Toon app: Afvalwijzer
Re: Toon app: Afvalwijzer
Hi all ,
version 4.68 will be available in the next few days in the ToonStore.
Changelog:
- fixed url change for stadswerk072.nl
- changed calendar retrieval process for Avalex.nl:
Log on to avalex.nl with your zipcode, at the bottom of the calendar click "iCalender openen"
Click "Kopieer link"
Paste the full link on Toon in the file /mnt/data/tsc/wastecollection.userSettings.json after the "ICSUrl" tag between quotes
Save the file and restart the Toon gui
Kind regards,
Changelog:
Kind regards,
Hi Toonz,
Would Irado (Capelle a/d IJssel, Rozenburg, Schiedam, Vlaardingen) be an option to integrate?
https://www.irado.nl/afvalkalender
just had a quick look, they do not provide the calendar in electronic format unfortunately.
The only option is to save the webpage with the year view and copy it over to Toon.
In the app on Toon I will need to scrape the webpage (a bit complicated for this one but can be done).
Just need some time to implement this (not this weekend for sure)
I can confirm that Avalex.nl is working again in version 4.69 after copying the URL.
Thanks Toonz.
Thanks Toonz.
Hello guys, am i the only one having issues with this app?
From this morning the Toon only gives a blank tile, no (RMN) dates anymore
When you login via your PC, do you get correct data then? Check the calendar download url, maybe your ICS number has changed.Joskep wrote:Hello guys, am i the only one having issues with this app?
Or they have changed all description of their waste categories, in that case I need to update the app.
Just let me know.....
Thanks.
when i check: https://inzamelschema.rmn.nl/ i have to give my postcode and housenumber, but the "OK" button doesn't work.
Probably an problem at their site.
What works: when i take the postcode from one street behind us, (the same days) then it works on the website.
Then i have to get the ICS from that postcode i think?!
EDIT:
It works!
I went to calendar option on the website and noticed that the ICS code was changed.
Thanks!
EDIT:
It works!
Thanks!
De afvalwijzer geeft geen datums meer aan.
Dit komt in mijn geval dat omdat afvalverwerker 13 suez is overgenomen door prezero en dus ook de link is veranderd van https://inzamelwijzer.suez.nl/ical/ naar https://inzamelwijze.prezero.nl/ical/
Is het mogelijk om dit zelf aan te passen of moet ik wachten tot er een update komt ?
ik kijk er vandaag even naar (inhoud kalender kan ook anders zijn)
EDIT: Prezero stelt geen afvalkalender ter beschikking via het web of een downloadfunctie. De data is alleen benaderbaar via hun app helaas.
EDIT 2: je kan via afvalverwerker "1" (= mijnafvalwijzer.nl) je data opvragen, wel ook je postcode /huisnummer invullen in het configuratiescherm
Ik zag dat alleen 1 soort afval nog geen omschrijving heeft, dat zal ik nog even aanpassen in de volgende versie
version 4.70 will be available in the ToonStore shortly.
Changelog:
- provider "13" Suez.nl has been replaced by prezero.nl. Go to the configscreen and enter your zipcode/housenr to make it work again.
Kind regardz,
Changelog:
Kind regardz,
Het werkt niet met optie 1 als je de postcode en huisnummer hebt ingegeven
Ik heb de laaste versie gedownload en 13 gekozen en dan de postcode en huisnummer ingevuld maar nog steeds krijg ik geen datums binnen.
Op de site van prezero staat dit https://inzamelwijzer.prezero.nl/ical-info
Misschien toch aan de hand van een ical nummer werken net als suez werkte ?
can you send me a PM with your zipcode?
Hallo Toonz.
Ik heb je een mail gestuurd.
thanks , in de volgende versie wordt prezero ook ondersteund.maus wrote:Hallo Toonz.
- Starting Member
Hi,Toonz wrote:Hi all,
release 4.63 is available in the ToonStore.
Changelog:
- fix for Meerlanden (16) (they changed backend service provider)
Update the app and go to the settings page, change any item and press 'Opslaan' (this to update the settings file to add a new tag ICSurl)
On your PC goto https://www.meerlanden.nl and login with your zipcode/housenr
when you see your calendar data, press 'Zet in agenda' at the right top of the month calendar
press 'Kopieer' to copy the full url to your calendar ICS file.
On the Toon you need to edit the file /mnt/data/tsc/wastecollection.userSettings.json
Paste the full url between the two "" after the "ICSUrl" tag.
The part should now look like "ICSUrl":"https://wasteprod2api.ximmio.com/api......"
Save the JSON file.
On Toon, goto the Menu, Instellingen, TSC, Restart GUI et voila.
- fix for omrin.nl (21) (paper category was not shown properly due to website change)
No need to update for other users.
Kind regardz,
I’m on version 4.70 and I’m trying to configure meerlanden.
I did follow these steps but does not seem to work. I get a blank window and nothing else.
Any other ideas?
Thanks!
