Toon App: Water
Hypermobile
Re: Toon App: Water
Post by Hypermobile »
i think i used the wrong device, counter is the correct one.
thx, it's working great
oepi-loepi
Re: Toon App: Water
Post by oepi-loepi »
Hypermobile wrote:i think i used the wrong device, counter is the correct one.
Nice!
Hypermobile
Re: Toon App: Water
for some reason,
i sometime can connect to the watermeter. sometimes not.
(tried to ping, sometimes resonse sometimes not.
I took a bath, but today it's stuck on 120Lts of water. (both Domoticz and Toon).
Watermeterprox is still flashing on and off.
I have issues recently with my ziggo modem....is't loosing Wifi Sunday morgning, between 9.00 and 11.00 for weeks already.
oepi-loepi
Re: Toon App: Water
I think your 2.4 wifi is not stable. If the prox is counting the local data will be written to internal memory of the watermeter each 15 minutes. So if you do not unplug the device earlier than 15 minutes aftter the bath it still has counted the bathing liters and will be vilsible as soon as the wifi is stable again.
Hypermobile
Re: Toon App: Water
You sent the flow and the TotalCounter. or do you sent a incremental value??? i think not
In that case wifi stability doesn't matter, than maybe the Prox Stability isn't what is needs to be.
i keep 'n eye on it.
thx anyway :wink:
oepi-loepi
Re: Toon App: Water
Hypermobile wrote:You sent the flow and the TotalCounter. or do you sent a incremental value??? i think not
thx anyway :wink:
But you say the prox is flashing and you are loosing wifi....
Hypermobile
Re: Toon App: Water
well, if you loose wifi once and a while.
and the Counter is adding up.
for example after loosing wifi for let say 24 hours, you should see a Peak. so therefore i tough it would be helpfull what value is pushed to toon. incremental or totalcountervalue
oepi-loepi
Re: Toon App: Water
Hypermobile wrote:well, if you loose wifi once and a while.
It is the calculated flow (from the interval between pulses) and the total quantity counter. Ther are not pushed but pulled by toon. The total is counted every pulse but is written to memory only each 15 minutes. So if you loose power or reset the module, you will loose the last 15 minutes of pulses.
oepi-loepi
Re: Toon App: Water
New version of toonWater is now available in the toonStore
Changes:
- new approach for the mobile site/app . The water data will be available almost live
- possibility to set the water tariff
The mobile app will be updated soon.
oepi-loepi
Re: Toon App: Water
New version of toonWater is now available in the toonStore (1.1.16)
Changes:
- change in file location for the mobile app
The mobile app will be updated automatically.
Tebogo
Re: Toon App: Water
Post by Tebogo »
oepi-loepi wrote:New version of toonWater is now available in the toonStore (1.1.16)
Changes:
Still very happy with you ToonWater app. Working all good.
You mention frequently "mobile app". What do you mean with that?
Edit: Never mind, found it. Had Never seen the 2 and 3 page :roll:
Thank you!
oepi-loepi
Re: Toon App: Water
For all othes using the /mobile page. When using a browser, you can slide to the left and right with your mouse..
memo1996
Re: Toon App: Water
Post by memo1996 »
Onderstaande script werkt niet bij mij.
Heb de script geplakt in configuration.yaml
ik krijg onderstaande foutmelding:
end of the stream or a document separator is expected at line 104, column 1:
- platform: rest
rolinck wrote:For home assistant implementation the script below can be used to get both waterflow and waterquantity in one rest call
sensor:
- platform: rest
json_attributes:
- waterflow
- waterquantity
resource: http://<ip-watermeter>/water.html
- platform: template
sensors:
watermeter_flow:
friendly_name: "Huidige waterflow"
value_template: '{{ states.sensor.Watermeter.attributes["waterflow"] }}'
unit_of_measurement: "l/m"
icon_template: "mdi:water-pump"
watermeter_quantity:
friendly_name: "Huidige watermeterstand"
value_template: '{{ states.sensor.Watermeter.attributes["waterquantity"] }}'
unit_of_measurement: "l"
icon_template: "mdi:water"
oepi-loepi
Re: Toon App: Water
memo1996 wrote:Onderstaande script werkt niet bij mij.
- platform: rest
is het mogelijk om anders de hele configuration.yaml te sturen? Ik denk dat je ergens een inspringing fout hebt staan of een inspringing met tabs ipv spaties.
Kan iemand zijn werkende configuration.yaml (of het stukje met de watermeter) als textfile posten? In de forumtext gaan de spaties helaas verloren.
memo1996
Re: Toon App: Water
Post by memo1996 »
Hoi,
Het is gelukt!
Ik had inderdaad te veel spaties!
Thanks!
