Toon App: Water
Krisrock
Re: Toon App: Water
Post by Krisrock »
Hello everyone,
I have a problem with Toonwater, after a few days I can no longer access the wemos via the ip address.
at these moments Toon is still connected (with the wemos).
but then Toon also spontaneously loses the connection, a hard reset of the wemos is the solution.
Does anyone have a problem with this or a solution?
Attached screenshot of the wemos info page
Info pagina Toonwater
oepi-loepi
Re: Toon App: Water
Post by oepi-loepi »
You are using a very old software. In the old version the wifi is nit reconnecting when losing the wifi. In the newer versions it is attempting to reconnect. So update to the latest version.
Krisrock
Re: Toon App: Water
Post by Krisrock »
oepi-loepi wrote:You are using a very old software. In the old version the wifi is nit reconnecting when losing the wifi. In the newer versions it is attempting to reconnect. So update to the latest version.
where can i find the latest version?
I have version 1.3.15 is this not the last one?
Re: Toon App: Water
Post by TheHogNL »
First place I would look is the start post
Krisrock
Re: Toon App: Water
Post by Krisrock »
there is the same version as what I described in the above post.
oepi-loepi
Re: Toon App: Water
Ok, from what i understood from your screenshot was the very old version. I guess you have only send part of the text there. If you have set the static ip and the wifi is lost, the unit will try to reconnect automatically. Try to run the upgrade with the latest file, just to be sure.
Also make sure that you do not have another divice in hour network assigned to the same static ip.
Bruce the boss
Re: Toon App: Water
Post by Bruce the boss »
oepi-loepi wrote:Wat heb je gedaan? Heb je een update gedaan of iets anders? Als je geen rood lampje krijgt als je iets van metaal tegen de ensor aanhoud (aan de blauwe kant). Dan is ook een draad van de 5V of 0V los (sensor bruin en blauw). Of de sensor is defect.
Dus even de sensor losnemen uit de houder en iet van metaal tegen de sensor aanhouden. Als hij het dan nog niet doet dan even de solderingen en de bedrading nalopen
Ik heb alles nagelopen maar krijg er geen leven meer in. Adviseer je om alles opnieuw te kopen of eerst de sensor?
Ik zie wel dat hij contact heeft met het WiFi netwerk.
Verstuurd vanaf mijn SM-G950F met Tapatalk
Krisrock
Re: Toon App: Water
Post by Krisrock »
oepi-loepi wrote:Ok, from what i understood from your screenshot was the very old version. I guess you have only send part of the text there. If you have set the static ip and the wifi is lost, the unit will try to reconnect automatically. Try to run the upgrade with the latest file, just to be sure.
update done again (see attachment for result)
the IP address (21) has been reserved for Tooon water. so this must be good.
I also don't see any apartments that come close with this ip address (in the router)
update 2
update 2
update 1
update 1
Krisrock
Re: Toon App: Water
Post by Krisrock »
Ik heb het zelfde gehad, waarschijnlijk is mijn sensor defect gegaan door vocht.
dit kan gebeuren omdat ik de tip van sensor moest bewerken voor een juiste meting.
sensor vervangen en iets veerder gestopt met schuren, en een plak bankje er tussen (zodat de sensor niet meer in aanraking kan komen met condens van de meter)
oepi-loepi
Re: Toon App: Water
Inderdaad. De wifi is prima, bedrading heb je nagelopen. Dan blijft de sensor over..
oepi-loepi
Re: Toon App: Water
Nieuwe versie in de toonStore. Ik werd erop gewezen dat in dimstand de grafiek van water en die van gas hetzelfde zijn. Kleine aanpassing gedaan in versie 1.1.17
Krisrock
Re: Toon App: Water
Post by Krisrock »
Still have after the latest firmware that sometimes I can't connect. (with the Wemos)
I can also see it in Toon that the graphs become gray
oepi-loepi
Re: Toon App: Water
Krisrock wrote:Still have after the latest firmware that sometimes I can't connect. (with the Wemos)
Maybe the wifi at the wemos is not stable?
Krisrock
Re: Toon App: Water
Post by Krisrock »
The Wemos is 2.5 meters away from the router.
Surely the reception should be good then?
info from the wemos: wifi strength -66
will look into getting an external antenna for the wemos or will this not help?
oepi-loepi
Re: Toon App: Water
Krisrock wrote:The Wemos is 2.5 meters away from the router.
The strenght of -66 is not the best. Maybe your wemos has a fault.
