Re: Toon firmware resource file (as from 4.16.8)
Posted: Sun Jul 29, 2018 8:15 pm
Yes that is (probably) in the other resources file containing all images. Will look into this, but low prio
Domotica - Home Automation Forum
https://domoticaforum.eu/
My apps folder looks like this ... as you can see some apps have multiple versions + links in the same directory ... is this a problem ?Toonz wrote: 1. by default all custom apps will be loaded from /qmf/qml/apps/ at startup.
Globals.qml is not used anymore for that purpose. If you don't want an app anymore, remove it from the apps folder
makkie2002, I see you have a webcam app?makkie2002 wrote:My apps folder looks like this ... as you can see some apps have multiple versions + links in the same directory ... is this a problem ?Toonz wrote: 1. by default all custom apps will be loaded from /qmf/qml/apps/ at startup.
Arcidodo wrote:how do i edit an *.rcc file? i found an app "QT" but i can only view it as an binary file.
It is a homemade app ... it is functional but not very performant ... but it does the job to display my IP-cam image (via a weblink to a (m)jpeg) ... please feel free to experiment with it !newwolf wrote:makkie2002, I see you have a webcam app?makkie2002 wrote:My apps folder looks like this ... as you can see some apps have multiple versions + links in the same directory ... is this a problem ?Toonz wrote: 1. by default all custom apps will be loaded from /qmf/qml/apps/ at startup.
Where did your get that from and what's in it?
Because I'm looking for something to show a webcam feed or photo of my frontdoor camera when there is someone pushing my doorbell.
I allready have a script that's sending a picture when the doorbell is pushed but if it also can be showed on my Toon it would be very cool
i want to edit it.. to remove the "toon" logo in the left top and add an custom pictureTheHogNL wrote:Arcidodo wrote:how do i edit an *.rcc file? i found an app "QT" but i can only view it as an binary file.
What do you want to do? It is not possible to edit the .rcc file as it indeed a binary file.
We create our own .rcc files to make it work on a > 4.16.8 toon.
Coolnewwolf wrote:makkie2002,
Thanks it's working.
I think a 4.19.10 release of the resource file is expected in a few days. However, I also advice not to upgrade if you don't have the 'flatline' graph issue.mAiden wrote:Eneco release today 4.19.10. Dont update it, if you like the custom apps.
