Page 2 of 2
Re: Squeezebox plugin v2 supports hstouch
Posted: Mon Jan 11, 2010 8:44 pm
by Wim2008
Hello Dick,
I tried also the standard, classic and the touch screen. All are succesfull introduced in HStouch this afternoon.
It is also recommend that you update to HSTouch server plugin 1.0.0.12 and the Squeezebox plugin 2.0.0.1 Beta.
And I used a normal textbox in HSTouch and changed the IsHTML=True and also AllowNavigation=True.
After this I brought in the IP-adress where Squeezebox is running on.
And it works by mine fine.
B.R. Wim :) :wink:
Posted: Mon Jan 11, 2010 9:24 pm
by Dickr43
Hmmm, strange. Will have another go at it later. Have ordered a new RFXcom LAN transmitter and receiver and will put that to work first. Got a lot of sensors that I can then implement....
Have fun!
Posted: Mon Jan 11, 2010 9:28 pm
by Wim2008
If you like to see more settings or information, ask me when you have more time.
B.R. Wim :) :wink:
Posted: Wed Jan 13, 2010 12:56 am
by r_255
The beta got updated and i am not loosing my players anymore.
There is also some small change of handling album art, so i guess the album art problem incombination with squeezeserver 7.4 should be fixed to.
Posted: Tue Jul 06, 2010 1:04 pm
by Snelvuur
to come back on the hstouch slimserver experience, i also change my slimserver skin to the layout like wim has. It works just like the website now with the ishtml=true. only problem that i have is that response time back is pretty slow. Sometimes it just takes a lot of time to report back the status via the website.
i am using the ipad though, i do think that the client of hstouch is pretty slow and could use some speedups too.
Posted: Tue Jul 06, 2010 8:12 pm
by Snelvuur
http://www.simulacrum.net.nz/squeeze/
found this page, might be of value.. its a "improved" version of the touch skin.
