Toon app: Afvalwijzer
Vibestar wrote:On my Toon "papier en karton" and "gft" are named "onbekend". The icons for these aren't working also. I'm using afvalstoffendienst.nl.
Great App by the way. :D
Will have a look, should be easy....can't remember having included afvalstoffendienst.nl ;-)
Vibestar
Post by Vibestar »
The normal waste is working. Thanks for the quick reply.
Vibestar
Post by Vibestar »
I was using mijnafvalwijzer.nl. On the website it works great. On the app it doesn’t.
I’m in the zipcode of Rosmalen. Normale I check the app Afvalstoffendienst.nl but mijnafvalwijzer seems to work great on the website. Thats why I used it in your app
Vibestar wrote:I was using mijnafvalwijzer.nl. On the website it works great. On the app it doesn’t.
just add two lines to the function wasteTypeMijnafvalwijzer(shortName) in WasteCollectionApp.qml:
case "gft-afval": return 3;
case "kerstbomen": return 4;
Should be ok then for Rosmalen. If not PM me your exact zipcode and I will have a second look
Kind regardz,
Vibestar
Post by Vibestar »
It worked for the GFT but it didn't for the paper. I think changing kerstbomen isn't the same as paper :D
I added a line case "papier": return 2; and now it works.
Vibestar
Post by Vibestar »
I use these icons in the waste collection app now. They aren't all mine but I like them. Can I share them here?
Vibestar wrote:I use these icons in the waste collection app now. They aren't all mine but I like them. Can I share them here?
Sure. I like it.....Might use them in the next version if you're ok.
Henk2k
Post by Henk2k »
Dear Toonz,
Is it possible https://www.afvalwijzer-arnhem.nl/ gets supported? It also work with downloadable google-agenda's so the website is able to export 'things'.
Would be pleased if possible!
Cheers Henk
Henk2k wrote:Dear Toonz,
Cheers Henk
This one is easy. Looks like an other provider and no hassle with https calls. Can be done from Toon directly.
I am on leave next week, so have a little bit of patience please.
Kind regardz,
ams123
Post by ams123 »
Toonz can you make it for me working http://afvalkalender.rova.nl/home.xhtml 3825CB Amersfoort
your great :D
greetz Arie
Toon solarpannels
jnieuw
Post by jnieuw »
While at it, please add http://www.recyclemanager.nl/afvalkalender for Uithoorn: 1422sl 129
Thank you!
jnieuw wrote:While at it, please add http://www.recyclemanager.nl/afvalkalender for Uithoorn: 1422sl 129
Thank you!
Not so easy. The dates are not returned in plain html but retrieved from the server via function calls. Cannot be handled by Toon unfortunately.
Cheers Henk
Done, will be released via the ToonStore early next week..... (waste provider 13)
ams123 wrote:Toonz can you make it for me working http://afvalkalender.rova.nl/home.xhtml 3825CB Amersfoort
your great :D
greetz Arie
Done as well.
Note: Toon cannot retrieve this file itself. You need to visit the rova website on your PC with your postcode/housenr and save the page with your waste collection data as "ROVA Afvalkalender.htm" on your PC.
Copy this file to Toon in the folder "/root/waste/ROVA Afvalkalender.htm". On Toon select waste provider 14.
As it contains the full year calendar you need to repeat this once a year around year end.
Hopefully that is ok.
Included in next version on ToonStore (early next week)
ams123
Post by ams123 »
your great :D
greetz Arie
Done as well.
i make the map waste under root/
now look as /root/waste
Toon solarpannels
