Toon app: Afvalwijzer
Re: Toon app: Afvalwijzer
Postby Toonz » Wed Jan 06, 2021 12:21 pm
customUser283 wrote:Hi,
I understand that as Westland serves their info over https, there's no good solution for a Toon 1.
This is the url: https://huisvuilkalender.gemeentewestla ... ode=2671AW
Any options? I have my own webserver and would be able to code a simple site that scrapes the site above and serve it in any format over http.
https is not an issue anymore, I will add westland to the app
Postby Toonz » Thu Jan 07, 2021 9:46 pm
It seems the website isn't working anymore, redirects you to www.gemeentewestland.nl now.....
Postby EchoNL » Sun Jan 10, 2021 1:11 pm
Is it possible to update Rova.nl for the afvalkalender with postcode 8333DT Steenwijk?
They call "oud papier" now "los papier". Sadly the Toon doesn't recognize this. It says now "onbekend".
Many thanks,
EchoNL
EchoNL
Postby Toonz » Sun Jan 10, 2021 6:32 pm
EchoNL wrote:Hi,
Many thanks,
EchoNL
Version 4.55 is available in the ToonStore with the 'paper' fix for Rova.nl.
No need to update for other users.
Postby Toonz » Wed Jan 13, 2021 7:24 pm
version 4.56 is available in the ToonStore with support for RAD Hoeksewaard.
Select provider 41 and enter your zipcode/housenr.
Postby EchoNL » Wed Jan 13, 2021 7:49 pm
Thank you for the update. Sadly it isn't working. Says "onbekend" again.
I removed the app from the Toonstore and reinstalled. Didn't work.
I also removed user data with winscp and re-entered address and postcode. Didn't work.
Is this because the changed it to "Los papier" ? inzamelkalender.rova.nl/
Many thanks,
EchoNL
EchoNL
Postby Toonz » Wed Jan 13, 2021 9:35 pm
EchoNL wrote:Thank you for the update. Sadly it isn't working. Says "onbekend" again.
Many thanks,
EchoNL
will test again when I am home
Postby Toonz » Thu Jan 14, 2021 12:49 am
version 4.57 is available in the ToonStore with a fix for rova.nl, now showing the paper category correctly.
Something went wrong with publishing the fix earlier.
No need to update for others
Postby EchoNL » Fri Jan 15, 2021 3:18 pm
It's working fine now! Thank you for the fast update!
EchoNL
Postby Rockabillybobber » Mon Jan 18, 2021 1:43 pm
Goedemiddag,
Ik krijg het niet voorelkaar met onze kalender van Blink .
Mocht je nog zin en tijd hebben kun je deze ook opnemen in de lijst. :D
https://mijnblink.nl/
gemeente Beek en Donk (Laarbeek)
Rockabillybobber
Postby Toonz » Mon Jan 18, 2021 4:52 pm
Rockabillybobber wrote:Goedemiddag,
ik kijk vanavond even, mag geen probleem zijn
Postby Toonz » Mon Jan 18, 2021 10:34 pm
version 4.58 is available in the ToonStore.
Changelog:
- added blink.nl (select provider 42 and fill in your calendar ICS number)
Get you calendar ICS number by visiting mijnblink.nl and login with your zipcode/housenr.
Click 'Naar maand en jaar kalender'
Click 'Zet inzameldata in agenda'
Look at the link under 'Synchroniseren'and find your calendar ICS number at the end of the URL.
- workaround for provider 41 - RAD Hoeksewaard as they hide some of their functionality.
After installing version 4.58 go to the app settings page, select provider 41 and press 'Opslaan' (this to update the user settings file with a new tag ICSurl)
On your PC go to https://www.radbv.nl/afvalkalender/ and login with your zipcode/housenr
when you see your calendar data, press 'Zet in agenda' at the right top of the month calendar
press 'Kopieer' to copy the full url to your calendar ICS file.
On the Toon you need to edit the file /mnt/data/tsc/wastecollection.userSettings.json using your tool of choice (Winscp.exe for example)
Paste the full url you just copied between the two "" after the new "ICSUrl" tag.
This part should now look like "ICSUrl":"https://wasteprod2api.ximmio.com/api......"
Save the /mnt/data/tsc/wastecollection.userSettings.json file.
On Toon, press Menu, Instellingen, TSC, Restart GUI and everything should work.
Toonz.
Postby georon » Sun Jan 31, 2021 1:19 pm
After a year I am trying to use the wastecollection app again for Limburg.net.
But I am unable to get it working.
Found the street number in the ics download url.
Filled in my provider: 10, street number and zip code.
No entries howere.
Am I doing something wrong, or is it broken currently?'
I searched this thread, but did not find a post that was helpfull to me.
Anybody got a tip for me?
My ics url:
https://limburg.net/api-proxy/public/kalender-download/ical/72037?straatNummer=33122&huisNummer=16&toevoeging=&includeAllEventTypes=1&eventTypes[]=8&eventTypes[]=14&eventTypes[]=15&eventTypes[]=16&eventTypes[]=17
georon
Postby georon » Sun Jan 31, 2021 1:35 pm
georon wrote:After a year I am trying to use the wastecollection app again for Limburg.net.
No entries howere.
My ics url:
I found that the currently used URL in the app returns an empty ICS file... so a no go for now.
georon
Postby Toonz » Sun Jan 31, 2021 3:45 pm
will have a look this evening
PreviousNext
Return to Toon Apps
cron
