Page 2 of 2
Re: Everspring doorsensor configuring OFF delay
Posted: Wed Jan 05, 2011 12:15 pm
by mhn
Have you tried associating a switch to the sensor?
Make the association between sensor and switch.
If you have a lamp on the sensor, you can see if the sensor sends on/off.
Regards
Morten
Posted: Wed Jan 05, 2011 12:50 pm
by Imbrium
Hi Tane,
I'm not a guy that brakes his promises
Homeseer 2.5.0.1
Z-stick Aeon Labs Series 2
Drivers Z-stick on XP :
http://www.aeon-labs.com/site/support/view/8/
Update Z-stick on XP :
http://www.aeon-labs.com/site/support/category/4/
I also installed everything on my Win 7 machine (with the correct drivers of course)......same result.....
Hope this can make a breaktrough.....
Best regards,
Lode.
Posted: Wed Jan 05, 2011 1:13 pm
by Imbrium
Hi Morten,
No i can't do that since i bought only a Z-stick and a sensor for testing purposes.
Altough i'm an ICT i can't see what's wrong here.
The sensor has been replaced so that's not the problem i think.
Thanks anyway..
Best regards,
Lode.
Posted: Wed Jan 05, 2011 9:40 pm
by TANE
Is there a association with Homeseer?
You can check this in the association setting of the doorsensor.
See the last picture in my review
http://blog.tane.nl/?p=178
Without association Homeseer will never notice status changes.
Posted: Thu Jan 06, 2011 12:03 am
by Imbrium
Tane,
I made an association between the sensor and homeseer below is what i see....
I only see homeseer and not the sensor
Your picture shows both devices or is it ok so because now IT WORKS !!
Posted: Thu Jan 06, 2011 12:07 am
by TANE
The attachment is not uploaded.
Posted: Thu Jan 06, 2011 12:29 am
by Imbrium
Sorry, post is edited...
Posted: Thu Jan 06, 2011 12:44 am
by TANE
good to hear that it's working.
You can associate with more than one device.
In my case i have associated with homeseer (i can trigger events depending on the status)
Other device is a switch.
Both will work when Homeseer is not available the second association will still work.
Zwave associations are stored on the devices. This is why i love zwave. it will also work without domotica software.
Posted: Thu Jan 06, 2011 2:00 am
by Imbrium
Tane,
Thank you so much for your help and also the other members, thanks a lot.
I can continue discovering this wonderfull world of domotica.
Tane, i send you a pm.
Best regards,
Lode.
