Belkin Lan USB HUB
Moderator: TANE
Belkin Lan USB HUB
<br />its hard to keep english sometimes if you know everyone is dutch..
@chak: let me know how it works with a pmix35..
Erik,
I have no Pmix35..If you like to test it in Nieuwegein let me now.
Erik,
Belkin Lan USB HUB
Hi Chak, what do you think about this USB-lan adapter with a CM19E usb device? I have purchased it to controll my ninja cams base but it's plugged (usb) in HS server that is far from cams base and the RF signal doesn't reach them!
Belkin Lan USB HUB
I have tested some other devices all is working well
Belkin has build good drivers.
I think it will work..but for 100% you have to test it self..
The most crazy USB device with the highest security did work fine.
Identifier of my Bank
Belkin Lan USB HUB
I ordered one today at Komplett.nl since 4launch could not deliver. I hope to get it next week (they have 50+ in stock) and will try to get a usb to rs232 device installed together with a CM11.
Let see what happens.
Francois
________________________________________________________________________________________________________________________
Francois
Belkin Lan USB HUB
I will ask Belkin for sponsoring..
Belkin Lan USB HUB
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by Francois</i>
<br />After 2 weeks in Redmond in a training group of 93 people with 37 nationalities I totally lost it....
I apologize !
Francois
<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">So you are a Microsoft guy [:)]
I apologize !
Francois
Belkin Lan USB HUB
Pieter,
To answer your first question: Yes. The ICYBOX looks interesting but I think with these kind of products it is very important to find somebody who has tested it and got it working. If the tester is a reliable source like Enver, it's a done deal
I am still curious to find out if I can run the RS232 to USB via the network, it would solve a lot of problems.
Francois
Francois
Belkin Lan USB HUB
@Francois:
I have tested it with the PMIX35.
I have set the drivers anywhere between 2400 and 19200 baud, it did make a small difference but it al worked after a while.
Still it was not as rock solid as I want for my system, this combined with the Belkin driver/program not running as a service, left it on the shelf. (Well it found a new fan)
I also have to add that I used it on a Windows Server 2008 to get around the missing USB functianality in their Hyper-V system.
Belkin Lan USB HUB
Today I ordered the IcyBox IB-LAN104 at www.komplett.nl
http://www.komplett.nl/k/ki.aspx?sku=391086
So now I can test it and tell you all if all my USB devices can be controlled over LAN.
To be continued
To be continued
Belkin Lan USB HUB
I will get the PMIX35 end of this week.
Plugwise USB dongle is working well since it's running
Belkin Lan USB HUB
Update 1 of ??
20:00 Installed the Belkin Network USB Hub
20:01 Installed the software, installation is simple, just like Enver said.
20:02 Hooked up my DigiBee+ USB interface in the "meterkast"
20:03 Fired up my homebrew VB interface
20:04 Works like a charm! ---> SO FAR THIS IS A GREAT DEVICE, Thanks for the tip.
Tomorrow I will try the RFxCOM device and the CM11.
Francois
Francois
Belkin Lan USB HUB
Sounds good..
I have installed my Plugwise software on the Homeseer machine.
USB connection was there but did not work..because of some driver problem (FTDI)
After upgrading the FTDI driver Plugwise is working fine.
There is also another nice option in the Belkin control software.
You can launch the correct application after the correct USB dongle is connected.
In my case the PlugwisePC.exe will be started
This option can also be used for auto starting the Homeseer if the PMIX35 or the CMXX is connected.
Belkin Lan USB HUB
Cool that autostart function, I'll give it a try. I was/am a bit worried what will happen in case of an unexpected power down. This might be the solution:
- Restart of the OS
- Belkin software starts automatically (load when os starts)
- if the device are connected it will launch HomeSeer, the DigiBee interface and the Touch screen interface.
Francois
- Restart of the OS
Francois
Belkin Lan USB HUB
Okay Just installed the PMIX35
After changing the Com port in Homeseer X10 control is working fine.
without restarting of Homeseer.
I hope it will be stable in the next days
The first one is the Plugwise
second PMIX35
[img]uploaded/Chak/20081016145925_pmixplugwise.gif[/img]
second PMIX35
