- buienradar.userSettings.json
postnl.userSettings.json
sonos.userSettings.json
toonstore.userSettings.json
wastecollection.userSettings.json
Yes that worked, thanks. Now I replaced the example calendar with my own Google Calendar public link and hit Refresh in the settings of the app but it hangs on "ophalen kalenders". This is the code in my userSettings.json;Toonz wrote:click on the calendar tile, go to 'instellingen' and press opslaan.
It should create the file /mnt/data/tsc/calendar.userSettings.json
{"Calendar_URL":["https://calendar.google.com/calendar/embed?src=familyXXXXXXXXXXXXXXXXXXXXXXX%40group.calendar.google.com&ctz=Europe%2FAmsterdam"],"ShowColors":"Yes","ShowNotifications":"Yes"}
Unfortunately I try to share a Google Family Calendar. Just found out you can't retrieve an iCal format for the Family Calendar.Toonz wrote:you don't have the correct url for your calendar, you have the https link for use in browsers.
You will need the link to the calendar in iCal format, you can retrieve this link in the settings page of your calendar in the browser.
It should be in the form of "https://calendar.google.com/calendar/ical/<<gmail address>>/private-<<random string>>/basic.ics"
better use the private link and not the public link unless you want your calendar to be accessible for everyone.
I also use a family calendar but it is just a private calendar (separate gmail account).speedyconnalis wrote: Unfortunately I try to share a Google Family Calendar. Just found out you can't retrieve an iCal format for the Family Calendar.![]()
support.google.com/calendar/thread/6462 ... 2599?hl=en
Thanks, I changed over as well and have it up and running now! Thanks a lot for the support!Toonz wrote:I also use a family calendar but it is just a private calendar (separate gmail account).
On all family members android phones the account is added and everyone has full access to the calendar.
I am not using google family calendar features as such.
Makes sense, good suggestions, I will have a look this week if it continues to rain like todayspeedyconnalis wrote: Two remarks (maybe for future releases?);
- From what I understood a refresh is only triggered once a calendar item is done. Would it be possible to add a fixed refresh interval (once every 4 hours for example)?
- Would it be possible to add a view to the standby screen to show the future 2 or 3 calendar items instead of just 1?
Greetz, Tom
Wow, great job, thanks a lot!Toonz wrote:Hi all,
Version 1.1.6 is available in the ToonStore.
Changelog:
- calendars are refreshed at least every 6 hours (or earlier when first appointment ends)
- option added to show first three appointments in dim state as well, you can enable this option in the settings screen
Ooh sorry, read your remark quite late and I already downloaded another F1 ical which works perfectly and indeed shows the correct times in Toon. So let's just say the other calendar was rubbish! If I do encounter a similar problem again I'll let you know!Toonz wrote:can you send me the specific iCal entry of that event?
I thought it would handle this well, but the number of variations are endless in the iCals....
Maybe not, I just haven't yet implemented all possible options in the iCal formatspeedyconnalis wrote: So let's just say the other calendar was rubbish!
