Toon app: Afvalwijzer
TheHogNL wrote:Graag nog even toevoegen aan :
function wasteTypeMijnafvalwijzer(shortName)
De volgende cases:
case "grofvuil": return 8;
case "tuinafval": return 4;
case "papier": return 2;
Bij mijzelf natuurlijk al gedaan maar zodat straks ook anderen hier van kunnen profiteren :)
Thanks, will be in next release...
Current scope of next release: support for rd4info, limburg.net and this change
georon
Post by georon »
Thanks in advance!
Post by TheHogNL »
puinDim.png and grootvuilDim.png are missing transparant background (installed from toonstore)
TheHogNL wrote:puinDim.png and grootvuilDim.png are missing transparant background (installed from toonstore)
Thanks, will fix it in next release.
Another note:
If you want to use WasteCollection 2.2 on 3.x firmware please make the following modification to WastecollectionConfigurationScreen.qml:
Delete the following line (3 times):
leftTextAvailableWidth: 270
This will do for now.
In the next version I will make wastecollection work seamlessly on both old and new firmwares.
Kind regardz,
We're getting somewhere: people at the toon forum are requesting the "afvalwijzer" app from Eneco:
https://forum.toon.nl/suggesties-ideeen ... e-toon-481
Well done, Toonz, I think it's time to start adding the GPL notice to our code ...
Stimpy68
Post by Stimpy68 »
Can implement Den Haag into the app?
https://huisvuilkalender.denhaag.nl/form
You have fill in your zipcode and housenumber, you get a webpage with the dates or you can download a pdf or ical.
Stimpy68 wrote:Can implement Den Haag into the app?
This is an easy one. The link on their webpage to the ical gives you a fixed url to your specific calendar via http (not https) which is very good.
I just need to add a configuration field to allow you to enter the unique number of your calendar (last part of the url: http://huisvuilkalender.denhaag.nl/ical ... 0000370521)
I am currently busy with a new version of the app, already added limburg.net and working on rd4info.
Will add this one as well, the new version will showup in the ToonStore.
I will post a message here when done.
Regardz,
Ikkeja
Post by Ikkeja »
Great work!
On my wishlist:
https://inzamelschema.rmn.nl/
I'm so glad with my rooted Toon ;-)
sure, looks like a copy of the 'Den Haag' website above. Can do both at the same time. Same storyline.
Version 2.3 will hit the ToonStore soon:
Changelog:
- ensured backwards compatibility with firmware version 3.x
- added provider limburg.net (BE)
- added provider denhaag.nl
- added provider rmn.nl
- added Streetnr to config screen for limburg.net.
N.B. iok.be users needs to enter the Streetnr in the new field instead of Housenr previously
- added more waste types for Mijnafvalkalender.nl (Thanks TheHogNL)
- added transparency for icons for 'grofvuil' and 'puin'
- added an icon for 'kunststof' for limburg.net
- changes / optimizations in the config screen.
- added helptext for all input fields in the config screen.
Note for new users of denhaag.nl and rmn.nl: the waste_calendar.ics file needs to be downloaded via https using cron and wget as described in the manuals section.
The exact link can be found when you go to your website to retrieve the ics file. Have fun.
There is no reason for existing users to update really, we will therefore configure the ToonStore as such that this update will not be automatically installed.
I didn't have time this week to include the provider rd4info.nl as well, that will move to the next release.
Kind regardz,
georon
Post by georon »
@Toonz,
Thanks for the hard work.
I've already implemented a 'clone' of the waste collection app so I can have it run twice, from two different waste 'providers'.
Changed the icon set of the clone to include the 'BE' letters.
My Toon is helping me great now to get my waste on the right streets :)
Again, thanks for this app!
georon wrote:@Toonz,
Great story, but are you able to produce enough waste to satisfy both? :D :D
the thermostat app in version 4.7.23 did change quite a lot. I updated the waste collection mod to be compatible with this firmware.
Icons are now shown above the temperature.
The attachment contains the full thermostat app for firmware 4.7.23 but only two files have been changed: ThermostatApp.qml and ThermostatSidepanel.qml.
All code changes are marked between the lines 'waste display start' and 'waste display end'.
Note: the icon will show only 6 minutes after restart of the gui and will be updated daily at 18.01 to show the icon for the next day
Summarizing:
- use the earlier posted version 1.2 of the mod for firmware version 3.7.9 (manually apply to other 3.x versions)
- use this earlier posted version 1.3 for firmware 4.4.21 (manually apply to other 4.x versions)
- use this version 1.3 on firmware 4.7.23
all are compatible with any recent version of the wastecollection app.
The screenshot below shows the thermostat panel for one and two waste icons.
Kind regardz,
wastecollection_thermostat_mod_v1.3_(fw_4.7.23).zip
(143.01 KiB) Downloaded 504 times
version 2.3 is available on ToonStore. Changelog:
- added transparancy for icons for 'grofvuil' and 'puin'
Kind regardz,
Vibestar
Post by Vibestar »
On my Toon "papier en karton" and "gft" are named "onbekend". The icons for these aren't working also. I'm using afvalstoffendienst.nl.
Great App by the way. :D
