.1-r37.1
glibc-binary-localedata-nl-nl - 2.10.1-r37.1
glibc-gconv - 2.10.1-r37.1
glibc-gconv-iso8859-1 - 2.10.1-r37.1
gnupg - 1.4.10-r3
gnutls - 2.10.4-r11.0
gpgme - 1.1.4-r5
gpgv - 1.4.10-r3
happ-eventmgr - 1.266-master
happ-kpi - 1.549-master
happ-pwrusage - 1.836-master
happ-scsync - 1.448-master
happ-smartplug - 1.299-master
happ-thermstat - 1.2375-master
happ-usermsg - 1.153-master
hcb-bxtproxy - 1.1365-master
hcb-comm - 1.219-master
hcb-config - 1.494-master
hcb-log - 1.121-master
hcb-netcon - 1.531-master
hcb-rrd - 2.222-master
hcb-watchdog - 1.147-master
hdrv-hue - 1.375-master
hdrv-p1 - 1.1058-master
hdrv-zwave - 1.1650-master
initscripts - 1.2-r6-runlvls
iptables - 1.4.9.1-r7.1
jansson - 1.3-r1.0
joe - 3.1-r3
kernel - 2.6.36-R10-h28
kernel-image - 2.6.36-R10-h28
kernel-module-fat - 2.6.36-R10-h28
kernel-module-ftdi-sio - 2.6.36-R10-h28
kernel-module-msdos - 2.6.36-R10-h28
kernel-module-pl2303 - 2.6.36-R10-h28
kernel-module-rt5370sta - 2.6.36-R10-h28
kernel-module-rt5370sta-cfg - 2.6.36-R10-h28
kernel-module-rtl8191su - 2.6.36-R10-h28
kernel-module-vfat - 2.6.36-R10-h28
kernel-module-zwave300 - 2.6.36-R10-h28
libbz2 - 1.0.6-r0
libc6 - 2.21-r0
libcrypto - 0.9.8m-r14.1
libcrypto1.0.0 - 1.0.2h-r2
libcrypto1.0.2 - 1.0.2p-r0
libcurl - 7.50.0-r0
libcurl4 - 7.40.0-r1
libfreetype6 - 2.5.4-r0
libgcc1 - 4.9.2-r0
libgcrypt - 1.4.1-r0
libgettextlib - 0.18-r5
libgettextsrc - 0.18-r5
libgpg-error - 1.4-r7.1
libhcb-base - 1.453-master
libhcb-boxtalk - 1.206-master
libhcb-com - 1.205-master
libhcb-drv - 1.529-master
libhcb-xml - 1.182-master
libjansson4 - 2.10-r1.0
libjpeg8 - 8d+1.4.0-r0
libmicrohttpd - 0.9.58-r0
libopkg - 0.1.8+svns635-r7-gcv
libpcre1 - 8.36-r0
libpng16-16 - 1.6.16-r0
libqt5svg-plugins - 5.11.2+git0+32c93cbca8-r0
libqt5svg-qmlplugins - 5.11.2+git0+32c93cbca8-r0
libqt5svg5 - 5.11.2+git0+32c93cbca8-r0
libqt5xmlpatterns-plugins - 5.11.2+git0+15e22118d0-r0
libqt5xmlpatterns-qmlplugins - 5.11.2+git0+15e22118d0-r0
libqt5xmlpatterns5 - 5.11.2+git0+15e22118d0-r0
libssl - 0.9.8m-r14.1
libssl1.0.0 - 1.0.2h-r2
libssl1.0.2 - 1.0.2p-r0
libstdc++6 - 4.9.2-r0
libudev - 162-r12
libusb-compat - 1:0.1.3-r0
libusb1 - 1.0.8-r0
libuuid1 - 2.25.2-r1-q1
libz1 - 1.2.8-r0
lighttpd - 1.4.35-r6
lighttpd-mod-hcb-web - 1.68-master
lighttpd-module-access - 1.4.35-r6
lighttpd-module-accesslog - 1.4.35-r6
lighttpd-module-auth - 1.4.35-r6
lighttpd-module-compress - 1.4.35-r6
lighttpd-module-dirlisting - 1.4.35-r6
lighttpd-module-indexfile - 1.4.35-r6
lighttpd-module-staticfile - 1.4.35-r6
locale-base-de-de - 2.10.1-r37.1
locale-base-en-us - 2.10.1-r37.1
locale-base-es-es - 2.10.1-r37.1
locale-base-fr-fr - 2.10.1-r37.1
locale-base-it-it - 2.10.1-r37.1
locale-base-nl-nl - 2.10.1-r37.1
makedevs - 1.0.0-r10
module-init-tools - 3.12-r6
module-init-tools-depmod - 3.12-r6
ncurses - 5.7+20110115-r16
ncurses-libncurses - 5.7+20110115-r16
ncurses-libtinfo - 5.7+20110115-r16
ncurses-terminfo - 5.7+20110115-r16
ncurses-terminfo-base - 5.7+20110115-r16
netbase - 4.21-r50
openssl - 1.0.2p-r0
openssl-conf - 1.0.2p-r0
openzwave - 1.4.164-r0
opkg-collateral - 1.0-r3
pointercal - 0.0-r22
psplash - 0.1+git0+14c8f7b705-r15-q16
psplash-quby - 0.1+git0+14c8f7b705-r15-q16
pth - 2.0.2-r2
qmf-0 - 1.19-master-r0
qmf-collateral - 1.1-r0
qmf-tenantize - 1.2-r0
qt-gui - 1.9714-master
qtbase - 5.11.2+git0+49efea26a5-r0
qtbase-plugins - 5.11.2+git0+49efea26a5-r0
qtbase-qmlplugins - 5.11.2+git0+49efea26a5-r0
qtdeclarative - 5.11.2+git0+c249438243-r0
qtdeclarative-plugins - 5.11.2+git0+c249438243-r0
qtdeclarative-qmlplugins - 5.11.2+git0+c249438243-r0
qttools-tools-lrelease - 5.11.2+git0+ff440191de-r2
qtvirtualkeyboard - 5.11.2+git0+631b2089bc-r0
qtvirtualkeyboard-plugins - 5.11.2+git0+631b2089bc-r0
qtvirtualkeyboard-qmlplugins - 5.11.2+git0+631b2089bc-r0
readline - 5.2-r8
samba-nmbd - 3.0.20-r8
sysvinit - 2.86-r63-q2
sysvinit-inittab - 2.86-r63
sysvinit-pidof - 2.86-r63
sysvinit-utils - 2.86-r63
tslib - 1.0-r28.7hae
tslib-calibrate - 1.0-r28.7hae
tslib-conf - 1.0-r28.7hae
tzdata - 2011b-r8.0
tzdata-europe - 2011b-r8.0
udev - 162-r12
udev-utils - 162-r12
update-modules - 1.0-r10
update-rc.d - 0.7-r2
util-linux-uuidgen - 2.25.2-r1-q1
wget - 1.12-r8.3
wireless-tools - 29-r5
wpa-supplicant - 2.6-r0
wpa-supplicant-cli - 2.6-r0
wpa-supplicant-passphrase - 2.6-r0
www-jquery-ui - 1.31-master
www-resources - 1.43-master
zip - 2.32-r2
