Toon app: Afvalwijzer
jnieuw
Re: Toon app: Afvalwijzer
Post by jnieuw »
Bestand in /var/volatile/tmp gezet en nu werkt het :)
die locatie heeft wel als nadeel dat je het bestand opnieuw moet kopieren na een volledige herstart van Toon (na een stroomstoring bijvoorbeeld)
jnieuw
Post by jnieuw »
Dat snap ik. Alleen is dat nu de enige manier dat hij het wel oppakt. Geen idee waarom, maar het werkt.
Rudolf
Post by Rudolf »
I've been using this app for quite some time without any problems. But today I noticed that it shows additional dates, "Onbekend".
This is provider '33'. Looks like the expected pick-up dates are shown as well.
Wastedates.txt shows a question mark for these.
The .ics has Summary "Onbekend".
EGIN:VEVENT^M
DTSTART;VALUE=DATE:20250311^M
SUMMARY:Onbekend^M
BEGIN:VEVENT^M
BEGIN:VEVENT^M
SUMMARY:Onbekend^M
BEGIN:VEVENT^M
BEGIN:VEVENT^M
DTSTART;VALUE=DATE:20250312^M
SUMMARY:GFT^M
BEGIN:VEVENT^M
BEGIN:VEVENT^M
DTSTART;VALUE=DATE:20250314^M
SUMMARY:Onbekend^M
BEGIN:VEVENT^M
BEGIN:VEVENT^M
SUMMARY:Onbekend^M
BEGIN:VEVENT^M
BEGIN:VEVENT^M
DTSTART;VALUE=DATE:20250319^M
SUMMARY:Rest^M
BEGIN:VEVENT^M
BEGIN:VEVENT^M
DTSTART;VALUE=DATE:20250324^M
SUMMARY:Papier^M
BEGIN:VEVENT^M
BEGIN:VEVENT^M
DTSTART;VALUE=DATE:20250326^M
Edit: Thanks to the comments in the wasteCollectionProvider.js I could try the API manually and it seems I now get "Kca" and "Textiel¨
[{"date":"2025-03-11T00:00:00","name":"Kca","daysTillDate":5,"totalThisYear":null},{"date":"2025-03-11T00:00:00","name":"Textiel","daysTillDate":5,"totalThisYear":null},{"date":"2025-03-12T00:00:00","name":"Gft","daysTillDate":6,"totalThisYear":null},{"date":"2025-03-14T00:00:00","name":"Kca","daysTillDate":8,"totalThisYear":null},{"date":"2025-03-14T00:00:00","name":"Textiel","daysTillDate":8,"totalThisYear":null},{"date":"2025-03-19T00:00:00","name":"Pbd","daysTillDate":13,"totalThisYear":null},{"date":"2025-03-19T00:00:00","name":"Restafval","daysTillDate":13,"totalThisYear":null},{"date":"2025-03-21T00:00:00","name":"Papier","daysTillDate":15,"totalThisYear":null},{"date":"2025-03-26T00:00:00","name":"Gft","daysTillDate":20,"totalThisYear":null},{"date":"2025-03-28T00:00:00","name":"Kca","daysTillDate":22,"totalThisYear":null},{"date":"2025-03-28T00:00:00","name":"Textiel","daysTillDate":22,"totalThisYear":null},{"date":"2025-04-02T00:00:00","name":"Pbd","daysTillDate":27,"totalThisYear":null},{"date":"2025-04-02T00:00:00","name":"Restafval","daysTillDate":27,"totalThisYear":null},{"date":"2025-04-08T00:00:00","name":"Kca","daysTillDate":33,"totalThisYear":null},{"date":"2025-04-08T00:00:00","name":"Textiel","daysTillDate":33,"totalThisYear":null},{"date":"2025-04-09T00:00:00","name":"Gft","daysTillDate":34,"totalThisYear":null},{"date":"2025-04-11T00:00:00","name":"Kca","daysTillDate":36,"totalThisYear":null},{"date":"2025-04-11T00:00:00","name":"Textiel","daysTillDate":36,"totalThisYear":null},{"date":"2025-04-16T00:00:00","name":"Pbd","daysTillDate":41,"totalThisYear":null},{"date":"2025-04-16T00:00:00","name":"Restafval","daysTillDate":41,"totalThisYear":null},{"date":"2025-04-18T00:00:00","name":"Papier","daysTillDate":43,"totalThisYear":null},{"date":"2025-04-23T00:00:00","name":"Gft","daysTillDate":48,"totalThisYear":null},{"date":"2025-04-25T00:00:00","name":"Kca","daysTillDate":50,"totalThisYear":null},{"date":"2025-04-25T00:00:00","name":"Textiel","daysTillDate":50,"totalThisYear":null},{"date":"2025-04-30T00:00:00","name":"Pbd","daysTillDate":55,"totalThisYear":null},{"date":"2025-04-30T00:00:00","name":"Restafval","daysTillDate":55,"totalThisYear":null},{"date":"2025-05-
BAR-afvalbeheer shows:
"Mobiel afvalaanbiedstation (zie afvalwijzer)"
for these dates.
It's a bit difficult to show what it is, because it allows you to bring several types of waste at severa locations throughout the town.
Kleine elektrische apparaten zoals een kapotte föhn, tandenborstel, laptop, scheerapparaat, lamp, boormachine of telefoon.
Klein Chemisch Afval (KCA) zoals een verfblik, olie, medicatie, spaarlampen of batterijen.
Harde kunststoffen zoals speelgoed, plantenbakje, opbergkrat of een emmer.
Hout zoals een krukje, fotolijstje, onderzetters, vogelhuisje of plankje.
Metalen zoals een koekenpan, keukengerei, gereedschap, rekje, prullenbak of ijzerdraad.
Karton zoals een doos.
Frituurvet - en oliën
Piepschuim
Textiel
With this change, it shows Textiel or KGA
        function wasteTypeCode(shortName) {
                switch (shortName) {
                        case "Restafval": return 0;
                        case "Gft": return 3;
                        case "Papier": return 2;
                        case "Pbd": return 1;
                        case "Kca": return 7;
                        case "Textiel": return 5;
                        default: break;
                return "?";
Thanks Rudolf,
I have updated the plugin '33', additionally also added the 'Snoeiafval' waste code used in some other cities (rwm.nl provider)
Please go to the 'Instellingen' screen of the app to automatically update the plugin.
Kind regardz,
madpatrick
Post by madpatrick »
Fow sometime i don't see the wastebin icon any more on the homescreen.
Only the arrow is visible when the wastebin has to return
madpatrick wrote: Sat Mar 22, 2025 8:41 pm Hi,
Only the aeeow is visible when the wastebin has to return
I assume you are referring to the waste icon in the thermostat panel (above the room temperature) and not the systray icon.
Can you go to the settings screen of the app to review your settings:
'Display icon vanaf uur:" 18 (if you want to show icons from 18:00 the day before the waste is collected
"Afvalicons in thermostaat" : enabled (green)
If all is set ok and the future waste collection dates shown are ok, then I would advise to restart the gui.
Note that the wastecollection app is starting retrieving data about 5 minutes after the gui restart
madpatrick
I think it is an issue with the custom icons.
My webserver was change a few months ago and the icons were not resored to the new webserver.
Apperntly it was reloading the icons and could not find them (of course)
Only i can get them back for some reason.
The default icon apperaed when switch of the setting custom icons
Can it be and can use https websites?
dagr9782
RMN ICS
Post by dagr9782 »
In case you need to generate an ICS file from the RMN Afvalkalender Mendix site, I created a KNIME workflow to transform webcapture JSON to ICS.
1. Access https://21burgerportaal.mendixcloud.com/p/rmn/landing/
2. Fill in zipcode and house number (do not send)
3. F12 - Network (Developer Tools - Network Capture)
4. Send the form
5. Export the WebCapture to JSON
6. In the KNIME workflow, change the file in the first node and execute the last node.
RMN Afvalkalender.zip
KNIME workflow
(103.64 KiB) Downloaded 26 times
