Toon app: Traffic information
Xavier
Re: Toon app: Traffic information
Post by Xavier »
ok, will wait on the new app :)
just checked the anwb json feed but the actual speed radar info is not included (although the JSON file suggests it would).
Anyway, the app is working fine again on a Toon 2, need to polish it a bit and do tests on a toon 1 for performance and layout.
This new release will become available in the ToonStore in the near future.
Xavier
Post by Xavier »
still not able to install.
Keeps telling:
"Deze applicatie Verkeersinformatie is niet geschikt voor de software versie 5.13.12 van uw Toon"......
Xavier wrote:still not able to install.
Keeps telling:
I am quick but not that quick.
Again: you get this message because I blocked installation of the old app via the ToonStore on all firmwares because it absolutely doesn't make sense to install it as it will not receive any traffic data.
The new version of the app is currently being developed, as you can read in my post above yours: "When the new app is completed it will be available through the ToonStore again"
Please forget about version 1.0.9, it is obsolete.
I will post it here when the new app is available, as usual it will get a higher version number.
Xavier
Post by Xavier »
ahhhhhhhhhhhhhhhhhh I misunderstood you.
Sorry about that!
the brand new version 2.0.0 is available in the ToonStore.
It uses the new json feed from anwb.nl.
Only available for firmware version 5.x.x
Changelog 2.0.0:
- changed the source from xml.fileindex.nl to the anwb.nl json feed
- user settings (road filter) are now stored in the persistent /mnt/data/tsc folder
- this update will only be available on firmware 5 Toons
Xavier
Post by Xavier »
Thanks, great Job.
Already installed it :)
aabre
Post by aabre »
Hi Toonz,
great that the trafic info app is working again, I only have a small question, in the early version I had in the road filter only A13 and A20 and when there was no traffic jam the tile was empty, now I see all the other roads also, even with filter on or off.
Is there something I can do about this ?
Many thanks for the new 2.0.0 version
aabre wrote:Hi Toonz,
No, it's a bug, will fix it in the next release
version 2.0.1 is available in the ToonStore.
Changelog:
- the road filter is now also correctly applied to the tile
aabre
Post by aabre »
Great job !!
Many thank's Toonz it's working like a charm
jumperone
Verkeersinformatie
Post by jumperone »
Geen verkeersinformatie meer.
melding:Verkeersinformatie ophalen mislukt.geen internet verbinding.
Wel internet verbinding. Andere apps werken voor 100%
software 5.25.8
I have the toon with Version: 2.0 - ThehogNL - 24-3-2018 upgrade from version 2.9.26 upgrade to 4.10.6. Update failled / Bus error
OPKG Do Not Work / Bus error / orange screen with 2 points.
What can I do
TerrorSource
Re: Verkeersinformatie
Post by TerrorSource »
jumperone wrote:Geen verkeersinformatie meer.
software 5.25.8
I've moved your post to the corresponding "Verkeersinformatie" topic.
the error message is a bit misleading maybe. Point is that the app could not retrieve the latest traffic data. It can be because of a local WiFi/internet issue or an issue with at the data provider. Anyway, should resolve automatically when the underlying issues has been resolved.
jumperone
Post by jumperone »
De link van ANWB: https://www.anwb.nl/feeds/gethf
volgens ANWB bestaat niet meer.
Dus weet ik het ook niet meer
What can I do
