Toon App: solarPanel ---> solar data without hardware
oepi-loepi
Re: Toon App: solarPanel ---> solar data without hardware LIVE
Post by oepi-loepi »
clvgtnl wrote:Beste oepi-loepi,
Mooie app, ik ben hier heel blij mee.
Alleen heb ik een vraag, is het mogelijk om 2 omvormers in te stellen? Want op dit moment is dat niet mogelijk of wel?
Ik heb de Growatt en de Goodwe. Thanks :)
This will be available in one of the next updates. However, it would then be 1 totaliser from the 2 inverters. For now i am focusing on getting the app error free.
If you have your 2 inverters visible in Domoticz, there is a test function though. Please send me a pm if you would like to test this "Double Domoticz" plugin.
Hiu80
Post by Hiu80 »
Hi oepi-loepi,
I too have two inverters. I understand you are working on an feature to add more than one inverter. I have configured my inverters in Domoticz and would like to test you domoticz-double plugin. Maybe i can help out?
oepi-loepi
i will send a pm to explain.
SolarShed
Post by SolarShed »
oepi-loepi wrote:In Toonstore Now
From now on it is possible to connect your solar inverter to Toon without the use of cables or hardware.
If you allready have a hardwired solution for this (extra meter and meteradapter): keep the hardwired solution. If you like to change solution to this solution: disable the meteradapter solution first otherwise you get double amounts.
- Install the app
- install a tile
- click on the tile and goto the configuration screen
- select one of the inverters and fill in your credentials
- click "opslaan". Your Toon will be modified for the use of solar features
After installation, more solar features will become visible in the tile setup.
For now the following inverters are available in the setup:
- Growatt
- Goodwe
- SolarEdge
- Fronius
- pvoutput
- zeversolar
- kostal piko
- enPhase
Further testing needed:
- sma (not woking for SB3000tl-21 series), have to try for the newer versions, please let me know if you own such a device
- Omnik (please let me know if it is working)
- Solis (Ginglong) (please let me know if it is working)
If you like to have your inverter available as well, please send me a message and i will look into programming an interface.
The first day will have an enourmous amount in the graphs. This because the day amount is calculated from the inverter's total amount.
Amazon Effort,
Because of this app I just purchased a toon1 to play around with. Eventually getting rid of my Nest.
Currently I have my solar and used power statistics on Pvoutput but I'm getting tired of opening the pvoutput app to see the performance. Using the rooted toon this would give me (laagdrempelige) insights of the current stats.
I expect to receive toon tomorrow by mail and then I would get into the rooting process by using raspberry pi. Will post pics of the results afterwards.
oepi-loepi
Super, i am glad you like the idea of the app.
joshavanleeuwen
Post by joshavanleeuwen »
Nice app!
I've send my Omnik credentials to You. Currently it's not working for me yet.
oepi-loepi
The plugin for Omnik has been modified (online).
SolarShed
Post by SolarShed »
oepi-loepi wrote:Super, i am glad you like the idea of the app.
Got it all done in a jiffy, thanks a lot. Will be reading up and following the new developments.
SolarShed
Post by SolarShed »
I have a question about the teruglevering. is there a reason why it's not showing in the graph? I'm currently generating more power then I'm using but not spotting details about this.
gabokkers
Post by gabokkers »
I installed the solarPanel app on my Toon, but I cannot find the tiles you are referring to.
Maybe I am missing something, but I cannot find any trace of the solarPanel app on my Toon now.
Demif
Post by Demif »
gabokkers wrote:Hi,
i had the same problem, maybe update the firmware, (thnx to terrorsource) did the update and all is running
viewtopic.php?f=99&t=13043&start=30#p96643
oepi-loepi
SolarShed wrote:I have a question about the teruglevering. is there a reason why it's not showing in the graph? I'm currently generating more power then I'm using but not spotting details about this.
This was indeed something what was impossible to test since the weather wasn’t tat good and i only have 6 panels myself. As soon as i am producing more than using, i will test and update the app.
oepi-loepi
gabokkers wrote:Hi,
You should see some new tiles when you click on an emty tile. Otherwise, update your toon, reboot, try again and reinstall the app from the store. Reboot after installing.
gabokkers
Post by gabokkers »
oepi-loepi wrote:
gabokkers wrote:Hi,
Ah oke, I was still at version 5.5.7. I was not aware that in the mean time many new versions appeared....
My Toon is upgrading now to version 5.33.9, so that will most likely solve my problem.
Thanks for your help.
oepi-loepi
gabokkers wrote:
oepi-loepi wrote:
gabokkers wrote:Hi,
So you are missing a lot of new features like the animation app. Install and allow app to trigger in the setup menu.
